POV-Ray : Newsgroups : povray.general : Can intensity of light be returned in Pov-Ray? Server Time
11 Oct 2025 21:37:58 EDT (-0400)
  Can intensity of light be returned in Pov-Ray? (Message 1 to 8 of 8)
Subject: Can intensity of light be returned in Pov-Ray?
Date: 31 May 2010 15:25:01
Message: <4c040d0d$1@news.povray.org>
Well, subject says it all. Is there a way to return the intensity of light
in Pov-Ray?
I mean like the trace-function, but return a light-intensity I(x,y,z)?
I realize that one first has to compute the scene, so I suppose there is no
easy way to do this. Is there a complicated way?
Subject: Re: Can intensity of light be returned in Pov-Ray?
Date: 31 May 2010 15:35:17
Message: <4c040f75@news.povray.org>
  Patch the source code?
Date: 31 May 2010 21:27:48
Message: <4c046214@news.povray.org>
I did not really want to spend the next few years studying the pov-ray
source... but probably the only solution.
Changing some of the source-code might be interesting, though. I always
thought a built-in physics-engine would have been nice, but I fear
implementing it would probably be the work of a lifetime and very probably
beyond my skills.
To know the amount of light at a certain point in space would allow to
simulate heliotropic behaviour of plants. Ivy not just creeping up a wall
but climbing towards the light. Yes, it can be achieved by using trace and
common sense and lots of trials, too, but to have a mechanism for it would
have been nice.
Date: 31 May 2010 21:52:47
Message: <4c0467ef$1@news.povray.org>
Or, trace the image without the ivy, then use it as a pigment to guide the
movement of the ivy in a second trace.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 1 Jun 2010 11:50:48
Message: <4c052c58$1@news.povray.org>
Given direct lighting and a small number of light sources the
calculations shouldn't be that difficult, or should they?
Mike
Date: 1 Jun 2010 14:07:24
Message: <4c054c5c$1@news.povray.org>
TC wrote:
> I always thought a built-in physics-engine would have been nice
MegaPOV has a patch for mechanical simulations, in case this
is of interest to you.
> to simulate heliotropic behaviour of plants. Ivy not just creeping up
> a wall but climbing towards the light.
Getting the light intensity at a point would not seem the
best choice for that even if possible. At least I don't think
heliotropic plants look for bright surfaces, they probably
target the light sources directly and you know where
those are in the scene anyway.
Actually I think the term heliotropic is reservered for plants
which actually turn towards the light actively, as opposed
to just growing towards the light.
Date: 1 Jun 2010 14:44:30
Message: <4c05550e$1@news.povray.org>
"Christian Froeschlin" <chr### [at] chrfrde> schrieb im Newsbeitrag
news:4c054c5c$1@news.povray.org...
Thank you for this suggestion. Megapov seems to have come quite a long way
ahead in the last few years.
Date: 1 Jun 2010 16:25:01
Message: <web.4c056bbc869f17a7e6ccfb210@news.povray.org>
Personally, I favor this choice - a grayscale light mapping of the surfaces
could be produced and used as a function to determine whether or not an area is
light or dark.  It is labor intensive, for sure, but it can be done.  Using
Megapov's proximity pattern also allows one to produce an ambient occlusion
pigment.  I have not tried this with a function, but if it works it will not
require the production of separate images (internal or external).
There was someone else's fastprox macro that used averaged object pigments to
produce a form of feature detection - corner detection for structures and large
objects could be drawn from this without much difficulty.  Of course, this would
again be a form of ambient occlusion, which may not always be accurate in a
given setup.  However, the nice thing about this is that you can introduce
objects into your ao/light map that do not have an actual scene presence.  These
objects can be used to make your light map more accurate, or manipulate it for
dramatic effect, etc.
-Reactor
