Subject: HELP: Old Scene Doesn't Render Anymore
Date: 23 Feb 2017 11:44:29
Message: <58af116d@news.povray.org>
Hi tried to render an older scene (a spaceship), but it doesn't render
anymore, only an error occurs and I am not able to fix it. Might be,
before I stopped working on that scene i added something that was
faulty, not sure.
Who can help?
#version 3.6;
#include "rand.inc"
#declare MyRadiosity = no; // yes
global_settings
assumed_gamma 1.0
#if(MyRadiosity)
radiosity
pretrace_start 0.08
pretrace_end 0.015
count 400
error_bound 0.75
recursion_limit 1
//#include "SL - Space - Ship - Cargo - Type 001 - Sepaei.inc"
camera
location < -10000.0, 10000, -10000.0 >
look_at < 0.0, 0.0, 0.0 >
light_source { < -50000, 50000, -50000 > White * 1.0 }
sky_sphere
pigment
planar
color_map
[ 0.0 color < 0.0, 0.0, 0.0 > ]
[ 1.0 color < 0.0, 0.0, 0.0 > ]
// Full Hull
#declare Pseudo_Hull = blob
threshold 0.04
sphere // Upper Hull
< 0.0, 0.0, 0.0 > 1135.0, 1.0
scale < 10.0, 1.0, 1.0 >
translate < 0.0, 750.0, 0.0 >
sphere // Lower Hull
translate < 0.0, -750.0, 0.0 >
sphere // Middle Hull
< 0.0, 0.0, 0.0 > 1135.0, 2.0
scale < 6.0, 1.75, 1.0 >
sphere // Flat Disk-Alike Sphere
< 0.0, 0.0, 0.0 > 1500.0, 1.0
scale < 2.0, 0.5, 1.0 >
sphere // Smaller Field-Generator-Carrying Ellipsoid
scale < 1.0, 0.15, 1.25 >
// Full Hull
#macro Full_Hull(Showtexture)
#declare Full_HullObj=blob
threshold 0.04
< 0.0, 0.0, 0.0 > 1135.0, 3.0
#declare Random_1 = seed(2); // Plus_X
#declare Random_2 = seed(7); // Sphere Diameter
#declare Random_3 = seed(3); // Sphere Height
#declare Random_4 = seed(9); // Sphere Translate
#declare Line_X = -6100.0;
#while (Line_X < -800.0)
#declare Trace_Start = < Line_X, 0.0, -2000.0 >;
#declare Trace_Direction = < Line_X, 0.0, 0.0 >;
#declare Trace_Norm = < 0.0, 0.0, 0.0 >;
#declare Sphere_Diameter = RRand(75, 150, Random_2);
#declare Sphere_Y = RRand(0.25, 0.50, Random_3);
#declare Translate_X = Line_X-1500;
#declare Translate_Y = RRand(0, 250, Random_4);
#declare Translate_Z = trace (Pseudo_Hull,
Trace_Start,(Trace_Direction-Trace_Start), Trace_Norm).z+250;
#declare DarkPower = 0.1;
sphere // Middle Constructions (-X +Y -Z)
< 0.0, 0.0, 0.0 > Sphere_Diameter, DarkPower
scale < 1.0, Sphere_Y, 1.25 >
pigment { color Green } // texture { Middle_Constructions }
translate < Translate_X, Translate_Y, Translate_Z >
sphere // Middle Constructions (-X +Y +Z)
translate < Translate_X, Translate_Y, (-1*Translate_Z) >
sphere // Middle Constructions (+X +Y -Z)
translate < (-1 *Translate_X), Translate_Y, Translate_Z >
translate <(-1 *Translate_X), Translate_Y, (-1*Translate_Z) >
sphere // Middle Constructions (-X -Y -Z)
translate < Translate_X, (-1*Translate_Y), Translate_Z >
sphere // Middle Constructions (-X -Y +Z)
translate < Translate_X, (-1*Translate_Y), (-1*Translate_Z) >
sphere // Middle Constructions (+X -Y -Z)
translate < (-1 *Translate_X), (-1*Translate_Y), Translate_Z >
translate <(-1 *Translate_X), (-1*Translate_Y), (-1*Translate_Z) >
#declare Plus_X = RRand(75, 150, Random_1);
#declare Line_X = Line_X + Plus_X;
#if (Showtexture=yes)
pigment { color Green } // texture { Hull_pigment { color Green } //
texture_Side scale 20000.0 translate < -10000.0, 0.0, 0.0 > }
// Full Hull
#macro Cut_Hull(Showtexture)
#declare Cut_HullObj = difference
object { Full_HullObj }
union
cylinder
< -20000.1, 0.0, 0.0 > < -7500.0, 0.0, 0.0 > 2000.0
cylinder
< 7500.0, 0.0, 0.0 > < 20000.1, 0.0, 0.0 > 2000.0
texture_Top
#declare Trace_Start = < -1000.0, 50.00001, -3000.0 >;
#declare Trace_Direction = < -1000.0, 50.00001, 0.0 >;
#declare Maximum = trace (Full_HullObj,
Trace_Start,Trace_Direction-Trace_Start, Trace_Norm).y - 750.0;
cylinder
< 0.0, -50.0, Maximum > < 0.0, 50.0, Maximum > 999.99999
pigment { color Green } // texture { Inside scale 1.0 translate <
0.0, 0.0, 0.0 > }
cylinder
< 0.0, -50.0, (-1 * Maximum) > < 0.0, 50.0, (-1 * Maximum) > 999.99999
0.0, 0.0, 0.0 > }
cylinder
