POV-Ray : Newsgroups : povray.general : Erroneous CCT comments in Lightsys IV Server Time
25 Nov 2024 01:51:23 EST (-0500)
  Erroneous CCT comments in Lightsys IV (Message 1 to 6 of 6)
Subject: Erroneous CCT comments in Lightsys IV
Date: 19 May 2016 20:47:01
Message: <573e5e85$1@news.povray.org>
In the file espd_cie_standard.inc, the correlated color temperatures of
illuminants B, C, and F9 are given as 5860 K, 6769 K, and 6150 K,
respectively, in the comments.  As far as I can determine, those values
should be 4874 K, 6774 K, and 4150 K.
Being only in the comments, these errors do not affect the operation of
Lightsys IV.
Subject: Re: Erroneous CCT comments in Lightsys IV
Date: 20 May 2016 11:18:32
Message: <573f2ac8$1@news.povray.org>
> of illuminants B, C, and F9 are given as 5860 K, 6769 K, and 6150 K,
> values should be 4874 K, 6774 K, and 4150 K.
> of Lightsys IV.
   Yes, that seems to be the case... I've corrected those comments for
future versions (not worthy pushing a new release now just for that).
jaime
Date: 22 May 2016 14:54:03
Message: <5742004b$1@news.povray.org>
Am 5/20/2016 um 2:46 schrieb Cousin Ricky:
> Lightsys IV.
Just seen this post and you are right - almost. 6150K seems to be an
unspotted typo and 5860K is plain wrong.
So, to be sure and in case there is a color scientist reading this, I've
recalculated the values using the method of A. R. Robertson as described
in "Color Science: Concepts and Methods, Quantitative Data and Formulae"
by G. Wyszecki and W. S. Stiles.
The result:
illuminant B: 4871 K
illuminant C: 6774 K
So you are close with B and perfect with C in whatever way you've
determined it and thanks for spotting the errors.
P.S. @Jaime: in case you are updating lightsys, please use these values
and change it also within your version of CIE.inc where the values are
4882K and 6769K - the result of some lazy way I've used at this time to
calculate it.
-Ive
Date: 23 May 2016 13:00:01
Message: <web.57433664de6442ec48abfd6f0@news.povray.org>
Various sources on the Web, but I haven't got behind any pay walls.
Your old C is very close to the new one, and your new B is close to what I found
for B.  Could this have anything to do with the refinement of the Boltzmann
constant, or would it be strictly methods of calculating the CCT?  (I'm nowhere
near where I want to be in color science.)
Date: 23 May 2016 18:17:20
Message: <57438170$1@news.povray.org>
Am 5/23/2016 um 18:57 schrieb Cousin Ricky:
I'm pretty sure it is the way you are calculating it. You can do it in a
lazy way as I usually did while I was working in the field and accuracy
really didn't matter (which should not be an excuse for making plain
mistakes) or you can do it in the way of Robertson who calculates the
closest distance for a given point in the CIE XYZ color space to the
blackbody radiation curve. But it requires inverse interpolation of the
Blackbody temperatures and forward interpolation on a data table and
other nasty algebra stuff. And nobody likes algebra, right? ;)
is not behind a paywall, it is one of this old fashioned things where
pages are still made of paper. And it is "The Bible" of color science.
http://eu.wiley.com/WileyCDA/WileyTitle/productCd-0471399183.html
Anyway I did add a POV-Ray SDL implementation of Robertson's method
within CIE.inc. The new version can, as usual, be downloaded from my
spectral render web page - or directly via
www.lilysoft.org/CGI/SR/LS_SpectralRender.zip
Following the tradition of CIE.inc the new macro is called XYZ2K(XYZ),
it takes a CIE XYZ coordinate as parameter and gives the color
temperature in Kelvin back.
Here is the way it is called to calculate the B and C illuminants:
#include "CIE.inc"
#declare XYZ_B = xyY2xyz(<Illuminant_B[0], Illuminant_B[1], 1>);
#declare XYZ_C = xyY2xyz(<Illuminant_C[0], Illuminant_C[1], 1>);
#declare KB = XYZ2K(XYZ_B);
#declare KC = XYZ2K(XYZ_C);
#warning concat("Correlated color temperature for illuminant B:
",str(KB,4,1),"K")
#warning concat("Correlated color temperature for illuminant C:
",str(KC,4,1),"K")
-Ive
Date: 24 May 2016 00:00:00
Message: <web.5743d109de6442ec48abfd6f0@news.povray.org>
I didn't calculate anything.  I just got those numbers from various sources on
the Web.
