POV-Ray : Newsgroups : povray.general : 3D images Server Time
21 May 2024 06:19:27 EDT (-0400)
  3D images (Message 38 to 47 of 47)
Subject: Re: 3D images
Date: 13 Jan 2016 15:20:01
Message: <web.5696b0b077c0d9bd5d6ac23a0@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> Are there tutorials on how set up POV-Ray to make such images? I'm not
> using the look_at keyword in my camera statement. I am using up, right,
> and direction instead. How can I compensate for this?
I'm not sure if I'm replying to the right post, but anyway. If you have MegaPOV,
I wrote a macro to generate a cross-eye pair image in a single parse and render,
using the camera pigment feature. I've listed it below for interest - if you're
after a parallel pair you can just swap the sign of the CamX vectors in the
location statements of each pigment camera. I can't remember exactly but I think
you just set the macro parameters as if for a single view, call the macro
instead of making a camera, then use double the horizontal resolution for the
render size (I don't really run MegaPOV any more these days so I can't check
quickly).
It generates images like these:
http://news.povray.org/povray.binaries.images/thread/%3C4f0b6ac6@news.povray.org%3E/?ttop=374865&toff=50
If this isn't any use to you, never mind, maybe someone else will find it
interesting!
Bill
// Stereo pair camera macro
// needs megapov for camera view pigment
#version unofficial megapov 1.21;
#macro StereoPair(CPos, CLook, CAngle, CRight, CUp, BaseLine, Border)
 // camera coord system
 #local CamZ = vnormalize(CLook - CPos);
 #local CamX = vnormalize(vcross(CUp, CamZ));
 #local CamY = vnormalize(vcross(CamZ, CamX));
 // replacement camera
  location CPos
  up CUp
  right x*CRight
  angle CAngle
  look_at CLook
 // coordinates for mesh screen
 #local XDist = tan(radians(CAngle/2));
 #local YDist = XDist / CRight;
 #local LeftP1 = CPos + CamZ - XDist*CamX - YDist*CamY;
 #local LeftP2 = CPos + CamZ - YDist*CamY;
 #local LeftP3 = CPos + CamZ + YDist*CamY;
 #local LeftP4 = CPos + CamZ - XDist*CamX + YDist*CamY;
 #local RightP1 = CPos + CamZ - YDist*CamY;
 #local RightP2 = CPos + CamZ + XDist*CamX - YDist*CamY;
 #local RightP3= CPos + CamZ + XDist*CamX + YDist*CamY;
 #local RightP4 = CPos + CamZ + YDist*CamY;
 // mesh screen
 // left
 mesh {
 triangle { LeftP1, LeftP2, LeftP3 uv_vectors <0, 0>, <1, 0>, <1, 1> }
 triangle { LeftP1, LeftP3, LeftP4 uv_vectors <0, 0>, <1, 1>, <0, 1> }
  uv_mapping
   camera_view {
    location CPos + CamZ*1.1 + CamX*BaseLine/2
    up CUp
    right x*CRight/2
    angle CAngle/2
    look_at CLook }
  finish { ambient 1 }
 no_shadow
 no_reflection }
 // right
 mesh {
 triangle { RightP1, RightP2, RightP3 uv_vectors <0, 0>, <1, 0>, <1, 1> }
 triangle { RightP1, RightP3, RightP4 uv_vectors <0, 0>, <1, 1>, <0, 1> }
  uv_mapping
   camera_view {
    location CPos + CamZ*1.1 - CamX*BaseLine/2
    up CUp
    right x*CRight/2
    angle CAngle/2
    look_at CLook }
 no_shadow
 no_reflection }
 #local R = Border * vlength(RightP2 - LeftP1);
 union {
  cylinder { LeftP1, RightP2, R }
  cylinder { RightP2, RightP3, R }
  cylinder { RightP3, LeftP4, R }
  cylinder { LeftP4, LeftP1, R }
  cylinder { LeftP2, LeftP3, R/2 }
  pigment { rgb 0 }
  finish { ambient 0 diffuse 0 }
  no_shadow
  no_reflection
Date: 13 Jan 2016 15:29:03
Message: <5696b38f$1@news.povray.org>
I still don't understand what is the difference between a cross-eye pair
and a parallel pair? Also, which should I be making for the glasses I
ordered?
http://www.amazon.com/gp/product/B004EDB1S4?keywords=stereoscope&qid=1452568122&ref_=sr_1_90&sr=8-90
Date: 13 Jan 2016 15:45:01
Message: <web.5696b65077c0d9bd5d6ac23a0@news.povray.org>
> ordered?