< 0.0, -49.99999, Maximum > < 0.0, 50.0, Maximum > 1000.0
texture_Center_Side scale 20000.0 rotate < 90.0, 0.0, 0.0 > }
cylinder
< 0.0, -49.99999, (-1 * Maximum) > < 0.0, 50.0, (-1 * Maximum) > 1000.0
#declare Up_Low_Hull = difference
// object { Cut_Hull(no) }
Cut_Hull(no)
object { Cut_HullObj scale < 1.0, 1.0000000001, 1.0 > }
box { < -7500.0, -1400.0, -1700.0 > < 7500.0, 1400.0, 1700.0 > }
texture_Top scale 20000.0 translate < -10000.0, 0.0, 0.0 > }
#declare Hull_End_Blob = difference
#declare Strength1 = 5.000; //(+ or -) strength of component's
radiating density
#declare Strength2 = 0.500; //(+ or -) strength of component's
radiating density
#declare Strength3 = 0.500; //(+ or -) strength of component's
radiating density
#declare Strength4 = 0.500; //(+ or -) strength of component's
radiating density
#declare Strength5 = 0.500; //(+ or -) strength of component's
radiating density
#declare Radius1 = 0.250; //(0 < Radius) outer sphere of influence on
other components
#declare Radius2 = 0.036; //(0 < Radius) outer sphere of influence on
other components
#declare Radius3 = 0.037; //(0 < Radius) outer sphere of influence on
other components
#declare Radius4 = 0.038; //(0 < Radius) outer sphere of influence on
other components
#declare Radius5 = 0.040; //(0 < Radius) outer sphere of influence on
other components
#declare Distance1 = -0.000; //(0 < Radius) outer sphere of influence
on other components
#declare Distance2 = -0.100; //(0 < Radius) outer sphere of influence
on other components
#declare Distance3 = -0.125; //(0 < Radius) outer sphere of influence
on other components
#declare Distance4 = -0.140; //(0 < Radius) outer sphere of influence
on other components
#declare Distance5 = -0.147; //(0 < Radius) outer sphere of influence
on other components
#declare Height2 = ((Radius1/10)*6.75);
#declare Height3 = ((Radius1/10)*6.00);
#declare Height4 = ((Radius1/10)*5.00);
#declare Height5 = ((Radius1/10)*3.50);
blob
threshold 0.6 // threshold (0.0 < threshold <= Strength) surface
falloff threshold #
cylinder { < Distance1, 0.00, 0.00 >, < 1.00, 0.00, 0.00 >, Radius1,
Strength1}
cylinder { < Distance2, Height2, 0.00 >, < 0.00, Height2, 0.00 >,
Radius2, Strength2 rotate < 000.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 018.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 036.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 054.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 072.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 090.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 108.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 126.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 144.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 162.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 180.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 198.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 216.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 234.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 252.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 270.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 288.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 306.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 324.0, 0.0, 0.0 > }
Radius2, Strength2 rotate < 342.0, 0.0, 0.0 > }
cylinder { < Distance3, Height3, 0.00 >, < 0.00, Height3, 0.00 >,
Radius3, Strength3 rotate < 000.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 018.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 036.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 054.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 072.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 090.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 108.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 126.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 144.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 162.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 180.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 198.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 216.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 234.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 252.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 270.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 288.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 306.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 324.0+9, 0.0, 0.0 > }
