POV-Ray : Newsgroups : povray.general : finish emission Server Time
14 Jan 2026 15:14:31 EST (-0500)
  finish emission (Message 1 to 7 of 7)
Subject: finish emission
Date: 8 Sep 2016 01:16:05
Message: <57d0f415$1@news.povray.org>
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.3#Using_Emission
Is emission always a single number, or does it take a color vector too?
I have emission 1 in my scene and am wondering if I should use a light
source's color value as well.
Mike
Subject: Re: finish emission
Date: 8 Sep 2016 01:40:44
Message: <57d0f9dc$1@news.povray.org>
It takes a colour vector.
Regards
Date: 8 Sep 2016 02:20:56
Message: <57d10348$1@news.povray.org>
Is it better to use the color vector than "1"?
Date: 8 Sep 2016 02:53:41
Message: <57d10af5$1@news.povray.org>
It depends what you want the effect to be. If you want a white emission
then use a digit.
If you want something more interesting then use the vector.
   absorption srgb <0.000,1.000,1.000> * Absorption_Factor
   emission   srgb <1.000,0.000,0.000> * Emission_Factor
Regards
Date: 8 Sep 2016 03:46:16
Message: <57d11748$1@news.povray.org>
> then use a digit.
I'm not talking about emissive media. I am talking about the emission
keyboard in the finish statement.
Also, I'm not sure how to update the lens effects script.
http://www.oocities.org/ccolefax/lenseffects.html
It defines pigments and finishes at different times and places in the
code. Very tricky.
Mike
Date: 8 Sep 2016 04:01:04
Message: <57d11ac0$1@news.povray.org>
>>>>> too?
>> then use a digit.
I don't use it. I am stuck on Pov 3·6.
But since "The syntax and effect are virtually identical to ambient".
Use it the way you would with ambient to add a bit of lighting. You can
also use it with radiosity to make an object glow a colour.
> code. Very tricky.
Sorry, it is years since I looked at it and even then it was as a plugin.
I would be tempted to load the file(s) in a spreadsheet and filter it on
ambient and emission. Just to see how often they are referenced. It
might be a simple find & replace, job.
Regards
Date: 8 Sep 2016 04:08:30
Message: <57d11c7e$1@news.povray.org>
Am 08.09.2016 um 07:16 schrieb Mike Horvath:
The emission can be a colour, but it is automatically multiplied by the
pigment colour. So to get a coloured emission, you can _either_ use a
white pigment and set `emission` to the desired colour, _or_ use a
pigment of the desired colour and set `emission` to a float.
And yes, you should indeed do one of these things in a looks_like object
if the light source itself isn't white.
