POV-Ray : Newsgroups : povray.general : Rune particle system Server Time
22 Dec 2025 05:20:46 EST (-0500)
  Rune particle system (Message 1 to 3 of 3)
Subject: Rune particle system
Date: 24 Aug 2009 15:30:22
Message: <4a92ea4e$1@news.povray.org>
I am having problems with Rune's particle system. The particle macros
use the clock in the chronological sense of passing time, whereas I am
using the clock simply to rotate the camera and want time to stand
still. This obviously produces a conflict.
My question is, how do I "freeze" the particles so that they don't
change as the clock value increases? I've tried changing the
"particle_start" and "particle_end" parameters so that they are equal,
but this causes the particles to not appear at all. Is there a way to
override the clock?
Thanks.
Subject: Re: Rune particle system
Date: 24 Aug 2009 16:02:40
Message: <4a92f1e0@news.povray.org>
> override the clock?
  If nothing else works, you could go and replace all instances of 'clock'
with eg. 'PSClock' and then add this to the beginning of the include:
#ifndef(PSClock)
  #define PSClock = clock;
  Then you can override PSClock with your own value from the outside.
Date: 24 Aug 2009 23:16:59
Message: <4a9357ab$1@news.povray.org>
>> override the clock?
> #ifndef(PSClock)
> #end
Thanks. It ended up being because I didn't read the docs properly. You
can set the clock value in the INI settings.
-Mike
