POV-Ray : Newsgroups : povray.general : texture map question Server Time
11 Apr 2026 00:02:06 EDT (-0400)
  texture map question (Message 1 to 5 of 5)
Subject: texture map question
Date: 16 Feb 2011 12:26:49
Message: <4d5c08d9@news.povray.org>
Shouldn't you be able to specify a default finish that would apply to
each entry of a texture map ...  I have a texture map that has almost a
dozen entries, but only want to tweak a couple of the entries. The rest
I want to make ALL the same finish. Default finish .... right? No syntax
errors ... just not working as I'd expect :-(
Subject: Re: texture map question
Date: 16 Feb 2011 13:00:01
Message: <web.4d5c107db37da10c94d713cc0@news.povray.org>
Yes, each object automatically uses the default texture unless you override it
(or some part of it, e.g., the finish) in your object declaration.
Try declaring a named finish and use that as the finish in any texture map
entries that should use default and see if that works as expected.
www.McGregorFineArt.com
Date: 16 Feb 2011 13:36:14
Message: <4d5c191e$1@news.povray.org>
at your suggestion I went through a little exercise of what works and
what wasn't and discovered a self inflicted wound ... don't you just
hate it when that happens (goes quietly back into the corner and cleans
up sloppy code)
Date: 16 Feb 2011 14:11:51
Message: <4d5c2177$1@news.povray.org>
On 16/02/2011 6:36 PM, Jim Holsenback wrote:
> don't you just
> up sloppy code)
Oh! Yes! ;-)
Regards
Date: 17 Feb 2011 03:11:58
Message: <4d5cd84e@news.povray.org>
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d5c2177$1@news.povray.org...
>> don't you just
>> up sloppy code)
> Oh! Yes! ;-)
<sigh> indeed...;-)
