POV-Ray : Newsgroups : povray.general : Reading a colour on an object Server Time
17 Apr 2026 12:00:56 EDT (-0400)
  Reading a colour on an object (Message 1 to 8 of 8)
Subject: Reading a colour on an object
Date: 11 Nov 2014 10:36:25
Message: <54622cf9$1@news.povray.org>
I am suddenly not sure. Is it possible to read a colour at a defined
point - using trace() - on the surface of an object, by using
eval_pigment() at that point? I know how to do it with an image_map as
intermediary but can it be done directly?
For instance, if object{A} has a texture{B} and trace() finds a position
P=<x,y,z> on the surface of A, would the colour at P then be
D=eval_pigment(A,P) ? That obviously does not work as A is not a
pigment. However, I would like to do something like that but do not know
how.
Subject: Re: Reading a colour on an object
Date: 11 Nov 2014 11:49:54
Message: <op.xo56ddzdufxv4h@xena.home>
On Tue, 11 Nov 2014 17:36:22 +0200, Thomas de Groot <tho### [at] degrootorg>
> how.
> Thomas
It would be wonderful if it worked on uv-mapped meshes as well :)
-Nekar Xenos-
Date: 11 Nov 2014 12:05:01
Message: <web.5462417fa4f9ea0062d177fa0@news.povray.org>
> how.
> Thomas
Since Trace only returns the point of intersection and the normal vector, and
there's really no way to query object attributes, the best I'd think you could
do is pass the intersection Point and the pigment to eval_pigment...
Although... You might get more information from a function.   It's worth
investigating.
A.D.B.
Date: 11 Nov 2014 12:35:01
Message: <web.546247d7a4f9ea00ca410ea00@news.povray.org>
"Anthony D. Baye" <Sha### [at] spamnomorehotmailcom> wrote:
 > Thomas
> investigating.
> Regards,
> A.D.B.
That would be of help in very simple situations only. First the object must have
a pigment only and not a more complicated texture or worse an uv-mapping. Second
you must invert all transformations applied to the object after coloring it.
I can understand the wish by Thomas since one can e.g. plant grass of different
length at the object depending on the color - just a stupid idea. In fact I used
color maps, which can be evaluated with eval_pigment, sometimes to determine the
kind of vegetation in a landscape with a corresponding shape.
May be it is possible to implement it into the trace()-statement as a third
return value, but this issue and the effort necessary I cannot judge.
Best regards,
Michael
Date: 11 Nov 2014 17:30:01
Message: <web.54628cfea4f9ea005e7df57c0@news.povray.org>
I searched around a bit, but didn't seem to find much of use.
There was some mention of coupling trace with eval_pigment, but I didn't see any
code or elaboration on that idea...
What's an "object pigment"?
It seemed to be something along the lines of
pigment {object {Something} }
Is / was that some sort of experimental thing / MegaPov?
Maybe LeForgeron knows a way to do this - he's got a ton of clever stuff that he
works on...
POV-Ray obviously needs to work with just such information in order to generate
the rendered image.   I wonder if there's a way to patch into that, or write a
separate object property querying function...  y'know, for 4.0....
Date: 11 Nov 2014 19:13:15
Message: <5462a61b$1@news.povray.org>
> works on...
object pigment is a block pigment, in a way, similar to checker. It
demand 2 pigments or textures: The first to be used inside the reference
object, and the second to be used outside.
It's used on an object larger than the controll object.
A use would be to add some text to an object, that text been controled
by a text object. You can then use a warp to have that text warp around
some object.
Date: 12 Nov 2014 03:10:38
Message: <546315fe$1@news.povray.org>
>   > Thomas
>> investigating.
>> Regards,
>> A.D.B.
Yes, that is what I generally do too and it works fine. My question in
fact derives from that usage and a solution would be a smart addition
but I am afraid it is not really possible.
Yes, that would be the logical thing indeed.
Date: 15 Nov 2014 21:12:19
Message: <54680803$1@news.povray.org>
>> third
it's not quite the same thing, but the camera_view pigment
in MegaPOV might help in some cases.
