POV-Ray : Newsgroups : povray.general : subsurface and normals Server Time
24 Aug 2025 09:50:12 EDT (-0400)
  subsurface and normals (Message 1 to 5 of 5)
Subject: subsurface and normals
Date: 22 Sep 2012 16:16:53
Message: <505e1cb5@news.povray.org>
I tried the subsurface feature for the first time (RC6) and noticed
that normals no longer seemed to have a visible effect on lighting, e.g.
testing with an object such as
sphere
   y,1
   pigment {color White}
   normal  {bozo 100 scale 0.2}
   // finish  {subsurface {translucency 0.2}}
Is this a known limitation? If so it should probably be documented
in the warning section of the subsurface reference.
Also, if I understand correctly SSLT completely replaces the lighting
model. I would have found it to be more intuitive if it were just some
additional effect (similar to a reflection block, at least without
conserve_energy). Possibly by defaulting the SSLT contribution with
a diffuse of 0 unless an explicit diffuse appears in the subsurface
block (in which case it would be physically correct, but optional, to
use diffuse 0 for the old model. Not sure if this is feasible, though.
Subject: Re: subsurface and normals
Date: 22 Sep 2012 19:23:22
Message: <505e486a$1@news.povray.org>
Am 22.09.2012 22:16, schrieb Christian Froeschlin:
> sphere
>    y,1
I never paid attention to this before, but you're right: Currently the
algorithm doesn't properly respect perturbed normals. The reason is that
this would require extra effort (both in terms of speed, but also and
especially in terms of programming) to handle averaged and layered
textures. There'll come a time to dig into this, but not yet.
 From the math behind SSLT, there is no such thing as an "SSLT
contribution" - the formulae totally /replace/ the conventional diffuse
term.
To obtain a pure SSLT-to-diffuse "delta" image, you could render the
scene once with only regular diffuse, and once with SSLT enabled, and
from the resulting images generate a difference. (Note though that
SSLT's light "bleeding" feature does not only brighten up dark areas,
but also darken bright ones in turn; so the delta may be negative, and
therefore OpenEXR is highly recommended as file format of choice.)
Date: 23 Sep 2012 14:45:09
Message: <505f58b5$1@news.povray.org>
Instead, I tried to average a plain texture with normals and
the subsurface texture, but the results are not very convincing.
Probably because small bumps on the surface are the features that
should be most affected by subsurface lighting.
Isosurface it is, then ;) (see p.b.i)
Some additional problems I encountered:
1. I tried to set "mm_per_unit 100" in the global settings block,
but this yielded the parse error "Parse Error: No matching } in
'subsurface', mm_per_unit found instead".
2. I had trouble with the help in the windows editor:
- Pressing F1 only seems to work for some types of keywords (for
example, I could use it to get help for camera or subsurface, but not
for location, aperture, samples, or global_settings).
- Also, when the topic was not unique (e.g. camera), and the help
was not previously open, the topic selector did not close on display
or double click and moved to the background. In this situation the
the search/replace dialog will not open.
Date: 23 Sep 2012 18:31:44
Message: <505f8dd0$1@news.povray.org>
Am 23.09.2012 20:45, schrieb Christian Froeschlin:
Note that mm_per_unit is /not/ a subsurface parameter; although SSLT is
currently the only feature using it, other features might follow
somewhen in the future.
I do remember that we did have some known issues with the online help
index, but I can't recall off the top of my head whether that was in RC5
or RC6. Jim is more familiar with the current status.
Date: 24 Sep 2012 06:12:23
Message: <50603207$1@news.povray.org>
thanks, that explains it ;)
