POV-Ray : Newsgroups : povray.general : Converter into Meshes Server Time
25 Aug 2025 19:04:27 EDT (-0400)
  Converter into Meshes (Message 1 to 9 of 9)
Subject: Converter into Meshes
Date: 24 Sep 2010 10:41:24
Message: <4c9cb894$1@news.povray.org>
Hi.
What are the best recommendable converters from POV-Ray scene files into
meshes used by file formats such as .3ds and .dxf?
Subject: Re: Converter into Meshes
Date: 24 Sep 2010 12:05:01
Message: <web.4c9ccbcb3204270a5d9443650@news.povray.org>
"Sven Littkowski" <Sve### [at] Jamaica-Focuscom> wrote:
> Hi.
dream on...
Date: 24 Sep 2010 12:16:44
Message: <4c9cceec@news.povray.org>
Not really, and not at all. There are modellers out there, like Bishop3D,
which can read the POV-Ray scene files. The step to convert a file which was
successfully read, to a 3D mesh, shouldn't be that big.
A decade ago, Crossroads did it already.It read POV-Ray scene files and
converted them into .3ds or .dxf files. My problem is only, I can't find the
program Crossroads 3D now.
If anyone has a copy of the free Crossroads 3D? Or links to other
converters?
Date: 24 Sep 2010 12:34:09
Message: <4c9cd301$1@news.povray.org>
On 24/09/2010 5:03 PM, nemesis wrote:
> "Sven Littkowski"<Sve### [at] Jamaica-Focuscom>  wrote:
>> Hi.
> dream on...
them in other formats. It is not free but less than 30 Euros.
Best Regards,
Date: 24 Sep 2010 19:10:01
Message: <web.4c9d2f623204270ab92da8ee0@news.povray.org>
> converters?
this seems to be a working link to Crossroads 3D:
http://www.free2u.org/freeware/graphics/3d_graphics/crossroads_3d.html
Cheers,
Simone
Date: 24 Sep 2010 19:15:17
Message: <4c9d3105@news.povray.org>
Thanks, Simone. I found it, and I used it. Still, my scene doesn't show up
within Crossroads 3D, despite that it has been imported without problem.
Can you try and find out, what's wrong?
Here's the entire schene, no additional INCLUDE file is required. Thanks a
lot!
Sven
// Persistence Of Vision raytracer version 2.2 sample file.
 location < 0.0, 23.0, -50.0 >
 look_at < 0.0, 2.70, 0.0 >
light_source { < 1000.0, 2000.0, 1000.0 > rgb < 1.0, 1.0, 1.0 > }
#declare HeightOfBlades= 12.2
#declare AngleOfWindCatchers_360= < 0.0, 0.0, 0.0 >
#declare Fundament=texture { pigment { rgb < 0.4, 0.2, 0.1 > } finish {
specular 1 roughness 0.0001 reflection 0.13 } }
#declare Building=texture { pigment { rgb < 1.0, 1.0, 1.0 > } finish {
#declare EntranceDoor=texture { pigment { rgb < 0.8, 0.4, 0.0 > } finish {
#declare StairsSection=texture { pigment { rgb < 1.0, 1.0, 1.0 > } finish
{ specular 1 roughness 0.0001 reflection 0.13 } }
#declare WindBlades=texture { pigment { rgb < 0.7, 0.7, 1.0 > } finish {
#declare WindBladesDrives=texture { pigment { rgb < 0.0, 0.0, 0.0 > } finish
#declare WindCatchers=texture { pigment { rgb < 1.0, 1.0, 0.7 > } finish {
#declare WindCatcherFixtures=texture { pigment { rgb < 0.0, 0.5, 0.0 > }
finish { specular 1 roughness 0.0001 reflection 0.13 } }
#declare RoofPlatform=texture { pigment { rgb < 1.0, 1.0, 1.0 > } finish {
#declare RoofDoor=texture { pigment { rgb < 0.5, 0.0, 0.0 > } finish {
#declare RoofReeling=texture { pigment { rgb < 1.0, 1.0, 0.0 > } finish {
#declare Base=object
 union
  cylinder { < 0.0, -2.0, 0.0 > < 0.0, 0.0, 0.0 > 7.5 texture {
Fundament } }
  cylinder { < 0.0, 0.0, 0.0 > < 0.0, 2.8, 0.0 > 5.0 texture { Building } }
  box { < -0.5, 0.0, -5.05 > < 0.5, 2.2, 0.0 > rotate < 0.0, 040.0, 0.0 >
texture { EntranceDoor } }
#declare Stairs=object
 cylinder { < 0.0, 2.8, 0.0 > < 0.0, (2.8+HeightOfBlades), 0.0 > 1.9 texture
