POV-Ray : Newsgroups : povray.general : Normal map vs Bump Map... How hard to implement? Server Time
10 Jun 2026 14:44:27 EDT (-0400)
  Normal map vs Bump Map... How hard to implement? (Message 1 to 9 of 9)
Subject: Normal map vs Bump Map... How hard to implement?
Date: 22 Aug 2009 23:52:54
Message: <4a90bd16$1@news.povray.org>
A few models I've seen lately have a normal map attached to them, rather
than the standard bump map. POV-Ray uses bumpmaps.
Essentially, a normal map has the x,y,z coordinates in the r,g,b values,
rather than grayscale. How hard would it be to implement a normal map
such as this, rather than a bump map?
To further put salt on the wound, the one program out there that seems
to be able to translate normal maps into bump maps costs $100 for a
non-educational license, pretty high for a piece of software that has
such a narrow purpose...
I need to sit down and write a small app that will do it. Maybe support
for normal maps can go into POV 4's suggestion box? Unless it's trivial
to add to 3.7, I'm guessing not, due to the way normals work (though,
some normal patterns do have special normal perturbing functions...)
Subject: Re: Normal map vs Bump Map... How hard to implement?
Date: 23 Aug 2009 02:52:12
Message: <4a90e71c$1@news.povray.org>
Question is, do those normal maps carry /absolute/ or /relative/ values?
That is, are these coordinates in true X;Y;Z space (subject only to
transformations applied to the whole object), or are they rather to be
interpreted in U;V;N space?
If they carry absolute values, then the whole thing should be as easy as
eating pancakes (and should actually give better results than POV-Ray's
current bump mapping implementation).
If they carry relative values, then they should still be about as easy
to implement as it would be to fix the major flaw of POV-Ray's bump
mapping implementation.
I wouldn't be all too surprised if both variants were in use out there.
That's probably because while it is darn easy to convert a bump map into
a normal map, the reverse needs some more math (and may actually be
impossible in some cases; there are things you can do with a normal map
that you can't do with a bump map, e.g. an endless slope around a cylinder).
Theoretically it shouldn't be much of a problem: Normal maps are just
another description of how to mangle the geometric surface normal. To
the contrary, it should actually be even easier: With bump maps, you
have to first evluate at least three pixels to get the local slope in U-
and V-direction; with normal maps, you get the same information in a
single pixel.
The problem here is that POV-Ray doesn't even treat bump maps properly.
But it shouldn't make a worse job on normal maps either.
(The biggest obstacle might actually turn out to be that the term
"normal map" is already occupied in POV-Ray for a totally different
thing ;-))
Date: 26 Aug 2009 21:37:10
Message: <4a95e346$1@news.povray.org>
 From what I've read, and the normal map I have it seems to hold true
that it is in the U;V;N space,
On both fronts, this is good to hear :)
That really wouldn't surprise me one bit.
> cylinder).
Right, it requires integration, but the math on that isn't terribly bad,
just takes a bit of processing power.
>> support for normal maps can go into POV 4's suggestion box? Unless
>> it's trivial to add to 3.7, I'm guessing not, due to the way normals
>> work (though, some normal patterns do have special normal perturbing
>> functions...)
> single pixel.
Right. It's rather simple to take the RGB values, and alter the normal
at the point of ray->surface intersection to get the new normal.
I had no idea POV-Ray was handling bump-maps incorrectly. Interesting,
I've only skimmed the code for POV-Ray, so I wouldn't know... At the
time, I was more interested in poking around with the root solver code.
> thing ;-))
Yep. Finding an acceptable grammar for the feature would be a problem...
But it isn't like that hasn't happened before, material_map, for
instance, doesn't exactly mean what it says.
normal_pattern, much like pigment_pattern, perhaps? Though I can't see
using basic patterns as a normal map...
Date: 26 Aug 2009 22:21:41
Message: <4a95edb5$1@news.povray.org>
Basically what happens is that POV-Ray calculates the slope components
of the bump map (U and V), and computes the pertubed normal vector as
something along the lines of:
   VNormal = VNormal * slopeN + VAxis1 * slopeU + VAxis2 * slopeV;
While this is not fundamentally wrong, the problem is that POV-Ray fails
to make sure that VAxis1 and VAxis2 match the U and V axes in texture
coordinate space - it instead basically picks them at random, just
making sure they are perpendicular to VNormal.
With more or less random normal pertubations like bozo this is not
really a problem because you won't be able to tell the difference;
however, if you're using a bump map image with a clearer structure, this
may cause apparent inside/outside flipping at best - at worst it will
look as if the light source had been rotated around the geometric
surface normal; usually this will look noticeably weird, but often not
noticeably enough to tell exactly /why/.
Date: 27 Aug 2009 04:55:00
Message: <web.4a96498877f72fba1443971d0@news.povray.org>
From the softwares I use (Blender and 3DS max) The normal map can be UVN mapped.
For animated objects like characters we generally bake it from a high to a lower
polygon count mesh. There is an option to make this normal map use "tangeant
space", and I always leave it on, which allows the shaded point to be moved
from an already moved normal, like a bump on the side of another. If you want a
sample normal from blender, let me know.
Also besides normal maps, Blender 2.5 is implementing a new bump map method with
even better results but I don't know any more than that about it:
http://blenderlabrat.blogspot.com/2009/07/new-bump-mapping.html
> thing ;-))
I'd be glad to change that to something else for such a feature (Of course my
opinion is of one who has no POV habits yet :))
Date: 27 Aug 2009 05:32:59
Message: <4a9652cb@news.povray.org>
I have no idea what the difference is supposed to be - aside from the
"new method" appearing to use a stronger "contrast".
Date: 27 Aug 2009 06:29:25
Message: <4a966005$1@news.povray.org>
Ah, this explains why it seems difficult for me to get the bump mapping
clear on my creature. (I did manage to convert the normal map to a bump
map, using the program in trial mode...)
Date: 22 Jun 2010 17:35:00
Message: <web.4c212bb677f72fba5cc9c68e0@news.povray.org>
Bumping in this old discussion to ask if anything has changed about bump maps
implementation, and if any macro or test build can now deal with tangent space
normal maps?
Date: 7 Jul 2010 08:10:01
Message: <web.4c346e3277f72fba5d1042290@news.povray.org>
> normal maps?
I posted a few references here
http://news.povray.org/povray.general/thread/%3Cweb.4c25107ec23a6d95cc9c68e0%40news.povray.org%3E/?mtop=3
Any idea, anyone?
