POV-Ray : Newsgroups : povray.general : Transformation to align two axes? Server Time
24 Feb 2025 16:27:52 EST (-0500)
  Transformation to align two axes? (Message 1 to 5 of 5)
Subject: Transformation to align two axes?
Date: 11 Mar 2009 20:26:33
Message: <49b856b9$1@news.povray.org>
I'm having trouble thinking through a transformation problem, and I'm
pretty sure this isn't too crazy of a problem.
The idea is that I have an object centered at the origin, let's say a
thin oval with the major and minor radii along the x and z axes, (so the
normal on the flat face is in y). I want to rotate this so the x and y
axes are pointing in the direction of two arbitrary (normalized and
perpendicular) vectors.
transforms.inc has the Point_At_Trans(newY) that will do half this
problem, but if I want to then rotate the x axis to align with another
vector, it will mess up the original translation.
The object can then be translated to be centered at a given point, but
that part is easy.
Subject: Re: Transformation to align two axes?
Date: 11 Mar 2009 22:30:01
Message: <web.49b872905a6edcc2801985dd0@news.povray.org>
Why rotate when you can shear? :)
  transform { Shear_Trans(newX,VCross(newX,newZ),newZ) }
There. Shear_Trans is your friend, too :)
Date: 11 Mar 2009 22:51:29
Message: <49b878b1$1@news.povray.org>
> that part is easy.
I think what you want is Shear_Trans.
As long as the vectors you supply are normal and perpendicular
the object just gets rotated. You can use VPerp_To_Plane to
get the third vector...
#include "transforms.inc"
#include "math.inc"
object {
   Foo
   Shear_Trans(Xvec,YVec,VPerp_To_Plane(Xvec,YVec))
Date: 11 Mar 2009 23:23:45
Message: <49b88041$1@news.povray.org>
Thanks, that works perfectly. I knew there was something stupid simple
to use, but was afraid of all the Shear transforms because it always
makes me think of distortion.
Date: 12 Mar 2009 16:38:44
Message: <49b972d4$1@news.povray.org>
CShake nous illumina en ce 2009-03-11 23:23 -->
It IS a distortion, as is any unevent scaling. It change the basic shape of the
object, but in a very controled way.
Q: If pro is opposite of con,then what is the opposite of progress?
A: Congress!
Men's restroom, House of Representatives, Washington , DC