A parallel pair is when you have the left eye image on the left, and the right
eye image on the right. If the separation is small, you can view these by
looking 'through' them and resolving the 'third' image in between to get the
stereo effect. This is what the viewing glasses use. This is also how dot
stereograms or 'magic eye' pictures work.
A cross-eye pair is swapped; the left eye image is on the right, and the right
eye image on the left. These can be viewed by looking 'in front of' them, by
going slightly cross-eyed to resolve the 'third' image in between to get the
stereo effect. This can be easier than the parallel method, and is not
restricted so much by image size / separation. I don't know if any devices exist
to help viewing these.
hope that helps!
Bill
Date: 14 Jan 2016 10:50:21
Message: <5697c3bd$1@news.povray.org>
>> ordered?
> hope that helps!
> Bill
For the cross eyed view, there are devices that do exist, but they are
bulkier and heavier as they rely on crossed periscope like setup.
They use 4 mirrors to swap the view points.
Date: 16 Jan 2016 00:56:35
Message: <5699db93@news.povray.org>
>> I just got done watching the new Star Wars movie in 3D. I kept the
>> glasses. How do I make images like that in POV-Ray?
>> Mike
> It seems, tonight I've all the answers...
> I use StereoPhotoMaker (free) to get *.jps files out of two left/right images (
> http://stereo.jpn.org/eng/stphmkr/index.html ).
> My LG TV-set understands this formate. The original images have to be squeezed
> first (look at binaries.images for an example).
> Norbert
That's a cool program. It doesn't support chromadepth glasses as far as
I can tell, though. Luckily I ordered anaglyph and standard
stereographic glasses as well.
Mike
Date: 16 Jan 2016 01:07:15
Message: <5699de13$1@news.povray.org>
>> Mike
> Norbert
Is there a particular image resolution, physical size, and aspect ratio
I should be aiming for when generating images in POV-Ray? Or will the
software automatically take care of issues regardless of how I render
the images?
Mike
Date: 16 Jan 2016 14:37:58
Message: <569a9c16$1@news.povray.org>
Am 16.01.2016 um 07:07 schrieb Mike Horvath:
> the images?
Image resolution: Ideally the same as the highest-resolution device you
intend to view it on -- unless the device you're most keen on viewing it
on doesn't support image scaling, in which case that's the resolution
you want to choose.
Physical image size: Ideally the same as the device you're most keen on
viewing it on.
Aspect ratio: Ideally the same as the device you're most keen on viewing
it on.
Whether "the software" on the target device will automatically take care
of issues entirely depends on "the software".
Date: 19 Jan 2016 13:29:01
Message: <569e806d@news.povray.org>
I've been shopping for a stereoscope that uses mirrors and works with
larger images. They are *really* expensive though. The cheapest ones are
over $100, and some are over $500. Yikes!
Mike
Date: 20 Jan 2016 08:21:18
Message: <569f89ce$1@news.povray.org>
Am 19.01.2016 um 19:28 schrieb Mike Horvath:
And people are whining about the price tag on the Oculus Rift CV1.
Date: 20 Jan 2016 16:36:11
Message: <569ffdcb$1@news.povray.org>
> Mike
You can make your own with some cardboard, glue and 4 mirrors. As for
the tools needed: Cisors, utility knife, glass cutter.
Home made mirror based steoscopes can cost very little, as low as a few
cents is you appen to have some small mirrors on hand.
