POV-Ray : Newsgroups : povray.general : shear matrix problem Server Time
26 Nov 2024 05:28:01 EST (-0500)
  shear matrix problem (Message 1 to 10 of 12)
Subject: shear matrix problem
Date: 13 Jul 2011 08:21:28
Message: <4e1d8dc8$1@news.povray.org>
I confess that I do not really understand the working of a matrix.
Consider the following piece of code:
//start code
#declare P1 = <-1.6, 0.0, 0>;
#declare P2 = < 1.6, 0.8,  0>;
#local Point =
sphere {
   <0,0,0>, 0.05
object {Point translate P1  pigment {rgb <1,0,0>}}
object {Point translate P2  pigment {rgb <1,1,0>}}
#declare Segment =
box {<-0.10, 0.00, -0.010>, <0.00, 1.00, 0.010>}
#local a = 0;
#local b = VDist(P1,P2);
union {
   #while (a <= b)
     object {Segment
       translate <0, a, 0>
       #if (even(a))
         pigment {rgb <0,1,0>}
       #else
         pigment {rgb <0,0,1>}
       #local a=a+1;
   clipped_by {plane {y, b}}
   matrix <1, (P1.y-P2.y), 0, // matrix-shear_x_to_y
           0, 1, 0,
           0, 0, 1,
           0, 0, 0>
   Point_At_Trans(P2-P1)
   translate P1
//end code
What I want is that the short sides of the Segment always remain
vertical whatever the positions of P1 or P2. What am I doing wrong?
Thanks for any help,
Subject: Re: shear matrix problem
Date: 13 Jul 2011 10:35:01
Message: <web.4e1dad017fd51405257ce790@news.povray.org>
I'm not quite sure what you are doing, so i can't tell you what you are doing
wrong.
My guess is, that you need to transpose the upper 3x3 portion of your matrix,
that is, use
matrix <1, 0, 0,
       (P1.y-P2.y), 1, 0,
       0, 0, 1,
       0, 0, 0>
instead.
You could also try the Shear_Trans() and/or Matrix_Trans() macros in
transforms.inc instead, which are probably easier to use.
Regards Roman
> //start code
> #local Point =
> sphere {
>    <0,0,0>, 0.05
> #declare Segment =
> #local a = 0;
> union {
>    #while (a <= b)
>      object {Segment
>        translate <0, a, 0>
>        #if (even(a))
>        #else
>        #end
>        #local a=a+1;
>    #end
>            0, 1, 0,
>            0, 0, 1,
>            0, 0, 0>
>    translate P1
> //end code
> Thomas
Date: 13 Jul 2011 17:10:00
Message: <web.4e1e08c27fd514019787f110@news.povray.org>
> Thomas
Did you see the new winpov insert menu/Transformation/matrix_shear...
examples with pictures.
Do these help?
Stephen S
Date: 14 Jul 2011 02:58:11
Message: <4e1e9383@news.povray.org>
>> Thomas
> Do these help?
> Stephen S
Yes, that is basically where my matrix is coming from:
      matrix<1, 0.5, 0, // matrix-shear_x_to_y
             0,  1,  0,
             0,  0,  1,
             0,  0,  0>
The difficulty is that, not only the object at P1 needs to point_at P2,
which is not difficult to do, but also has to be sheared in such a way
that the short sides remain vertical.
Maybe I am making a wrong assumption somewhere....
THomas
Date: 14 Jul 2011 03:42:12
Message: <4e1e9dd4$1@news.povray.org>
No, the matrix is correct for shearing vertically, which is my
intention, like from the Insert Menu:
   matrix <1, 0.5, 0, // matrix-shear_x_to_y
           0,  1,  0,
           0,  0,  1,
           0,  0,  0>
Where I am going wrong, I guess is by using Point_At_Trans(), instead of
Reorient_Trans(). Still, I am not out of the wood :-(
I rewrote my code accordingly and I am sure it is the 0.5 in the matrix
that should be replaced by a variable based on P1 and P2, but I am
really at a loss what that should be.
Try this new code which is more towards what I intend to do:
//Start Code
#local P1 = <-1.6, 0.1, 0>;
#local P2 = < 1.7, 1.5, 0>;
#local Point =
sphere {
   <0,0,0>, 0.05
object {Point}
#local Segment =
box {<0.00, 0.00, -0.010>, <1.00, 0.10, 0.010>}
#local a = 0;
union {
   #while (a < b)
     object {Segment
       translate <a, 0, 0>
       #if (even(a))
       #else
       #local a=a+1;
   clipped_by {plane {x, b}}
           0,  1,  0,
           0,  0,  1,
           0,  0,  0>
   Reorient_Trans (<P1.x,0,P1.z>, <-P2.x, 0, -P2.z>)
   translate P1
//End Code
If you increase or decrease the 0.5 value, you will see the shearing
increasing or decreasing, while the short sides remain vertical like I
want. Only, now the problem is to keep the object's far end at the P2
The info about Shear_Trans() and Matrix_Trans() is so succinct (for me)
that I cannot do anything with it. My math knowledge is clearly to low
for this.
> wrong.
> that is, use
> matrix<1, 0, 0,
>         (P1.y-P2.y), 1, 0,
>         0, 0, 1,
>         0, 0, 0>
> instead.
