POV-Ray : Newsgroups : povray.general : Repeating texture sprite Server Time
18 May 2024 09:52:39 EDT (-0400)
  Repeating texture sprite (Message 16 to 25 of 25)
Subject: Re: Repeating texture sprite
Date: 1 Mar 2016 08:40:01
Message: <web.56d59b683999a405e7df57c0@news.povray.org>
"Go go POV-Ray newsgroup!"
"Activate: Colefax Include file!"
:O
Thanks for all the links.
There's a bunch of includes I'm sure I'll love playing with.
Date: 1 Mar 2016 10:05:01
Message: <web.56d5af013999a405e7df57c0@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> I played around with this a bit. It seems it creates images that can be
> imported and used in subsequent scenes as repeating textures, but not
> repeating flat textures that can be used within the *same* scene. Unless
> I'm missing something.
> Mike
I guess I'm not quite following what exactly it is that you're trying to
accomplish.
Could you expand upon what "... but not repeating flat textures that can be used
within the *same* scene" means?
I sliced up that little island/water jpg and played around with the tiles, but
it's not clear to me how you're intending to arrange them.  There are only 8
tiles, whereas I _did_ understand the logic behind the 9-tile system that
Anthony posted.  I couldn't get those tiles to do much, and after using 6, I
only had a choppy cubist reef and 2 extra tiles that seemed unusable or
redundant.
Maybe throw together a diagram or two to illustrate the goal - even if it's on
real quick on paper and photographed with a cellphone.  ;)
Date: 1 Mar 2016 10:30:00
Message: <web.56d5b49c3999a405e7df57c0@news.povray.org>
http://www.jazz2online.com/tilesets/programs.php
http://www.verycomputer.com/275_080d1f45e2064eba_1.htm
Just posting these here - because.  :D
Date: 1 Mar 2016 12:03:05
Message: <56d5cb49$1@news.povray.org>
>> Mike
> accomplish.
I want to create an flat textured object (such as a polygon or plane)
that is parallel to the ground; and that through clever manipulation
within POV-Ray itself can be used to create a series of frames like this:
http://uploads.gamedev.net/monthly_06_2011/ccs-8549-0-57863900-1307467523.gif
Except that I want them to be isometric. Think in terms of the old
strategy game Civilization II.
Here's an image chosen at random using Google that shows what an
isometric game sprite looks like:
https://s-media-cache-ak0.pinimg.com/736x/84/25/bb/8425bb96e5bcb75a8ef3a9c8fbde1bd2.jpg
If you look at Chris Colefax's Tile Generator carefully, you'll find it
creates a 3D scene - not a 2D scene - that is meant to be looked at from
one and only one direction. Therefore, I cannot use it in an isometric
scene.
I want to do 99% of the work in POV-Ray, not using some third-party tool
or Photoshop.
A short recap:
1. The object needs to be a flat textured POV-Ray object - maybe a
polygon - that is parallel with the ground.
2. By translating the object, its texture or the camera it should
produce a sprite suitable for use in an isometric video game.
3. The texture needs to repeat in such a way that when several of these
sprites are arranged next to each other, the transition will be seamless.
4. I want to use POV-Ray as much as possible instead of relying on
external tools.
What jpg are you talking about?
  but
> redundant.
Date: 1 Mar 2016 12:17:44
Message: <56d5ceb8$1@news.povray.org>
On 2/29/2016 10:49 AM, Bald Eagle wrote:
> http://www.mapeditor.org/    looked interesting if you're doing that kind of
> work.
I looked at this too, and I can't tell if it's capable of creating all
32 of the sprites stipulated in the first article I linked to. I think
it just creates a smaller subset of them.
Mike
Date: 1 Mar 2016 18:00:43
Message: <56d61f1b$1@news.povray.org>
>>> Mike
>> accomplish.
>> can be used
> scene.
> or Photoshop.
> A short recap:
> external tools.
>> tiles,
>   but
>> only 8
>> using 6, I
>> redundant.
>> it's on
An important first step would be to get POV-Ray to make a tiling texture {}.
