POV-Ray : Newsgroups : povray.general : Stopping a render Server Time
17 Jun 2024 06:58:56 EDT (-0400)
  Stopping a render (Message 1 to 7 of 7)
Subject: Stopping a render
Date: 3 Dec 2016 23:34:57
Message: <58439cf1$1@news.povray.org>
I started rendering a 16 frame animation. I am at frame #8, and want to
stop when this one is done. How do I tell POV-Ray to stop after the
current frame and not continue? I don't want to start the sequence over
again.
Mike
Subject: Re: Stopping a render
Date: 4 Dec 2016 01:38:31
Message: <5843b9e7$1@news.povray.org>
Am 04.12.2016 um 05:35 schrieb Mike Horvath:
> again.
Hm... I guess that would be a feature waiting to be implemented.
Are we talking about Unix or Windows?
IIRC the Windows version already pops up a warning when stopping a long
render; maybe we could extend that window to offer three choices: Stop
now, stop as soon as the current frame has finished, or simply continue.
Of course that additional choice would have to be backed by new internal
logic, but I don't think it should be too difficult.
As for the Unix version, I'm not familiar enough with it to say how such
a functionality could be offered to the user.
Date: 4 Dec 2016 03:15:01
Message: <web.5843cfc1afd893e29c5d6c810@news.povray.org>
> > again.
Would be great to be able to do that, but the current method would be to just
stop rendering and use +C to continue later. At least for Windows.
Should be possible to either use that on the command line before beginning the
animation frames (before any frame is made) or after stopping the rendering
(adding +c before restart). Just jumps (eventually) to the next in line needing
the render.
Date: 4 Dec 2016 05:07:36
Message: <5843eae8$1@news.povray.org>
>>> again.
> the render.
You should also use:
Subset_Start_Frame
Subset_End_Frame
when restarting the render. Or PovRay will start at the first frame and
step through them to see if that frame has been rendered before
continuing the render. If you have lots of frames rendered it is annoying.
Regards
Date: 4 Dec 2016 17:02:04
Message: <5844925c$1@news.povray.org>
>>>> again.
>> to just
>> beginning the
>> rendering
>> line needing
>> the render.
> Subset_Start_Frame
> Subset_End_Frame
Subset_Start_Frame should be enough, unless you don't want to render to
the end of the animation.
Date: 4 Dec 2016 18:02:07
Message: <5844a06f$1@news.povray.org>
Yes, indeed.
I use a template that uses Start and Finish as well.
Regards
Date: 5 Dec 2016 10:41:11
Message: <58458a97$1@news.povray.org>
I don't.
