POV-Ray : Newsgroups : povray.general : rad_def.inc Server Time
20 Nov 2025 15:24:13 EST (-0500)
  rad_def.inc (Message 1 to 4 of 4)
Subject: rad_def.inc
Date: 24 May 2010 09:53:37
Message: <4bfa84e1$1@news.povray.org>
Greetings,
Working on some doc issues and noticed something in rad_def.inc file
that doesn't apply anymore:
// ####### DO NOT FORGET TO USE THE +QR/Radiosity=on OPTION ########
before I submit a change to remove it, I wanted to ask if there is
anything ELSE that needs to be changed/added/deleted that anyone would
care to mention.
Jim
Subject: Re: rad_def.inc
Date: 24 May 2010 12:22:20
Message: <4bfaa7bc$1@news.povray.org>
Am 24.05.2010 15:56, schrieb Jim Holsenback:
> Greetings,
> care to mention.
> Jim
Some typos:
     // An empty raddiosiy block uses deault settings
should be "An empty radiosity block using default settings", I think.
Date: 25 May 2010 12:12:51
Message: <4bfbf703$1@news.povray.org>
On 05/24/2010 01:22 PM, clipka wrote:
> Some typos:
ah yes ... I did notice that, but was hoping for some technical upgrades
while I had the file checked out.
Currently working on a scene that's been rendering since last evening.
Granted it has media (shafts of light through a window) but that seems
kind of lengthy render time to me. I'm doing radiosity gather (two pass)
with a tad of AA and media samples less than what I'd settle for in the
final version. I'm using the IndoorHG setting and was wondering if the
"canned" settings are optimal. Any thoughts on if these are the settings
to use or can I do better with less overhead (render time)
Jim
Date: 25 May 2010 14:36:24
Message: <4bfc18a8$1@news.povray.org>
Am 25.05.2010 18:15, schrieb Jim Holsenback:
I took care to not change radiosity parameterization too much, so
generally the setting should still be as good as they used to be.
As stated in the file, the settings are not intended to be optimum
settings - they can't be anyway, as every scene is different.
Do you have the radiosity media setting on? It may make a hell of a
difference in render time, while probably not contributing /too/ much to
radiosity quality.
BTW, my lanterns on the water did behave exceptionally badly until I set
some objects to "no_radiosity" which would contribute virtually nothing
anyway, and just cost extra intersection testing time; the most
offending ones were a pair of (pseudo-) sky spheres.
