POV-Ray : Newsgroups : povray.general : Cloth backdrop Server Time
16 Nov 2025 13:49:36 EST (-0500)
  Cloth backdrop (Message 1 to 10 of 11)
Subject: Cloth backdrop
Date: 4 Sep 2016 03:11:43
Message: <57cbc92f$1@news.povray.org>
Many times in photography you see smooth backdrops behind small objects
so you don't see a sharp crease where a floor might meet a wall. How
would I create one of these in POV-Ray? It would need to be circular
since I might use any camera angle.
Thanks!
Mike
Subject: Re: Cloth backdrop
Date: 4 Sep 2016 03:53:50
Message: <57cbd30e@news.povray.org>
> Thanks!
> Mike
Simple case:
The floor and wall are planes. You connect them using a clipped cylinder.
If the wall is curved, you replace the cylinder by a clipped torus.
In both cases, you can make the curvature of the link as small or large
as you want.
Date: 4 Sep 2016 08:24:38
Message: <57cc1286$1@news.povray.org>
>> Thanks!
>> Mike
> Simple case:
> as you want.
Is there a smoother shape than a torus? I can still see a fuzzy seam.
Mike
Date: 4 Sep 2016 08:49:20
Message: <57cc1850$1@news.povray.org>
Am 04.09.2016 um 09:11 schrieb Mike Horvath:
I'd probably use a cubic spline lathe; alternatively, a f(x)=pow(x,1/n)
surface of revolution might also work.
Cylinder&Torus-based solutions are probably prone to so-called mach
banding at the transition between the shapes (the illusion of brighter
or darker bands, related to the fact that the human eye is not only
sensitive to abrupt changes in brightness, but also to abrupt changes in
the the rate of change in brightness).
Date: 4 Sep 2016 09:15:01
Message: <web.57cc1dc48f7556c45e7df57c0@news.povray.org>
What about:
(Hit [CTRL]-[F] and search for "tornado" )
http://bugman123.com/Renderings/index.html
Date: 4 Sep 2016 16:05:00
Message: <web.57cc7dd68f7556c47a3e03fe0@news.povray.org>
> Thanks!
> Mike
superellipsoid with cubic pattern: good room. Door and window:CSG
Date: 5 Sep 2016 11:18:38
Message: <57cd8cce$1@news.povray.org>
> Thanks!
> Mike
Perhaps a mesh...?  Estimate the sort of curve you need and use nested
loops to generate an array of points.  It has the advantage of being
fairly easy to tweak.
--Sherry K. Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 5 Sep 2016 17:23:35
Message: <57cde257$1@news.povray.org>
>> Thanks!
>> Mike
> --Sherry K. Shaw
I think the only way to get rid of the seam completely is to create a
giant sphere with the light source in the middle, then put the scene
objects on the bottom inner surface of the sphere. But that will create
weird shadows and a lot of objects getting clipped by the sphere.
Mike
Date: 5 Sep 2016 17:25:15
Message: <57cde2bb$1@news.povray.org>
On 9/4/2016 9:12 AM, Bald Eagle wrote:
> What about:
What?
Date: 5 Sep 2016 18:51:07
Message: <57cdf6db$1@news.povray.org>
> Thanks!
> Mike
Try:
prism{
  bezier_spline
to simulate one side of a cloth hanging from cieling and draped on floor.
or
lathe{
  bezier_spline
With the bezier_spline you can have true flat surface to place objects
and curve without seam.
Stephen S