> Regards Roman
Date: 14 Jul 2011 04:55:00
Message: <web.4e1eaeba7fd51405257ce790@news.povray.org>
Like this?
//Start Code
#local Point =
sphere {
   <0,0,0>, 0.05
   pigment { rgb 1 }
object {Point}
#local Segment =
#declare d = P2-P1;
#local a = 0;
#local b = d.x;
union {
   #while (a < b)
     object {Segment
       translate <a, 0, 0>
       #if (mod(a,2)=0)
       #else
       #local a=a+1;
   matrix <d.x/b,  d.y/b,  0, // matrix-shear_x_to_y
           0,  1,  0,
           0,  0,  1,
           0,  0,  0>
   translate P1
//End Code
Date: 14 Jul 2011 05:10:01
Message: <web.4e1eb1907fd51405257ce790@news.povray.org>
BTW, i killed that Reorient_Trans since it does nothing. As P1.z and P2.z are
zero those two: <P1.x,0,P1.z>, <-P2.x, 0, -P2.z> are parallel (pointing in
opposite directions) resulting in the Reorient_Trans macro to return an empty
transform.
Regards Roman
Date: 14 Jul 2011 07:20:30
Message: <4e1ed0fe$1@news.povray.org>
> zero those two:<P1.x,0,P1.z>,<-P2.x, 0, -P2.z>  are parallel (pointing in
> transform.
> Regards Roman
Yes, that works, but only because z remains 0 in your code. That is why
I am not too sure about not using VDist(). The Reorient_Trans() is
necessary for those cases where P2 (and/or P1) moves also along the
z-axis. Or is there another way? The code should be valid for *all* 3D
locations of P1 and P2.
Date: 14 Jul 2011 08:10:00
Message: <web.4e1edc227fd51405257ce790@news.povray.org>
In that case it should read Reorient_Trans(<1,0,0>, <d.x, 0, d.z>) where d is,
again, P2-P1.
Also b = d.x needs to be replaced with b = vlength(<d.x, 0, d.z>).
Altogether:
//Start Code
#local P1 = <-1.6, 0.1, -.5>;
#local P2 = < 1.7, 1.5, 1>;
#local Point =
sphere {
   <0,0,0>, 0.05
   pigment { rgb 1 }
object {Point}
#local Segment =
#declare d = P2-P1;
#local a = 0;
#local b = vlength(<d.x, 0, d.z>);
union {
   #while (a < b)
     object {Segment
       translate <a, 0, 0>
       #if (mod(a,2)=0)
       #else
       #local a=a+1;
   matrix <1  d.y/b,  0,
           0,  1,  0,
           0,  0,  1,
           0,  0,  0>
   Reorient_Trans(x, d*(1-y)) //short for Reorient_Trans(<1,0,0>, <d.x, 0, d.z>)
   translate P1
//End Code
[Note, that the above version shears the segments by dragging the far end up
resulting in the originally unit length segments to get longer. If you want them
to remain at unit length you need to use
   clipped_by {plane {x, vlength(d)}}
   matrix <b/vlength(d)  d.y/vlength(d),  0,
           0,  1,  0,
           0,  0,  1,
           0,  0,  0>
instead.]
Feel free to ask if you need any explanations!
Regards Roman
> Thomas
Date: 14 Jul 2011 10:22:42
Message: <4e1efbb2@news.povray.org>
Thank you Roman, for your help! This works fine.
One question: you use vlength() instead of VDist() and seem not to take
into account the y-component. However, it seems to me that between P1
and P2 the y-component can potentially be of importance especially if
height differences are large. Would that not be compensated by VDist()?
Or vlength(d)?
On 14-7-2011 14:08, Roman Reiner wrote:
> In that case it should read Reorient_Trans(<1,0,0>,<d.x, 0, d.z>) where d is,
> again, P2-P1.
> Altogether:
> //Start Code
> #local P1 =<-1.6, 0.1, -.5>;
> #local P2 =<  1.7, 1.5, 1>;
> #local Point =
> sphere {
>     <0,0,0>, 0.05
>     pigment { rgb 1 }
> object {Point}
> object {Point translate P1  pigment {rgb<1,0,0>}}
> object {Point translate P2  pigment {rgb<1,1,0>}}
> #local Segment =
> box {<0.00, 0.00, -0.010>,<1.00, 0.10, 0.010>}
> #declare d = P2-P1;
> #local a = 0;
> union {
>     #while (a<  b)
>       object {Segment
>         translate<a, 0, 0>
>         #if (mod(a,2)=0)
>           pigment {rgb<0,1,0>}
>         #else
>           pigment {rgb<0,0,1>}
>         #end
>         #local a=a+1;
>     #end
>     matrix<1  d.y/b,  0,
>             0,  1,  0,
>             0,  0,  1,
>             0,  0,  0>
>     Reorient_Trans(x, d*(1-y)) //short for Reorient_Trans(<1,0,0>,<d.x, 0, d.z>)
>     translate P1
> //End Code
>     matrix<b/vlength(d)  d.y/vlength(d),  0,
>             0,  1,  0,
>             0,  0,  1,
>             0,  0,  0>
> instead.]
> Regards Roman
