POV-Ray : Newsgroups : povray.general : Function for air density Server Time
30 Jul 2024 08:21:10 EDT (-0400)
  Function for air density (Message 1 to 8 of 8)
Subject: Function for air density
Date: 31 Aug 2009 08:56:31
Message: <4a9bc87f@news.povray.org>
I'm trying to write a function to calculate air density based on the
following article:
http://en.wikipedia.org/wiki/Barometric_formula#Density_equations
My question is, is the "exp" function in the article the same as the
"exp" function in POV-Ray? If not, what's the best way of going about
writing these functions in SDL? My calculus is very rusty, but the
description given here seems simple enough to implement:
http://en.wikipedia.org/wiki/Exponential_function#Continued_fractions_for_ex
-Mike
Subject: Re: Function for air density
Date: 31 Aug 2009 11:11:19
Message: <4a9be817$1@news.povray.org>
> following article:
Yes.
Date: 31 Aug 2009 17:09:36
Message: <4a9c3c10$1@news.povray.org>
scott wrote:
> Yes.
Thanks! The functions use multi-valued constants that will be tricky to
implement. Also, there are no functions for values beyond 71km. Is that
because the air so so thin that it's not worth calculating?
-Mike
Date: 31 Aug 2009 23:45:00
Message: <web.4a9c98231540ef51805d39df0@news.povray.org>
The atmosphere is made up of different layers, each with their own typical
temperature gradient.  Just because the last reference point is at 71km, that
doesn't mean the formulae are not valid beyond that point.  It just means that
most of the interesting features are below.
If you just want a good approximation,
exp(-1.4237e-4 * h)
is a good approximation on a log scale, where h is in meters.  That tends to
overpredict where the density is large, so
exp(-1.2e-4 * h)
is a much better approximation for low altitudes.  Of course it overpredicts
high altitudes where the densities are tiny anyway.  These are just based on
least squares and eyeballing, respectively.  Which one to choose just depends
what you need it for.  If you're looking to model it with media or something,
I'd just split the difference.  It'd be in the ballpark anyway.  If you really
need it to be accurate, then work on implementing the formula on Wikipedia.
 - Ricky
Date: 1 Sep 2009 18:41:16
Message: <4a9da30c$1@news.povray.org>
> exp(-1.4237e-4 * h)
> exp(-1.2e-4 * h)
>  - Ricky
I'm applying the media to the difference of two very large spheres.
Currently, the inner sphere (the Earth's radius) is set to "6375000 *
Meters", where Meters is equal to 4. I'm not sure how big to make the
outer sphere.
Could you please rewrite your density function to take this into
account? I've created a few patterns that begin and end at X distances
away from the center. I managed to get them to work if they are linear,
but act strange when the functions are non-linear.
-Mike
Date: 1 Sep 2009 21:25:01
Message: <web.4a9dc7ea1540ef51958421d50@news.povray.org>
> outer sphere.
Just make it go up to 50 or 100km.  The density at 100km is about 6e-4 percent
the density at the surface.  You'd have to try *very* hard to make this appear
as a discontinuity.
> account?
exp(-1.2e-4*(h/Meters-6375000))
Does that sound right?  Just be aware of precision issues if you're going to
model the earth in meters.
 - Ricky
Date: 2 Sep 2009 09:26:03
Message: <4a9e726b$1@news.povray.org>
> as a discontinuity.
>> account?
>  - Ricky
Here's my first attempt. I can't see a whole lot in the image. Could you
suggest some better settings for the scattering media?
-Mike
//BEGIN
#local Meters = 4;
#local InnerRadius = EarthRadius;
#local OuterRadius = EarthRadius + 100000 * Meters;
#local BoundRadius = sin(acos(EarthRadius/OuterRadius)) * OuterRadius;
#local DiffrRadius = OuterRadius - InnerRadius;
#local ScaleAmount = 32;			// arbitrary number
#local HazePigment = pigment
	function {exp(-1.2e-4 * (f_r(x,y,z) - EarthRadius)/Meters)}
	color_map
		[0 rgb 0]
		[1 rgb 1]
difference
	sphere {0, OuterRadius}
	sphere {0, InnerRadius}
	bounded_by {cylinder {<0,EarthRadius,0,>, <0,OuterRadius,0,>, BoundRadius}}
	hollow
	material
		texture {pigment {rgbt 1}}
		interior
			media
				scattering	{1, 0.5 * 1/ScaleAmount/1000}
				method		3
				intervals	1
//				samples		30, 100
				samples		10, 40
				density
					pigment_pattern {HazePigment}
					density_map {[1/4 rgb 0][3/4 rgb 1]}
		scale ScaleAmount
	translate -y * EarthRadius
//END
Date: 2 Sep 2009 10:21:19
Message: <4a9e7f5f@news.povray.org>
> -Mike
Nevermind. I am going to crap this and follow the TerraPOV tutorial instead.
-Mike
