POV-Ray : Newsgroups : povray.general : smooth gradient color_map Server Time
21 May 2024 04:42:37 EDT (-0400)
  smooth gradient color_map (Message 28 to 37 of 37)
Subject: Re: smooth gradient color_map
Date: 23 Jul 2017 10:18:36
Message: <5974b03c$1@news.povray.org>
On 7/23/2017 9:13 AM, Jim Holsenback wrote:
> On 7/23/2017 7:43 AM, Jim Holsenback wrote:
>> On 7/23/2017 2:56 AM, Thomas de Groot wrote:
>>> On 23-7-2017 8:21, omniverse wrote:
>>>> clipka <ano### [at] anonymousorg> wrote:
>>>>> Am 22.07.2017 um 20:21 schrieb omniverse:
>>>>>> And something curious going on, I'm not sure about, when I add
>>>>>> blend_mode to my
>>>>>> example; I can't get the same appearance as yours, which seems to
>>>>>> remove the
>>>>>> purple color between blue and red.
>>> Now I am completely lost indeed. Where do you put that "blend_mode"
>>> parameter??? The wiki doesn't show in the examples, while it
>>> discusses it; something to correct I guess.
>> true enough no example ... but i thought i hinted about the order with
>> the syntax diagram
> well ok now ... looking closer i'm not entirely comfortable with that
> syntax diagram. i think i can do better. i'm trying to get 3.8 docs
> squared away so we can get back to doing a release ... standby
the syntax diagram has been changed to /correctly/ reflect it's /order/
specific nature when using blend_mode:
http://wiki.povray.org/content/Reference:Color_Map
http://wiki.povray.org/content/Reference:Pigment_Map
Date: 24 Jul 2017 02:40:23
Message: <59759657$1@news.povray.org>
Thank you indeed Jim, much clearer now.
Date: 24 Jul 2017 04:15:00
Message: <web.5975ac806b1125dc9c5d6c810@news.povray.org>
> Thomas
Documentation is 2nd only to the program itself, and sometimes I think of it the
other way around.
Thanks goes to Christoph (clipka) too for that more thorough blend explanation.
Takes me a couple three reads for most things like that. Ahhh that technical
detail stuff!
Date: 24 Jul 2017 06:48:56
Message: <5975d098$1@news.povray.org>
>> Thomas
> other way around.
> detail stuff!
I fully agree. Would it be going to far to ask if some of that
explanation could be included into the docs? I think it is not trivial.
Date: 24 Jul 2017 07:16:00
Message: <5975d6f0$1@news.povray.org>
>>> Thomas
>> of it the
>> other way around.
>> explanation.
>> technical
>> detail stuff!
i just updated (developer suggested) both syntax diagrams again ... if
you could help me out by replying here with relevant portions and i'll
follow up in the morning.
Date: 24 Jul 2017 07:59:06
Message: <5975e10a@news.povray.org>
>>>>> /order/
>>>> Thomas
>>> think of it the
>>> other way around.
>>> explanation.
>>> technical
>>> detail stuff!
I shall do that tomorrow if you don't mind. I have to go away now.
Date: 24 Jul 2017 12:57:33
Message: <597626fd$1@news.povray.org>
Am 24.07.2017 um 10:14 schrieb omniverse:
> detail stuff!
I'm not sure if I should get credit for at last explaining the stuff I
implemented myself...
Date: 25 Jul 2017 03:42:42
Message: <5976f672$1@news.povray.org>
I /think/ it is quite clear now what is intended and what blend_mode
does to the color_map entries. I find it a difficult matter altogether
though. Like always, I need a simple example to play with in order to
show me the differences. I have not yet done that with Christoph's
examples but will do so presently....
After playing a bit with that, I think I understand the theory but less
the (practical) use of blend_mode :-/
Date: 25 Jul 2017 12:07:45
Message: <59776cd1$1@news.povray.org>
Am 25.07.2017 um 09:42 schrieb Thomas de Groot:
Problem #1:
Linear greyscale gradients (which is what you get by default with
`assumed_gamma 1.0`) are typically perceived as non-linear.
Solution:
Introduce a mechanism to interpolate colour gradients in a non-linear
fashion. Enter `blend_mode 2`. (`blend_mode 1` was defined as a
mechanism to interpolate gradients in a linear fashion even when
`assumed_gamma 2.2` or similar is used.)
Problem #2:
Non-linear interpolation of colour gradients, if done on RGB values,
causes colour gradients to exhibit a midway dip in brightness and a poor
midway hue (note that this effect can be seen not only with `blend_mode
2`, but also with default blend mode if `assumed_gamma 2.2` or similar
is used).
Solution:
Introduce a mechanism to interpolate brightness in a non-linear fashion
while interpolating chromaticity (the relative ratio of R:G:B) in a
linear fashion. Enter `blend_mode 3`.
Date: 26 Jul 2017 02:53:03
Message: <59783c4f$1@news.povray.org>
On 25-7-2017 18:07, clipka wrote:
> Problem #1:
> Solution:
> Problem #2:
> is used).
> Solution:
Thank you indeed Christoph, much appreciated. My thoughts were not a
criticism towards the methods but more a failure from my side to
/really/ understand what was going on, and I did not go too deep into
experimentations. Your explanation is (as always) welcome and clear.
Next time I need some blending I shall certainly explore deeper.