Radius3, Strength3 rotate < 342.0+9, 0.0, 0.0 > }
cylinder { < Distance4, Height4, 0.00 >, < 0.00, Height4, 0.00 >,
Radius4, Strength4 rotate < 000.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 018.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 036.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 054.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 072.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 090.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 108.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 126.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 144.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 162.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 180.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 198.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 216.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 234.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 252.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 270.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 288.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 306.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 324.0+0, 0.0, 0.0 > }
Radius4, Strength4 rotate < 342.0+0, 0.0, 0.0 > }
cylinder { < Distance5, Height5, 0.00 >, < 0.00, Height5, 0.00 >,
Radius5, Strength5 rotate < 000.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 018.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 036.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 054.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 072.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 090.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 108.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 126.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 144.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 162.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 180.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 198.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 216.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 234.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 252.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 270.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 288.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 306.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 324.0+9, 0.0, 0.0 > }
Radius5, Strength5 rotate < 342.0+9, 0.0, 0.0 > }
scale 10000
rotate < 0.0, 0.0, 0.0 >
texture
pigment{ color rgb < 0.9, 0.9, 0.9 > }
// finish { phong 1 }
// 4x Hull Ends
#declare Hulls_End = union {
#declare Random_1 = seed(0);
#declare Random_2 = seed(12345);
#declare Count = 0;
#declare Trace_Start = < -7499.99999, 2000.0, 0.0 >;
#declare Trace_Direction = < -7499.99999, 0.0, 0.0 >;
#declare Maximum = trace (Cut_HullObj, Trace_Start,
Trace_Direction-Trace_Start,Trace_Norm).y - 750.0;
#declare Minimum = 100.0;
#declare Maximum_Inner = Maximum-Minimum;
#declare Maximum_Outer = Minimum;
torus { Maximum-Minimum, Minimum rotate < 0.0, 0.0, 90.0 > }
cylinder { < -100.0, 0.0, 0.0 > < 0.0, 0.0, 0.0 > Maximum-Minimum }
// #while (Count < 10)
// #declare Outer=RRand(Minimum, Maximum_Outer, Random_1);
// #declare Inner=RRand(Minimum, Maximum_Inner, Random_1);
// #if (Outer+Inner<=Maximum)
// #declare Count=Count+1;
// #end
// #end
