POV-Ray : Newsgroups : povray.general : Modifying an image_map color? Server Time
18 Mar 2026 02:23:08 EDT (-0400)
  Modifying an image_map color? (Message 1 to 7 of 7)
Subject: Modifying an image_map color?
Date: 14 Oct 2009 12:27:51
Message: <4ad5fc07$1@news.povray.org>
I'm currently doing some rendering of game models by exporting through
MilkShape, and while the basic textures work fine, I'm having some color
issues. I've found that in the game itself, the same image can be loaded
for multiple textures, then multiplied by a solid color to give it a
different hue/brightness.
Is there any way to do this in povray, without having to manually edit
the .tga files in gimp/photoshop? (I've converted them from .dds to
.tga, but could use other formats if it would make it easier). The
majority are multiplied by a <0.6,0.6,0.6> color which at first glance
is the same as applying 'diffuse 0.6', except many textures also have
ambient and this doesn't affect the color of that. Also, some have
non-gray colors, which I can't do with a simple diffuse statement.
Thanks!
Cshake
An example of the textures generated by the exporter:
#declare uvtexture_0 = texture{
   uv_mapping pigment{
     image_map{
       tga "hw_p2_fr1.tga"
       map_type 0
       interpolate 2
       transmit all 0.000000
   finish{
     ambient rgb <0.200000 0.200000 0.200000>
     specular 0.100000
     roughness 0.000781
Subject: Re: Modifying an image_map color?
Date: 14 Oct 2009 14:51:56
Message: <4ad61dcc$1@news.povray.org>
You can convert between pigments and functions, which should allow
you to do arbitrary color transformations on an image_map, e.g.
#macro from_black(COLOR)
color_map
   [0 color rgb 0]
   [1 color COLOR]
#macro pigment_scale(PIGMENT, SCALE)
#local F = function { pigment {PIGMENT} }
#local R = pigment {function {F(x,y,z).red}   from_black(3*SCALE*Red)  }
#local G = pigment {function {F(x,y,z).green} from_black(3*SCALE*Green)}
#local B = pigment {function {F(x,y,z).blue}  from_black(3*SCALE*Blue) }
pigment {average pigment_map {[R] [G] [B]} }
Date: 14 Oct 2009 15:21:29
Message: <4ad624b9$1@news.povray.org>
> Thanks!
> Cshake
>   uv_mapping pigment{
>     image_map{
>       tga "hw_p2_fr1.tga"
>       map_type 0
>       interpolate 2
>   finish{
>     specular 0.100000
>     roughness 0.000781
If you use that texture in a radiosity scene, you must replace the
ambient by ambient 0. Otherwise, it will actualy illuminate it's
surrounding.
In some cases, you can use a layered texture.
Use a fully transparent uper texture with some transmit or filter, like:
pigment{rgbf <1, 0.5, 0.1, 1>}
This will add an orange cast to the underlying pigment.
You can use a filter or transmit larger than 1 to create some
interesting effect.
You can use a negative filter or transmit. It result in a negative effect.
Date: 14 Oct 2009 21:09:40
Message: <4ad67654$1@news.povray.org>
> interesting effect.
> Alain
I was hoping this would work since it's almost exactly what I want, but
I get the error "Cannot layer over a patterned texture", which I assume
comes from having an image_map.
On to try Christian's method now.
Chris
Date: 15 Oct 2009 10:43:09
Message: <4ad734fd$1@news.povray.org>
> color_map
>   [0 color rgb 0]
>   [1 color COLOR]
> #end
> #end
Thanks, this seems to work perfectly. More code than I anticipated, but
oh well. I'll have to see if I can modify the exporter to allow for it
natively.
A new issue I'm finding is that all the uv_mapping textures seem to be
mirrored in either u or v , so I'm having to go through and scale them
with a bit of trial and error. I'm assuming this is the fault of the
exporter not doing the right-handed coordinated (milkshape) to
left-handed (povray) correctly.
I'm not holding my breath, but could there be a way of not needing to do
this by hand, either through scaling the mesh or something? It seems
that whichever direction is closest to being in-line with z (either u or
v) needs to be mirrored for the texture to work correctly.
Date: 15 Oct 2009 10:58:24
Message: <4ad73890$1@news.povray.org>
Mirroring the geometry will not help you there; you will need to mirror
either (a) the original texture images, or (b) the textures.
This also has nothing to do with POV-Ray's left-handed world coordinate
system (which is actually just the default, and can be changed by
choosing appropriate camera parameters), but an incompatibility of the
UV coordinate system. As this is clearly defined in POV-Ray and cannot
be changed (except by messing with the textures), it must therefore be
considered a bug in the exporter (unless you're going via an interim
file format in which UV coordinate space is poorly defined).
Date: 16 Oct 2009 03:06:17
Message: <4ad81b69$1@news.povray.org>
"CShake" <cshake+pov### [at] gmailcom> schreef in bericht
news:4ad67654$1@news.povray.org...
> I was hoping this would work since it's almost exactly what I want, but I
No. Image_maps work fine with layered textures as Poseray (for instance)
shows clearly. The error must come from something else.
Here is an example texture as Poseray generates:
//===start code===
#declare p_map6=pigment {image_map{png "MyImage.png" interpolate 2 transmit
all 0 filter all 0.21} }
#declare LeftEyeWhite_1_=
material{
texture{ pigment {color rgb <0.79,0.79,0.79> transmit  0}
        finish{specular 0 roughness 1 ambient rgb <0.00,0.00,0.00> diffuse
0.8 reflection{0} conserve_energy}}
texture{ pigment{uv_mapping p_map6}
        finish{specular 0.04266667 roughness 0.01484519 ambient rgb
<0.00,0.00,0.00> diffuse 0.8   reflection{0 } conserve_energy}}
//===end code===
material{} is not strictly necessary for layering. Note also that here the
image_map p_map6 is on top, which is possible as it has some filter. In the
same way, you can inverse the textures, providing some filter or transmit to
the top pigment.
Hope this helps.
