![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Shouldn't you be able to specify a default finish that would apply to
each entry of a texture map ... I have a texture map that has almost a
dozen entries, but only want to tweak a couple of the entries. The rest
I want to make ALL the same finish. Default finish .... right? No syntax
errors ... just not working as I'd expect :-(
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, each object automatically uses the default texture unless you override it
(or some part of it, e.g., the finish) in your object declaration.
Try declaring a named finish and use that as the finish in any texture map
entries that should use default and see if that works as expected.
www.McGregorFineArt.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
at your suggestion I went through a little exercise of what works and
what wasn't and discovered a self inflicted wound ... don't you just
hate it when that happens (goes quietly back into the corner and cleans
up sloppy code)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 16/02/2011 6:36 PM, Jim Holsenback wrote:
> don't you just
> up sloppy code)
Oh! Yes! ;-)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d5c2177$1@news.povray.org...
>> don't you just
>> up sloppy code)
> Oh! Yes! ;-)
<sigh> indeed...;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
