POV-Ray : Newsgroups : povray.general : Batch/command-line render in Windows Server Time
29 Jul 2024 06:18:17 EDT (-0400)
  Batch/command-line render in Windows (Message 1 to 10 of 24)
Subject: Batch/command-line render in Windows
Date: 15 Mar 2013 13:19:29
Message: <51435821$1@news.povray.org>
As far as I can tell, the Windows version of POV-ray comes only with a GUI.
What do I need to do to get a command-line-compatible renderer?
Subject: Re: Batch/command-line render in Windows
Date: 15 Mar 2013 13:59:25
Message: <5143617d$1@news.povray.org>
I don't use windows version so maybe this isn't relevant:
http://wiki.povray.org/content/Documentation:Windows_Section_3#Special_Command-Line_Options
and doing google search for: batch/command line render AND POV-Ray AND
Windows
I found this:
http://stackoverflow.com/questions/2207472/povray-for-windows-using-the-command-line-to-render-several-pov-files
Date: 15 Mar 2013 15:03:16
Message: <51437074$1@news.povray.org>
>> GUI.
> Windows
> I found this:
Well, neither of those turn the GUI off. All of them open a POV-ray
editor window, do the render (visibly!) and then exit.
This way, rendering a hundred images requires me to either run 100 GUI
instances, or run them one after the other. In both cases, my computer
is completely unusable for quite some time while windows keep popping up.
Timwi
Date: 15 Mar 2013 15:54:43
Message: <51437c83$1@news.povray.org>
>>> GUI.
>> Windows
>> I found this:
> Timwi
well what does /RENDER do when using -D
Date: 15 Mar 2013 16:49:15
Message: <5143894b$1@news.povray.org>
-D all this time.
Date: 15 Mar 2013 17:05:01
Message: <web.51438c1969ab0bc478641e0c0@news.povray.org>
I used batch files like this for Windows batch renders:
________________________________________________________________________________
setlocal
set PATH=%PATH%;"C:\Users\Ricky Callwood\AppData\Local\Programs\POV-Ray\3.7\bin"
start /w /min pvengine-sse2 /nr /exit +imyscenefile1.pov
start /w /min pvengine-sse2 /nr /exit +imyscenefile2.pov
start /w /min pvengine-sse2 /nr /exit +imyscenefile3.pov
start /w /min pvengine-sse2 /nr /exit 'myinifile[section1]'
start /w /min pvengine-sse2 /nr /exit 'myinifile[section2]'
start /w /min pvengine-sse2 /nr /exit 'myinifile[section3]'
endlocal
The splash screen still showed, but it worked.  (Annoying, yes, but the POV team
has its reasons for insisting on the splash screen.)  You would set the PATH to
whatever is appropriate for your system.
Note that I used the /nr switch to keep it from wasting time loading the editor
windows.  If you don't want to lose your editor windows, you must keep one GUI
session open during the batch run and set Options | Keep Single Instance to OFF.
Date: 15 Mar 2013 17:30:15
Message: <514392e7@news.povray.org>
Am 15.03.2013 20:03, schrieb Timwi:
>>> GUI.
>> Windows
>> I found this:
There are various reasons for this, one being a series of "copyleft
infringements": At some time various people thought it was ok to sell
commercial software that deliberately hid the fact that the actual
rendering was done with POV-Ray; at that point, it was decided to have
the Windows version always fire up the GUI. (At least that's what I've
heard tell.)
There actually still exists an old Windows command-line version of
POV-Ray, but it has not been maintained for quite.
The last word hasn't been spoken on this issue though, and chances are
the command-line-only version will see a revival.
Date: 16 Mar 2013 11:55:08
Message: <514495dc$1@news.povray.org>
> heard tell.)
Surely the correct response to that is to sue the perpetrator, not to
massively inconvenience all Windows users...
Timwi
Date: 16 Mar 2013 13:28:01
Message: <5144aba1$1@news.povray.org>
Am 16.03.2013 16:55, schrieb Timwi:
>>> up.
>> heard tell.)
Lawsuits were filed, as a matter of fact - but law is slow to take
effect, and it didn't help that the copyleft concept was still
comparatively new back then. (Not to mention that quite a lot of money
had to be thrown at those lawsuits to fight them through; AFAIK the last
of them was still ongoing at the end of the POV-Ray 3.7 beta phase, and
one of the problems slowing down 3.7 development in those days was that
Thorsten was working hard to make the necessary money to keep those
lawsuits running.)
As for "massively" inconveniencing "all" Windows users: Most Windows
users have been happy to run their renders from within the GUI, and
Windows never really made batch processing easy anyway, so people
requiring batch processing would typically turn towards Linux in the
first place.
Times are changing, and judging past decisions based on today's
circumstances is cheap, and moot besides if the decision is already
being revised. As I said, we're likely to see a revival of the
command-line-only POV-Ray version for Windows.
Date: 16 Mar 2013 14:24:33
Message: <5144b8e1$1@news.povray.org>
>>>> up.
>>> heard tell.)
> lawsuits running.)
> first place.
Of course, there is also the "alternative", which is to have the GUI,
but allow for a "batch" processing queue. I could see a case where even
working on something in the GUI could either branch a new instance, to
run a quick test render, while the queue is still running, or insert it
as "next in line" (possibly less useful, given the render times involved
in many cases). This would, in effect, not only allow work with it was
doing other things, if needed, but also provide a clear list of what was
"up and coming", which a person could halt, edit, rearrange, etc. None
of which is exactly plausible using a pure "batch from command line"
solution.
