POV-Ray : Newsgroups : povray.general : mesh2 Server Time
11 Apr 2026 20:07:25 EDT (-0400)
  mesh2 (Message 1 to 5 of 5)
Subject: mesh2
Date: 1 Jan 2009 10:05:44
Message: <495cdbc8$1@news.povray.org>
First the best wishes for 2009.
Is it with mesh2 objects possible to give the out-site en the in-site
different textures? What can I do with the texture_list?
Thanks...
Wijnand Nijs
Subject: Re: mesh2
Date: 1 Jan 2009 11:59:57
Message: <495cf68d$1@news.povray.org>
"Wijnand Nijs" <w.n### [at] alf4alldemonnl> wrote in message
news:495cdbc8$1@news.povray.org...
Yes, you can give the inside and outside of a POV-Ray object different
textures. By default they're the same, but you can use the
'interior_texture'  object modifier to specify a different texture for the
interior surfaces. Your mesh2 will need to have consistently defined
normals.
The texture_list enables you to specify different textures for use in the
mesh2 object. Each texture gets an index that can be used in the
face_indices section to assign a different texture to the different faces in
the mesh2 object, or optionally different textures for each of the vertices
of each face. From the help: "To specify a texture for an individual mesh
triangle, specify a single integer texture index following the face-index
vector for that triangle. To specify three textures for vertex-texture
interpolation, specify three integer texture indices (separated by commas)
following the face-index vector for that triangle."
I don't know how the two things work together if both are specified on the
same mesh2 object (I've never tried that). I would guess that you get a
single interior texture and that it would use the texture_list textures for
the outside.
Chris B.
Subject: Re: mesh2
Date: 2 Jan 2009 00:40:00
Message: <web.495da8747707fe405510c690@news.povray.org>
IIRC this is possible if your mesh does not make use of the texture_list, so
that you specify a single texture for the whole mesh instead. However, if
someone knows how to get this into the texture_list, I'd be glad to hear about
it.
Subject: Re: mesh2
Date: 2 Jan 2009 08:11:32
Message: <495e1284$1@news.povray.org>
Thanks Chris and Clipka. For test results see p.b.images.
> the interior surfaces. Your mesh2 will need to have consistently defined
> normals.
> the mesh2 object. Each texture gets an index that can be used in the
> faces in the mesh2 object, or optionally different textures for each of
> the vertices of each face. From the help: "To specify a texture for an
> individual mesh triangle, specify a single integer texture index
> following the face-index vector for that triangle. To specify three
> textures for vertex-texture interpolation, specify three integer texture
> indices (separated by commas) following the face-index vector for that
> triangle."
> the same mesh2 object (I've never tried that). I would guess that you
> get a single interior texture and that it would use the texture_list
> textures for the outside.
> Regards,
> Chris B.
Subject: Re: mesh2
Date: 2 Jan 2009 13:28:22
Message: <495e5cc6$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.495da8747707fe405510c690@news.povray.org...
> so
> about
> it.
The code sample I've added to the thread in povray.binaries.images uses
both, but I don't see any way of getting interior textures to map to the
texture_list inside the mesh2 definition.