texture_End scale 20000.0 translate < -10000.0, 0.0, 0.0 > }
// 4x Hangar Light bars
#declare Hangar_Light_Bars = union
#declare Thickness = 1.0;
#declare Axis_X = -1000.0;
#while (Axis_X < 1000.0)
#declare Trace1_Start = < Axis_X, 50.00001, -3000.0 >;
#declare Trace1_Direction = < Axis_X, 50.00001, 0.0 >;
#declare Axis_Z1 = trace (Cut_HullObj,
Trace1_Start,Trace1_Direction-Trace1_Start, Trace_Norm).z;
#declare Trace2_Start = < (Axis_X+10.0), 50.00001, -3000.0 >;
#declare Trace2_Direction = < (Axis_X+10.0), 50.00001, 0.0 >;
#declare Axis_Z2 = trace (Cut_HullObj,
Trace2_Start,Trace2_Direction-Trace2_Start, Trace_Norm).z;
sphere { < Axis_X, 50.0, Axis_Z1 > Thickness }
cylinder { < Axis_X, 50.0, Axis_Z1 > < (Axis_X+10.0), 50.0, Axis_Z2 >
Thickness }
sphere { < Axis_X, -50.0, Axis_Z1 > Thickness }
cylinder { < Axis_X, -50.0, Axis_Z1 > < (Axis_X+10.0), -50.0, Axis_Z2
> Thickness }
sphere { < Axis_X, 50.0, (-1 * Axis_Z1) > Thickness }
cylinder { < Axis_X, 50.0, (-1 * Axis_Z1) > < (Axis_X+10.0), 50.0, (-1
* Axis_Z2) > Thickness }
sphere { < Axis_X, -50.0, (-1 * Axis_Z1) > Thickness }
cylinder { < Axis_X, -50.0, (-1 * Axis_Z1) > < (Axis_X+10.0), -50.0,
(-1 * Axis_Z2) > Thickness }
#declare Axis_X = Axis_X + 10.0;
sphere { < (Axis_X+10.0), 50.0, Axis_Z2 > Thickness }
sphere { < (Axis_X+10.0), -50.0, Axis_Z2 > Thickness }
sphere { < (Axis_X+10.0), 50.0, (-1 * Axis_Z2) > Thickness }
sphere { < (Axis_X+10.0), -50.0, (-1 * Axis_Z2) > Thickness }
pigment { color Green } // texture { Hangar_Light_Stripe }
#declare Ship = union
// object
Cut_Hull(yes)
/* object
Up_Low_Hull
object
Hulls_End
translate < -7500.0, 750.0, 0.0 >
object
Hulls_End
translate < 7500.0, 750.0, 0.0 >
object
Hulls_End
translate < -7500.0, -750.0, 0.0 >
object
Hulls_End
translate < 7500.0, -750.0, 0.0 >
object
Hangar_Light_Bars
union
object
Ship
> faulty, not sure.
> Who can help?
You have not declared texture_Top
Regards
Yes, that is correct, but this is a step to do for later. At the moment,
all "texture_Top" are commented out with "//".
The error must be something else.
>> faulty, not sure.
>> Who can help?
This is the error I get when I run the text you posted
"C:\Users\Stephen\Documents\Graphics\Blender
Test\Models\Output\Comparison\wax.pov" line 213: Parse Error: No
matching } in 'union', undeclared identifier 'texture_Top'
>>> faulty, not sure.
>>> Who can help?
Regards
After I corrected for all comment lines, because of how your message text is
wrapped here at the newsgroups, I was able to render the SDL without errors.
By using /* comment line */ you could avoid that, otherwise it's impossible to
know where a long commented text ends.
And I also commented out the unnecessary difference {} for Hull_End_Blob, and
the union {} around object{Ship} so there wouldn't be any soft errors.
Although the actual rendered image appears to be only 4 green disk shapes and a
scatter of specks between them, I'm guessing there might still be something
wrong. Since your include isn't available I wasn't sure but just from looking at
what's there of the SDL already I don't know why more isn't showing in the
image. I didn't try to find out (yet).
Subject: Re: HELP: Old Scene Doesn't Render Anymore
Date: 23 Feb 2017 21:43:06
Message: <58af9dba@news.povray.org>
Hmmm, it actually should look more like this older scene image. Seems, I
had added some faulty or unfinished lines before I rested this project,
years ago.
Let me do on my side what you all describe here, and feedback with an
update later on.
> Bob
Download 'space - ship - cargo - type 001 - sepaei.png' (102 KB)
Preview of image 'space - ship - cargo - type 001 - sepaei.png'
it seems I don't get the success you got with my scene. Maybe I am not
eating the right vitamins, but I still get errors. Or I am losing my
POV-Ray skills...
Can you show me the successfully rendering scene code, or at least the
resulting image? Thanks.
> Bob
I think, the error lies within my TRACE command somewhere.