{ StairsSection } }
#declare Blade=object
 difference
  cylinder { < 0.0, 0.0, 0.0 > < 0.0, HeightOfBlades, 0.0 > 3.0 }
  cylinder { < 1.1, -0.01, 0.0 > < 1.1, (HeightOfBlades+0.01), 0.0 > 4.0 }
 translate < 2.8, 2.8, 0.0 >
 rotate < 0.0, 75.0, 0.0 >
 translate < -3.5, 0.0, 0.0 >
 texture { WindBlades }
#declare Turbine=object
 union
  object { Blade rotate < 0.0, 000.0, 0.0 > }
  object { Blade rotate < 0.0, 036.0, 0.0 > }
  object { Blade rotate < 0.0, 072.0, 0.0 > }
  object { Blade rotate < 0.0, 108.0, 0.0 > }
  object { Blade rotate < 0.0, 144.0, 0.0 > }
  object { Blade rotate < 0.0, 180.0, 0.0 > }
  object { Blade rotate < 0.0, 216.0, 0.0 > }
  object { Blade rotate < 0.0, 252.0, 0.0 > }
  object { Blade rotate < 0.0, 288.0, 0.0 > }
  object { Blade rotate < 0.0, 324.0, 0.0 > }
  torus { 4.50, 0.05 translate < 0.0, 2.8, 0.0 > texture {
WindBladesDrives } }
  torus { 2.75, 0.05 translate < 0.0, 2.8, 0.0 > texture {
  torus { 4.50, 0.05 translate < 0.0, (2.8+HeightOfBlades), 0.0 > texture
{ WindBladesDrives } }
  torus { 2.75, 0.05 translate < 0.0, (2.8+HeightOfBlades), 0.0 > texture
#declare WindCatcher=object
 union
  torus { 5.0, 0.1 translate < 0.0, 2.8, 0.0 > texture {
WindCatcherFixtures } }
  torus { 5.5, 0.1 translate < 0.0, 2.8, 0.0 > texture {
  torus { 5.0, 0.1 translate < 0.0, (2.8+HeightOfBlades), 0.0 > texture {
  torus { 5.5, 0.1 translate < 0.0, (2.8+HeightOfBlades), 0.0 > texture {
  box { < 5.0, 2.8, -0.05 > < 12.5, (2.8+HeightOfBlades), 0.05 > rotate <
0.0, 000.0, 0.0 > texture { WindCatchers } }
0.0, 120.0, 0.0 > texture { WindCatchers } }
0.0, 240.0, 0.0 > texture { WindCatchers } }
  cylinder { < -5.5, 2.8, 0.0 > < -5.0, 2.8, 0.0 > 0.1 rotate < 0.0, 000.0,
0.0 > texture { WindCatcherFixtures } }
  cylinder { < -5.5, 2.8, 0.0 > < -5.0, 2.8, 0.0 > 0.1 rotate < 0.0, 120.0,
  cylinder { < -5.5, 2.8, 0.0 > < -5.0, 2.8, 0.0 > 0.1 rotate < 0.0, 240.0,
  cylinder { < -5.5, (2.8+HeightOfBlades), 0.0 > < -5.0,
(2.8+HeightOfBlades), 0.0 > 0.1 rotate < 0.0, 000.0, 0.0 > texture {
(2.8+HeightOfBlades), 0.0 > 0.1 rotate < 0.0, 120.0, 0.0 > texture {
(2.8+HeightOfBlades), 0.0 > 0.1 rotate < 0.0, 240.0, 0.0 > texture {
  cylinder { < -12.5, 2.8, 0.0 > < -5.0, 2.8, 0.0 > 0.1 rotate < 0.0, 060.0,
0.0 > texture { WindCatcherFixtures } }   // Following the windcatcher's
holds
  cylinder { < -12.5, 2.8, 0.0 > < -5.0, 2.8, 0.0 > 0.1 rotate < 0.0, 180.0,
  cylinder { < -12.5, 2.8, 0.0 > < -5.0, 2.8, 0.0 > 0.1 rotate < 0.0, 300.0,
  cylinder { < -12.5, (2.8+HeightOfBlades), 0.0 > < -5.0,
(2.8+HeightOfBlades), 0.0 > 0.1 rotate < 0.0, 060.0, 0.0 > texture {
(2.8+HeightOfBlades), 0.0 > 0.1 rotate < 0.0, 180.0, 0.0 > texture {
(2.8+HeightOfBlades), 0.0 > 0.1 rotate < 0.0, 300.0, 0.0 > texture {
 rotate AngleOfWindCatchers_360
#declare Platform=object
 union
  cylinder { < 0.0, (2.8+HeightOfBlades), 0.0 > < 0.0,
(3.30+HeightOfBlades), 0.0 > 5.0 texture { RoofPlatform } }
  cylinder { < 0.0, (2.8+HeightOfBlades+0.5), 0.0 > < 0.0,
(2.8+HeightOfBlades+0.6), 0.0 > 1.5 texture { RoofDoor } }
  torus { 4.975, 0.025 translate < 0.0, (2.8+0.5+HeightOfBlades+0.34), 0.0 >
texture { RoofReeling } }
  torus { 4.975, 0.025 translate < 0.0, (2.8+0.5+HeightOfBlades+0.67), 0.0 >
  torus { 4.975, 0.025 translate < 0.0, (2.8+0.5+HeightOfBlades+1.0), 0.0 >
  cylinder { < 4.975, 15.5, 0.0 > < 4.975, (2.8+0.5+HeightOfBlades+0.975),
