POV-Ray : Newsgroups : povray.general : Ovus Server Time
19 May 2024 18:37:43 EDT (-0400)
  Ovus (Message 18 to 27 of 27)
Subject: Re: Ovus
Date: 6 May 2016 10:24:10
Message: <572ca90a@news.povray.org>
Le 06/05/2016 16:13, Bald Eagle a écrit :
> Correct me if I'm wrong, but does Wolfram have the 2D cross-sectional diagrams
> (on the right) switched for the spindle and horn tori?
> http://mathworld.wolfram.com/SpindleTorus.html
> http://mathworld.wolfram.com/HornTorus.html
Yes, you are correct. the slice is correct, but the 3D in the middle are
switched.
Subject: Re: Ovus
Date: 25 May 2016 08:06:39
Message: <5745954f$1@news.povray.org>
Le 04/05/2016 à 17:42, clipka a écrit :
>> > About being doable, yes, I can (but there will be additional constraints
>> > on the values, such a minimal minor radius function of the three other
>> > distances under which you would get an error)
> Of course such constraint checks would be part of the deal.
>> > And do you expect default values for some parameters too ? (yet more
>> > syntax sugar... )
> Since I'd advocate to put it into the ovus primitive, of course the
> default values would be Bottom_radius for the Y coordinate of the top
> sphere, and 2*max(Bottom_radius,Top_radius).
back to that subject... finding a suitable syntax, backward compatible
with existing syntax.
So far :
   ovus { Bottom_radius, Top_radius }
0 <= Bottom_radius
0 <= Top_radius <= 2*Bottom_radius
(when TopRadius > 2*BottomRadius, object is replaced by a sphere)
Additional parameters:
   InnerRadius (default to 2 * max( Bottom_radius, Top_radius )
   Distance_between_spheres (default to Bottom_radius )
0 <= Bottom_radius
0 <= Top_radius
0 <= Distance_between_spheres (Bottom is at <0,0,0>,
   but Top is at <0, Distance_between_spheres, 0> instead
   of <0, Bottom_radius, 0>
complex relation for InnerRadius vs its minimal value.
If it was only for one additional parameter the obvious syntax would
have been:
   ovus { Bottom_radius, Top_radius [, extra_value ] }
Please provide some suggestions about an acceptable syntax.
Subject: Re: Ovus
Date: 25 May 2016 14:05:15
Message: <5745e95b$1@news.povray.org>
Am 25.05.2016 um 14:06 schrieb Le_Forgeron:
> have been:
How about
    ovus { Bottom_radius, Top_radius [, extra_value1, extra_value2 ] }
Subject: Re: Ovus
Date: 25 May 2016 14:31:06
Message: <5745ef6a$1@news.povray.org>
>> have been:
> How about
Yes... but which one is or should be the first ? (or which one should be the second,
less used) ?
Subject: Re: Ovus
Date: 25 May 2016 15:50:37
Message: <5746020d$1@news.povray.org>
Forgive me for being slow to understand, but is the
lemon/barrel/ogive(1) then going to be added as new object and the
current ovus made at little more flexible - rather than folding all the
function recently discussed into one object?
Guess, my thinking is if we are doing the new barrel object, we can
duplicate the new ovus function for which we need syntax by adding
spheres to the end of the new lemon/barrel/ogive.
Suppose taking it the other way around, if we update the ovus only,
nothing stops us from chopping off the ends to match the
lemon/barrel/ogive. Though we'd not have the 'open' mode that way.
(1) - Taking the barrel/ogive to be the improved ovus less the two end
spheres ?
Bill P.
Subject: Re: Ovus
Date: 25 May 2016 16:28:52
Message: <57460b04$1@news.povray.org>
> Forgive me for being slow to understand, but is the lemon/barrel/ogive(1) then going
to be added as new object and the current ovus made at little more flexible - rather
than folding all the function recently discussed into one object?
> Guess, my thinking is if we are doing the new barrel object, we can duplicate the
new ovus function for which we need syntax by adding spheres to the end of the new
lemon/barrel/ogive.
> Suppose taking it the other way around, if we update the ovus only, nothing stops us
from chopping off the ends to match the lemon/barrel/ogive. Though we'd not have the
> (1) - Taking the barrel/ogive to be the improved ovus less the two end spheres ?
> Bill P.
It is a bit more complex than that.
lemon is not an ovus without spheres, or rather, to use a manual lemon with additional
spheres to make an ovus, the computation is not simple. (no, you do not just put the
sphere at the vertex of lemon).
 ( And you get coincident surfaces problem too, and internal surfaces, useless
computations... things that are better handled in code than later in SDL. )
The same way that putting spheres at the ends of a conical frustum does not make a
nice segment of linear sphere_sweep.
It's easy with a cylinder, but become more subtle when the radius are different.
lemon is similar to cone, even a bit better: you can get a true lemon (mathematical
object), or a frustum of lemon. With SDL cone, you get a false mathematical cone or a
conical frustum (because a true cone would be infinite along its axis, both ways, and
povray's cone is
actually only a right circular cone, not all cones)
Subject: Re: Ovus
Date: 26 May 2016 07:25:27
Message: <5746dd27$1@news.povray.org>
>> Bill P.
additional spheres to make an ovus, the computation is not simple. (no, you do not
just put the sphere at the vertex of lemon).
povray's cone is
Thanks for the detailed explanation.
If we will then have both an improved ovus and a new lemon/barrel/ogive
object in 3.7.1, I would suggest adding the two new arguments for the
ovus in the same order the equivalent information is given to the lemon
in your mercurial "Hg-povray" code. Namely:
ovus { Bottom_radius, Top_radius [, sphere_to_sphere, inner_radius ] }
Bill P.
Subject: Re: Ovus
Date: 26 May 2016 09:51:18
Message: <5746ff56$1@news.povray.org>
>>> have been:
>> How about
less used) ?
Both must be associated with a keyword.
It can be something like offset for the placement of the second sphere
and link_radius or spindle_radius for the other one.
Subject: Re: Ovus
Date: 3 Jun 2016 13:41:13
Message: <5751c139$1@news.povray.org>
Am 25.05.2016 um 20:30 schrieb Le_Forgeron:
>>> have been:
>> How about
less used) ?
It doesn't matter if you make it mandatory to either supply exactly two
parameters (the Bottom_radius and Top_radius) or exactly four (all the
parameters).
Subject: Re: Ovus
Date: 3 Jun 2016 13:53:37
Message: <5751c421$1@news.povray.org>
Am 26.05.2016 um 15:52 schrieb Alain:
>>>> have been:
>>> How about
>> be the second, less used) ?
"must"?
No. There's no objective requirement for that.
"should"?
Personally I disagree, but fair enough.
