POV-Ray : Newsgroups : povray.general : web-view newsgroups problem Server Time
18 May 2026 02:38:05 EDT (-0400)
  web-view newsgroups problem (Message 1 to 8 of 8)
Subject: web-view newsgroups problem
Date: 8 Aug 2008 18:35:06
Message: <489cca1a$1@news.povray.org>
I have been trying to reply to messages in p.b-images using the web-view
version of the newsgroups. Every time I try to reply, I am sent to log
in. After logging in, I go back to the log in screen. Going back to
p.b-images, I try to reply once again. The situation loops. I tried
changing my password--which was successful--but I am still unable to
reply to messages.
None of this would matter if Thunderbird would reliably let me reply to
image-bearing messages in the first place.
Any ideas would be appreciated!
Sam
Subject: Re: web-view newsgroups problem
Date: 8 Aug 2008 21:11:06
Message: <489ceeaa$1@news.povray.org>
> reply to messages.
I am not aware of Thunderbird having problems to reply to any newsgroups
(using it myself). Nor the web view having such problems.
	Thorsten, POV-Team
Date: 8 Aug 2008 21:23:39
Message: <489cf19b@news.povray.org>
The problem with Thunderbird is that it insists on taking the same
amount of time loading up the reply window as it does downloading the
image of the original post. It's as if I'm replying with the posted
image, but of course I'm not. Sometimes it takes even longer than this,
making it very difficult to reply to most posts in p.b-images...
Sam
Date: 9 Aug 2008 02:56:55
Message: <489d3fb7$1@news.povray.org>
>> newsgroups (using it myself). Nor the web view having such problems.
The problem with Thunderbird is that is seriously re-downloads the whole
message when replying rather than using the local cached copy. It does the
same for IMAP email servers (a known bug), but it does seem like the bug has
not yet been reported for (NNTP) newsgroup servers yet. So you might want to
do that...
As for the web view, it definitely does not have that problem. I just tried
replying to a p.b.i message and it worked like it should.
	Thorsten, POV-Team
Date: 9 Aug 2008 13:10:55
Message: <489dcf9f@news.povray.org>
Wild guess: Did you accidentally deny some cookies from
news.povray.org? I don't use the web interface but on other
sites it is often the trouble when logging in doesn't work
properly. You might check in your privacy settings.
Date: 9 Aug 2008 17:31:02
Message: <489e0c96@news.povray.org>
Gah! That's what it was, all right. I get so used to denying all useless
cookies that I forget to allow the important ones in. There's a bigger
lesson in there somewhere...
Thanks, Christian!
Sam
Date: 11 Aug 2008 19:11:39
Message: <48a0c72b@news.povray.org>
stbenge nous illumina en ce 2008-08-08 18:35 -->
> Hi,
> reply to messages.
> Sam
I never encoutered any problem replying to messages containing images, including
attached, inline and HTML.
If I want to keep the image(s) with my reply, I just hold the shift key when
clicking the reply button.
"The problem with Thunderbird is that is seriously re-downloads the whole
message when replying rather than using the local cached copy. It does the same
for IMAP email servers (a known bug), but it does seem like the bug has not yet
been reported for (NNTP) newsgroup servers yet. So you might want to do that..."
Thorsten, I already reported about that problem a long time ago. It's the same
problem that cause a message to be re-downloaded when saving the attachment(s).
The answer I got was that Thunderbird had no way to know it the attachment was
in cache or not, and assumed that it was not there. A sane aproach would be to
first check the cache and only request it if not found localy...
Keep your boss’s boss off your boss’s back.
Date: 14 Aug 2008 18:58:58
Message: <48a4b8b1@news.povray.org>
> has not yet been reported for (NNTP) newsgroup servers yet. So you might
> want to do that..."
> same problem that cause a message to be re-downloaded when saving the
> attachment(s).
> was in cache or not, and assumed that it was not there. A sane aproach
> would be to first check the cache and only request it if not found
> localy...
I had Thunderbird *always* re-download messages. With or without
attachments.
Looks like there are two options:
- keep a cache that expires whenever you switch to another folder/newsgroup
or close Thunderbird.
- download EVERYTHING the newsgroup has, and keep it locally (mark the
newsgroup "available offline").
There is no way to configure Thunderbird to behave like a web browser: when
you download something, keep it cached forever unless the cache is getting
too big; but don't download stuff you don't look at.
Sad that the best newsreader I have ever used was Outlook Express...
