![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
My brain has gone dead.
How do you set up a scene so that a box with an image map is visible
when it is only lit from behind. It is visible when the background is
not black.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> not black.
You mean: the box should be /invisible/ with a background other than black?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> not black.
No the other way around. The image should be visible when the background
is black.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 03.04.2016 um 13:14 schrieb Stephen:
To _light_ an object from its _inside_, there are two alternatives:
(A) double_illuminate
Using "double_illuminate" in an object will cause incident light from
the back side of a surface to cause the exact same effect as light from
the front side (as far as diffuse illumination is concerned; it does not
cause highlights).
(B) two-parameter diffuse
Using "diffuse FRONT,BACK" in a finish does virtually the same thing,
except that this property is tied to the finish rather than the object,
and allows different brightness levels depening on what side of the
surface the light is coming from.
To _light_ a solid object from its _back_, there are two alternatives as
well (presuming you want a diffuse effect):
(A) dense scattering media
(B) subsurface light transport
> not black.
Not sure what to make of this sentence.
Maybe I misunderstood your request, and what you're really after is just
coloured transparency? In that case, there's only one "alternative":
(A) filtering pigment
Using "colour rgb SOMETHING filter 1.0" will cause the background to be
visible, but tinted with the specified colour.
To achieve the same effect with an image-based pigment, use "image_map {
... filter all 1.0 }"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> >not black.
That is what I was trying to do but I got the meaning of diffuse A for
Elbow. :(
Now I have to find out why the colours of the output looks different
when the camera is at the front or at the back..
Although I have been on the newsgroups I have not been Poving for about
two and a half years. It is true, if you don't use it you lose it. ;-)
And what has not helped is that I was quite ill in hospital and seem to
have misplaced a few neurons.
Thanks
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> >not black.
> Elbow. :(
Maybe a little example image would help.
Yes, that is true.
Using POV-Ray will grow new ones in the right place.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oops! It was an assumed gamma problem. My default scene was still set up
for 2.2.
I have been meaning to update that file for ages.
As the poet said. "Never put off till tomorrow that which you can put
off today." ;)
I don't need new ones I just need the old ones connected properly.
It is a sair fecht for a hauf loaf.
(Another saying for your linguistic collection ;) )
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 03.04.2016 um 17:54 schrieb Stephen:
>>> >not black.
> Elbow. :(
Forgot to turn off highlights and/or reflections?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
LOL Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>>> not black.
>> Elbow. :(
No, I did that.
One of the Devs has been mucking about with the gamma.
Can you believe it?
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
