POV-Ray : Newsgroups : povray.general : Observation: Memory Increase During Render Server Time
19 May 2024 11:39:04 EDT (-0400)
  Observation: Memory Increase During Render (Message 11 to 16 of 16)
Subject: Re: Observation: Memory Increase During Render
Date: 10 Feb 2016 16:32:46
Message: <56bbac7e$1@news.povray.org>
On 2/10/2016 2:19 PM, clipka wrote:
> Am 10.02.2016 um 19:00 schrieb dick balaska:
>> povwin 3.7.1-alpha.8358383+av65.msvc14.win
>> I think you built it.
> To be precise, I didn't -- it was AppVeyor that did. All builds
> identifying as "+av<number>" are automated builds generated by that service.
> But yes, I did authorize the build and its distribution.
tomayto, tomahto.
> https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8463913%2Bav107
Running the same render set.
boot idle:
Mem Usage (KB) 16,028
VM Size (KB)    7,704
During first frame:
Mem Usage (KB) 190,400
VM Size (KB)   243,388
2nd:
Mem Usage (KB) 221,928
VM Size (KB)   273,868
3rd:
Mem Usage (KB) 253,004
VM Size (KB)   304,468
4th:
Mem Usage (KB) 286,372
VM Size (KB)   340,000
aborted render.  Hey, it gave back lots of memory then. Idling at:
Mem Usage (KB) 185,532
VM Size (KB)   197,652
Date: 10 Feb 2016 17:48:06
Message: <56bbbe26$1@news.povray.org>
Am 10.02.2016 um 22:32 schrieb dick balaska:
> boot idle:
> VM Size (KB)    7,704
> During first frame:
> 2nd:
> 3rd:
> 4th:
I presume you're currently giving it a more challenging test?
Date: 10 Feb 2016 19:12:12
Message: <56bbd1dc$1@news.povray.org>
Nah. I discovered an object position problem (I think related to my
constantly switching between 23.976 and 30 fps).  My renderfarm is
cranking a 2 week run and I didn't want to waste 12 hours of cpu time on
my fastest box. ;)
complete:1028 todo:2315     FPH:10.70  lastday:6.2   lasthour:7
ETC:9 days   (15 days, 13 days)
I had looked at some leak detectors a while back.  I should look
again... (In 1989 I paid $2K for Purify.  If we can get povwin running
on Windows 3.1, *that* will find all leaks)
dik
Date: 11 Feb 2016 19:53:25
Message: <56bd2d05$1@news.povray.org>
> my fastest box. ;)
> complete:1028 todo:2315     FPH:10.70  lastday:6.2   lasthour:7 ETC:9
> dik
It's a tool to detect memory leak in 16 bits applications running under
a 16 bits OS with 32 bits extention. Not sure if it can work for 32 bits
applications, and would be surprised if it can work at all for 64 bits ones.
Date: 25 Mar 2016 08:45:01
Message: <web.56f531d82b3b4bf7a10b12a00@news.povray.org>
I have seen this happen, but only occasionally. And I have a workaround.
Some while ago one of my images (I render at 2048x1536) crashed POV-Ray (XP,
intel quad core - yes, I know, I need to leave the stone age!) by eating up the
memory (gradual climb from 1.3 gb to 1.7 gb over 24 hours). It was a tree scene
so there were lots of objects. I subsequently discovered that by pausing the
render and going off to do something else on the very same machine the reported
memory usage dropped and then picked up again after restarting the render, but
at a much lower value, allowing the render to complete.
Is this the same problem, or something else again?
Date: 25 Mar 2016 11:01:16
Message: <56f552bc$1@news.povray.org>
Am 25.03.2016 um 13:43 schrieb Simon J. Cambridge:
That exactly matches the scenario I described.