0.0 > 0.025 rotate < 0.0, 000.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 036.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 072.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 108.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 144.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 180.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 216.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 252.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 288.0, 0.0 > texture { RoofReeling } }
0.0 > 0.025 rotate < 0.0, 324.0, 0.0 > texture { RoofReeling } }
#declare Maglev=union
 object { Base }
 object { Stairs }
 object { Turbine }
 object { WindCatcher }
 object { Platform }
object { Maglev }
Date: 24 Sep 2010 19:17:43
Message: <4c9d3197$1@news.povray.org>
Or, if anyone finds a way to export the source code below (POV-Ray scene
language version 3.7) or the source code inside my previous posting in this
thread (POV-Ray scene language version 2.2) to the current .3ds or .dxf file
formats, I would appreciate this very much!
#version 3.7;
light_source { < 1000.0, 2000.0, -1000.1 > rgb < 1.0, 1.0, 1.0 > }
light_source { < -1000.0, 2000.0, -1000. > rgb < 1.0, 1.0, 1.0 > }
#declare Radiosity=on;
#declare Photons=off;
global_settings
 assumed_gamma 1.0
 #if (Radiosity)
  radiosity
   pretrace_start 0.04         // start pretrace at this size
   pretrace_end   0.04         // end pretrace at this size
   count 35                    // higher -> higher quality (1..1600) [35]
   nearest_count 5             // higher -> higher quality (1..10) [5]
   error_bound 1.8             // higher -> smoother, less accurate [1.8]
   recursion_limit 3           // how much interreflections are calculated
(1..5+) [3]
   low_error_factor .5         // reduce error_bound during last pretrace
step
   gray_threshold 0.0          // increase for weakening colors (0..1) [0]
   minimum_reuse 0.015         // reuse of old radiosity samples [0.015]
   brightness 1                // brightness of radiosity effects (0..1) [1]
   adc_bailout 0.01/2
   normal on                   // take surface normals into account [off]
   media on                    // take media into account [off]
   always_sample off           // turn sampling in final trace off [on]
   max_sample 1.0              // maximum brightness of samples
 #if (Photons)
  photons
   spacing 0.01                 // specify the density of photons
   media 0.5, 1.5  // media photons
   jitter 1.0                 // jitter phor photon rays
//   save_file "SL - SF - Shuttle 01.ptn"       // save photons to file
   load_file "SL Maglev Wind Turbine.ptn"       // load photons from file
//   steps 1
   expand_thresholds 0.2, 40
#declare HeightOfBlades= 12.2;
#declare AngleOfWindCatchers_360= < 0.0, 0.0, 0.0 >;
 union
Fundament } }
{ StairsSection } }
 difference
 union
 union
holds
 union
 object { Base }
 object { Stairs }
 object { Turbine }
 object { Platform }
object { Maglev }
Date: 24 Sep 2010 20:50:00
Message: <web.4c9d45fd3204270ab92da8ee0@news.povray.org>
I have no idea, I haven't used crossroads before (or if so, it's been so long
since then, I can't remember).
There is a shareware converter here http://psenzee.com/pov2mesh/ which converts
to .obj  which might be imported to 3ds or dxf with other converters (probably
poseray) afterwards. However it seems to have limitations concerning the import
of #declare statements, at least it says so on the homepage. I haven't tried
this one either, but maybe it can help with your project.
Cheers,
Simone
Date: 27 Sep 2010 10:15:59
Message: <4ca0a71f@news.povray.org>
The problem has been solved. Thanks to everyone. Thread closed.   :-)