> Bob
Okay, if you can select all of this (except these words) and copy as it is there
shouldn't be any errors. Although only 2 green bar-like objects get rendered.
I only commented out lines of SDL. I still don't know what the other parts are
about, nothing else seems to show.
/* ERRORLESS */
#version 3.6;
#include "rand.inc"
global_settings
assumed_gamma 1.0
#if(MyRadiosity)
radiosity
pretrace_start 0.08
pretrace_end 0.015
count 400
error_bound 0.75
recursion_limit 1
/* #include "SL - Space - Ship - Cargo - Type 001 - Sepaei.inc" */
background{rgb 0.5}
camera
sky_sphere
pigment
planar
color_map
// Full Hull
threshold 0.04
sphere /* Smaller Field-Generator-Carrying Ellipsoid */
// Full Hull
threshold 0.04
pigment { color Green } /* texture { Middle_Constructions } */
pigment { color Green } /* texture { Hull_pigment { color Green } //
texture_Side scale 20000.0 translate < -10000.0, 0.0, 0.0 > } */
// Full Hull
union
cylinder
cylinder
//texture_Top scale 20000.0 translate < -10000.0, 0.0, 0.0 > } */
(Full_HullObj,Trace_Start,Trace_Direction-Trace_Start, Trace_Norm).y - 750.0;
cylinder
pigment { color Green } /* texture { Inside scale 1.0 translate <0.0, 0.0,
0.0 > } */
cylinder
0.0 > } */
cylinder
//texture_Center_Side scale 20000.0 rotate < 90.0, 0.0, 0.0 > } */
cylinder
#end // macro
Cut_Hull(no)
pigment { color Green } /* texture { Hull_pigment { color Green } //texture_Top
#declare Hull_End_Blob = //difference
#declare Strength1 = 5.000; /*(+ or -) strength of component's radiating
density*/
#declare Strength2 = 0.500; /*(+ or -) strength of component's radiating
density*/
#declare Strength3 = 0.500; /*(+ or -) strength of component's radiating
density*/
#declare Strength4 = 0.500; /*(+ or -) strength of component's radiating
density*/
#declare Strength5 = 0.500; /*(+ or -) strength of component's radiating
density*/
#declare Radius1 = 0.250; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Radius2 = 0.036; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Radius3 = 0.037; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Radius4 = 0.038; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Radius5 = 0.040; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Distance1 = -0.000; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Distance2 = -0.100; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Distance3 = -0.125; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Distance4 = -0.140; /*(0 < Radius) outer sphere of influence on other
components*/
#declare Distance5 = -0.147; /*(0 < Radius) outer sphere of influence on other
components*/
blob
threshold 0.6 /* threshold (0.0 < threshold <= Strength) surface falloff
threshold # */
Strength1}
scale 10000
texture
//} // end difference
// 4x Hull Ends
#declare Count = 0;
#while (Count < 10)
//texture_End scale 20000.0 translate < -10000.0, 0.0, 0.0 > } */
Thickness }
cylinder { < Axis_X, -50.0, Axis_Z1 > < (Axis_X+10.0), -50.0, Axis_Z2 >
Thickness }
cylinder { < Axis_X, 50.0, (-1 * Axis_Z1) > < (Axis_X+10.0), 50.0, (-1 *
cylinder { < Axis_X, -50.0, (-1 * Axis_Z1) > < (Axis_X+10.0), -50.0, (-1 *
pigment { color Green } /* texture { Hangar_Light_Stripe } */
// object
Cut_Hull(yes)
object
Up_Low_Hull
object
Hulls_End
object
Hulls_End
object
Hulls_End
object
Hulls_End
object
Hangar_Light_Bars
//union
object
Ship
Am 26.02.2017 um 01:03 schrieb Sven Littkowski:
Maybe. You're using:
trace (Pseudo_Hull, Trace_Start,
Trace_Norm).z+250;
Presuming that Trace_Direction is indeed supposed to be a direction (as
opposed to a location), then it should instead be:
Trace_Direction,
Trace_Norm).z+250;
(If however Trace_Direction is supposed to be a location after all, then
disregard this post.)
