POV-Ray : Newsgroups : povray.general : geostationary weather pics to image_map ? Server Time
18 May 2026 07:40:44 EDT (-0400)
  geostationary weather pics to image_map ? (Message 1 to 9 of 9)
Subject: geostationary weather pics to image_map ?
Date: 30 Oct 2009 08:16:22
Message: <4aead916$1@news.povray.org>
Hello.
I've got a bunch of satellit pictures like this one
http://foo.buvette.org/trucs/nuages.jpeg and I want
use them to make an animation of the earth.
How can I process this pics to make them usable as
an image_map ?
Th.
Subject: Re: geostationary weather pics to image_map ?
Date: 30 Oct 2009 09:05:41
Message: <4aeae4a5@news.povray.org>
tcgetattr wrote:
> Hello.
> an image_map ?
I think that i need this sort of pictures :
http://earthobservatory.nasa.gov/Features/BlueMarble/BlueMarble_monthlies.php
Date: 30 Oct 2009 09:14:37
Message: <4aeae6bd@news.povray.org>
"tcgetattr" <tg### [at] getattrinvalid> wrote in message
news:4aead916$1@news.povray.org...
> Hello.
> an image_map ?
> Th.
POV-Ray supports jpeg as an image_map format, so strictly speaking you don't
need to process them at all to make them usable in POV-Ray. If you simply
wish to animate the image sequence and generate an mpeg then you don't
really even need to use POV-Ray. You can just use an mpeg compressor to
assemble the sequence. Indeed POV-Ray won't automatically assemble an
animation, it'll just create the individual frames, so you'll still need
software to assemble the sequence into an animation.
If you want to do something more sophisticated, then any advice will really
depend upon exactly what you want to do. If you want to do color correction,
then you may be able to use a color_map with the image. If you want to
project it onto a sphere and rotate the sphere, then you may need to
assemble a mosaic of images (which you probably won't have if the images are
from a geostationary satellite). If you want to overlay the clouds on a
terrain map or over a visible light spectrum image then you may need to
marry up the projections used (depending on the technical accuracy you are
hoping to achieve).
So more information on what you are trying to achieve is needed to be able
to offer any detailed advice.
Chris B.
(ps Nice jeans.gif)
Date: 30 Oct 2009 09:50:13
Message: <4aeaef15@news.povray.org>
news:4aeae4a5@news.povray.org...
> tcgetattr wrote:
>> Hello.
>> an image_map ?
There are some immediate problems apparent with this that could make life a
little complicated. I'll just start throwing a couple of ideas in the air to
get things started:
The cloud image you have only covers a small part of the planet whereas the
BlueMarble images cover the whole planet, so, unless you have images from
other multiple geostationary positions (or unless it's not stationary) then
you can't cover the entire globe. If you do have other images then you have
the problem of mosaic'ing them together.
Mapping the cloud cover image precisely to the projection of the BlueMarble
images is likely to be tricky (if you need to do that). You may be able to
get something approximate by using your cloud images with a flat projection
onto a sphere and then using a spherical camera in the middle of the sphere
to generate an image that would approximately overlay the BlueMarble images.
If you want to overlay the clouds onto the BlueMarble images you could
probably achieve this with a single pass in POV-Ray by using a spherical
projection to project a BlueMarble image onto a slightly larger sphere that
would show up as being behind the cloud sphere when the camera is in the
middle of the two concentric spheres.
You could maybe use a filter on the image to  make the darker green parts
transparent so that you could overlay the image onto a BlueMarble image (if
you need to overlay the images). This could be done in an external graphics
editor (e.g. Photoshop). If you wish to add tranparency that POV-Ray can use
then you'll probably need to convert the cloud images into one of the
formats that the filter option on the image_map supports (e.g. png or gif).
Chris B.
Date: 30 Oct 2009 10:13:19
Message: <4aeaf47f$1@news.povray.org>
>> an image_map ?
> need to assemble a mosaic of images (which you probably won't have if
> the images are from a geostationary satellite). If you want to overlay
> able to offer any detailed advice.
   I think I have to do some geometric transformation on my pics
   to make them suitable for image mapping them.
> (ps Nice jeans.gif)
Date: 30 Oct 2009 10:19:05
Message: <4aeaf5d9@news.povray.org>
  What kind of geometric transformation? POV-Ray already supports some.
Date: 30 Oct 2009 10:21:15
Message: <4aeaf65b$2@news.povray.org>
> the BlueMarble images cover the whole planet, so, unless you have images
> from other multiple geostationary positions (or unless it's not
   I'm a poor man, I only have one geostat satellite ;)
> BlueMarble images is likely to be tricky (if you need to do that).
   You hit the real point here... I'm seeking for that mapping.
   http://foo.buvette.org/trucs/geostatpics.tar.gz (6 Mo)
Date: 30 Oct 2009 10:55:58
Message: <4aeafe7e@news.povray.org>
   First try...
   http://foo.buvette.org/trucs/corrected.jpg
Date: 30 Oct 2009 11:22:09
Message: <4aeb04a1@news.povray.org>
news:4aeaf65b$2@news.povray.org...
Ah! So you're Thierry rather than the girl in the gif :o(
Well, to state the obvious, you can only get a partial earth coverage with
the images you've got.
Ok. Well here's my idea:
At a geostationary distance (37,786km according to Wikipedia) the image
should be fairly close to a linear projection, so you should be able to use
the spherical camera trick to get something fairly close to what you want.
Here's an example:
//camera {spherical location 0 look_at z}
camera {location <-1,2,-2> look_at 0}
sphere {0,1
    image_map {jpeg "nuages.jpeg" once}
    translate -y
    scale <1.61,0.7,1>
    translate -x+y
  finish {ambient 1}
The second camera definition may be handy to understand quite what's going
on. The image is mapped straight through the sphere like the letters passing
through a stick of rock at the seaside (hope that analogy works for you).
You can think of it as the light passing back from the satellite in almost
parallel rays and staining the sphere. The spherical camera looking out from
the centre of the sphere towards the 'far' side of the sphere draws what it
sees around the 360 degree surface of the inside of the sphere.
The only bit that's valid for you is the middle half of the top half of the
image, but I think this should be quite close to the projection used for the
BlueMarble images. It won't be exact as the light entering the satellite
doesn't really arrive in parallel rays, but at that sort of distance the
distortion, although probably noticable, should be fairly small. You may be
able to improve on the scaling of the original image which I got to by trial
and error. It would obviously be much easier if the starting image was
symmetrical and covered a full half of the globe.
Chris B.