Mike
Date: 1 Mar 2016 20:05:07
Message: <web.56d63bc03999a405e7df57c0@news.povray.org>
#version 3.7;
global_settings { assumed_gamma 1.0 }
// SDL for generating Isometric View Game Tiles
// Bill Walker - 2016
#include "debug.inc"
 Set_Debug (true)
#include "math.inc"
#include "rand.inc"
#include "shapes.inc"
#include "metals.inc"
#include "transforms.inc"
#declare XImageSize = 1024;
#declare YImageSize = 768;
light_source { <0, 50, 0>  color rgb <1, 1, 1>}
#declare Camera_Iso = camera {
                            location  <0, 0, -12>
                            //right    x*image_width/image_height
                            look_at   <0, 0, 0>
                            rotate x*30 rotate y*45 }
camera {Camera_Iso}
sky_sphere { pigment {Blue} }
#declare TileTexture =
pigment {cylindrical frequency 1 turbulence 0
         color_map {[0.0 color Green * 0.5]
            [0.3 color Green * 0.5]
            [0.8 color Yellow * 0.1]
                    [1.0 color Yellow * 0.1]
  }//end of color_map
} // end of pigment
#declare Scale = 3;
#declare TileBox = box { 0, 1 translate <-0.5, -0.5, -0.5> pigment {TileTexture}
scale <Scale, 0.01, Scale>}
#declare PlainBox = box { 0, 1 translate <-0.5, -0.5, -0.5>}
#declare Box1 = intersection {object {PlainBox translate <-1, 0,  1>} object
{TileBox}}
#declare Box2 = intersection {object {PlainBox translate < 0, 0,  1>} object
{TileBox}}
#declare Box3 = intersection {object {PlainBox translate < 1, 0,  1>} object
{TileBox}}
#declare Box4 = intersection {object {PlainBox translate <-1, 0,  0>} object
{TileBox}}
#declare Box5 = intersection {object {PlainBox translate < 0, 0,  0>} object
{TileBox}}
#declare Box6 = intersection {object {PlainBox translate < 1, 0,  0>} object
{TileBox}}
#declare Box7 = intersection {object {PlainBox translate <-1, 0, -1>} object
{TileBox}}
#declare Box8 = intersection {object {PlainBox translate < 0, 0, -1>} object
{TileBox}}
#declare Box9 = intersection {object {PlainBox translate < 1, 0, -1>} object
{TileBox}}
#declare Spacing = 0.1;
#local NrX = -1;     // start x
#local EndNrX = 2; // end   x
#while (NrX < EndNrX)
 #local NrZ = -1;     // start z
 #local EndNrZ = 1; // end   z
 #while (NrZ < EndNrZ)
  object{Box1 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box2 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box3 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box4 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box5 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box6 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box7 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box8 translate <Scale * NrX, 0, Scale * NrZ>}
  object{Box9 translate <Scale * NrX, 0, Scale * NrZ>}
  #local NrZ = NrZ + 1+Spacing;  // next Nr z
 #end // --------------- end of loop z
#declare NrX = NrX + 1+Spacing;  // next Nr x
#end // --------------- end of loop x
// 1,3,7,9
  object{Box3 translate <Scale * NrX-1, 0, Scale * NrZ>}
  object{Box7 translate <Scale * NrX, 0, Scale * NrZ+1>}
  object{Box9 translate <Scale * NrX-1, 0, Scale * NrZ+1>}
// 1,2,3,7,8,9
  object{Box1 translate <Scale * (NrX-2), 0, Scale * NrZ>}
  object{Box2 translate <Scale * (NrX-2), 0, Scale * NrZ>}
  object{Box3 translate <Scale * (NrX-2), 0, Scale * NrZ>}
  object{Box7 translate <Scale * (NrX-2), 0, Scale * NrZ+1>}
  object{Box8 translate <Scale * (NrX-2), 0, Scale * NrZ+1>}
  object{Box9 translate <Scale * (NrX-2), 0, Scale * NrZ+1>}
// 9, 7, 3, 1
  object{Box9 translate <Scale * (NrX-4), 0, Scale * NrZ+1>}
  object{Box7 translate <Scale * (NrX-3), 0, Scale * NrZ+1>}
  object{Box3 translate <Scale * (NrX-4), 0, Scale * NrZ>}
  object{Box1 translate <Scale * (NrX-3), 0, Scale * NrZ>}
Date: 1 Mar 2016 21:35:01
Message: <web.56d6506f3999a405e7df57c0@news.povray.org>
I even looked up how to get the background of the sprite to be transparent if
you need that:
Use the command-line option +ua
(good to know!   :)  )
http://news.povray.org/povray.newusers/message/%3C48a89167%40news.povray.org%3E/#%3C48a89167%40news.povray.org%3E
Date: 3 Mar 2016 00:43:19
Message: <56d7cef7$1@news.povray.org>
On 3/1/2016 8:02 PM, Bald Eagle wrote:
> #version 3.7;
>   Set_Debug (true)
> #include "math.inc"
> #include "rand.inc"
>                              look_at   <0, 0, 0>
> camera {Camera_Iso}
>    }//end of color_map
> } // end of pigment
> #declare Scale = 3;
> {TileBox}}
> {TileBox}}
> {TileBox}}
> {TileBox}}
> {TileBox}}
> {TileBox}}
> {TileBox}}
> {TileBox}}
> {TileBox}}
> // 1,3,7,9
> // 1,2,3,7,8,9
> // 9, 7, 3, 1
I don't understand. What am I looking at here?
Mike
Date: 3 Mar 2016 09:30:01
Message: <web.56d8499e3999a405e7df57c0@news.povray.org>
Continuous smoothly textured infinitely tessellating isometric tiles?
Replace the yellow and the green pigments with more complex textures, and that
seems PRETTY close to what you want.  Probably need to use orthographic camera
to get it exact.
