POV-Ray : Newsgroups : povray.general : projected_through Test. Server Time
11 Apr 2026 00:02:02 EDT (-0400)
  projected_through Test. (Message 1 to 6 of 6)
Subject: projected_through Test.
Date: 17 Feb 2011 08:22:53
Message: <4d5d212d$1@news.povray.org>
projected_through only seems to work when the light source is below the
projected_through object. And the light is projected on the ceiling.
Also if the light source is close in height to the object and to the
side, the light is projected vertically upward and not through the object.
This happens in Pov-Ray 3.5, 3.6 and RC3.
I would appreciate it if someone would either confirm that this is
Regards
Subject: Re: projected_through Test.
Date: 17 Feb 2011 10:27:47
Message: <4d5d3e73$1@news.povray.org>
On 17/02/2011 1:22 PM, Stephen wrote:
Well it looks to me as if a point light projects a vertical cone with a
half angle of 30 degrees that will interact with the projected_through
object. If you rotate the light then the cone of interaction rotates too.
Is this by design?
Regards
Date: 17 Feb 2011 10:30:36
Message: <4d5d3f1c$1@news.povray.org>
Am 17.02.2011 14:22, schrieb Stephen:
It's pretty simple: The projected_through object "sticks" to the light
source when it is translated around.
So if you want to know where your projected_through object /really/ is,
you'll need to use
#declare Target = box {...}
union {
   light_source {
     projected_through { Target }
   object { Target no_shadow }
(Also note the no_shadow flag on the target.)
As another note: Are you sure projected_through really does what you
think it does? I'm still wondering what you intend to use it for in your
lamp scene.
Date: 17 Feb 2011 11:11:53
Message: <4d5d48c9$1@news.povray.org>
> you'll need to use
> union {
> light_source {
Thanks, Christoph. I knew I was doing something wrong.
Are you sure about the no_shadow flag? I'm sure I read that it was implicit.
> lamp scene.
Thanks, I know it won't do what I'd like it to do but I just wanted to
get it working and understand it.
Regards
Date: 17 Feb 2011 19:14:13
Message: <4d5db9d5$1@news.povray.org>
Am 17.02.2011 17:11, schrieb Stephen:
>> you'll need to use
>> union {
>> light_source {
> implicit.
Not if you also add the object to the scene, as in the sample above. It
/may/ be reduntant there as well, but I'd prefer not to rely on it. (At
any rate it speeds up rendering, if only by a few nanoseconds ;-))
Date: 18 Feb 2011 11:41:50
Message: <4d5ea14e$1@news.povray.org>
>> implicit.
:-D
Regards
