POV-Ray : Newsgroups : povray.general : FixedSimpleVector internal limit exceeded? Server Time
29 Jul 2024 12:26:48 EDT (-0400)
  FixedSimpleVector internal limit exceeded? (Message 1 to 6 of 6)
Subject: FixedSimpleVector internal limit exceeded?
Date: 1 Nov 2011 13:15:00
Message: <web.4eb028a372b9c89577e50e540@news.povray.org>
I keep getting this error:
Internal limit exceeded in FixedSimpleVector
Fatal error in renderer: A POV-Ray internal nesting limit was reached.
Render failed
What does this mean?
I am using a loop containing a lightsource in a loop with media.
I can post the file if needed.
Ian
Subject: Re: FixedSimpleVector internal limit exceeded?
Date: 1 Nov 2011 13:20:01
Message: <web.4eb02972dc17694377e50e540@news.povray.org>
Ok, a bit more information...If i just render the scene normally, no issue. But
when I select a subregion, I get the error. I'm not sure, but this sounds like a
bug.
Ian
Date: 1 Nov 2011 13:37:59
Message: <4eb02e77$1@news.povray.org>
You've hit a hard-coded internal limit within POV-Ray. This limit is
there as a trade-off between performance, memory use and flexibility.
I don't like it but it's difficult to fix without impacting rendering
speed.
The error message itself should be fairly self-explanatory, though I
think we might need to add a reference to a doc page that makes the
issue clearer (in terms of what you can do about it).
See also
http://news.povray.org/povray.beta-test/thread/%3Cweb.4d18ce518224b54c231f2b0b0@news.povray.org%3E/
Date: 1 Nov 2011 14:20:01
Message: <web.4eb037ebdc17694377e50e540@news.povray.org>
> speed.
Gotcha. As a developer, I can relate to how those things go sometimes.
It is, in that it effectively relates that a limit has been reached, which is
just about all its supposed to do. I agree that a docpage reference would be
nice.
Thanks for the info!
Ian
Date: 1 Nov 2011 14:55:01
Message: <web.4eb04001dc17694377e50e540@news.povray.org>
Although, it is unexpected that simply changing the number of decimal points I'm
dividing the size of a sphere by would be enough to also trigger this message.
(glowRadius / ((j * j) * 0.01))   //no error
(glowRadius / ((j * j) * 0.0001)) //error
Ian
Date: 2 Nov 2011 01:46:44
Message: <4eb0d944$1@news.povray.org>
> speed.
> See also
Added a note and link (2nd paragraph) of the Light Sources section:
http://wiki.povray.org/content/Documentation:Reference_Section_4.3#Light_Sources
