I have forgotten - is there ever anyone who have made a macro for creating
rounded prisms? I currently need a macro to create rounded prisms, where the
rounded prism will fit inside a normal prism with the same points. In other
words, the rounding thickness should not be added to the prism, but rather
some volume should be taken away at the edges to get the rounding.
I tried to do the math myself, but it turned out to be a bit tricky for me.
I have searched on google for both rounded and smooth prism, but with no
good results as far as I can see. I just seem to remember that such a macro
existed, but I may be mixing up things...?
Rune
http://runevision.com
"Rune" <nor### [at] runevision com> wrote in message
news:488e392c$1@news.povray.org...
> Hi,
> the rounded prism will fit inside a normal prism with the same points. In
> other words, the rounding thickness should not be added to the prism, but
> rather some volume should be taken away at the edges to get the rounding.
> me.
> macro existed, but I may be mixing up things...?
as part of my greeble-macros, I made a beveled linear-spline prism macro.
Those macros should be somewhere in p.b.s-f
Syntax:
RoundPrism(Points,R,H)
with Points the array of points defining the prism, R the radius of the
bevel, and H the height of the bevel.
It's actually not rounded, but with the macro GetBeveledPrism(Points,R) you
should be able to create a rounded linear-spline prism. That macro just
returns the points (as an array) of the beveled end of a beveled prism using
points Points and bevel-radius R.
So, for example, let say you want to make a beveled 3-sided prism, you first
define the points:
#local Points=array[3]{UV1,UV2,UV3};
Then you ask for the beveled points:
#local BeveledPoints=GetBeveledPrism(Points,Radius);
Then you make a linear prism, going from y=Radius to y=Height-Radius, using
the points in the array Points.
You also make another linear prism going from y=0 to y=Height, using the
points in the array BeveledPoints.
And then you add the beveled ends, by using cylinders, going through pairs
of points in BeveledPoints, intersected by planes defined by the original
point, the beveled point on the original height and the beveled point on the
beveled height.
This will give you a prism with sharp corners, but round bevels.
I you want round corners and round bevels, you'll have to use a linear prism
going from y=0 to y=Height using the points in BeveledPoints, spheres at
every point in BeveledPoints with y=Radius and y=Height-Radius, cylinders
going from sphere to sphere, and some more math for the sides... shouldn't
be too hard.
The macros should work with any non self-intersecting set of points, as far
as I know, but might give weird results if the radius is too high.
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
Rune wrote:
> Hi,
I am like you. I forget too!
There was a discussion a while back about rounded prisms. But I don't
remember if anything came of it. I do know that I have 6 version of
'rounded prisms' all of which I'm not proud of.
The math is tricky! Especially if you try and match a prism object.
And I'm always geting flat spots on all but the simplest prisms.
It might be best if we made a mesh shape object out of the prism data.
I might give it a go...
If you find a good one LET US KNOW please.
> Rune
> rounded prisms?
http://www.slimeland.com/misc/roundedprism.inc
It only works with linear spline prisms, and looking back I don't think it's
done in the most ideal way, but it should work fine.
- Slime
[ http://www.slimeland.com/ ]
Rune wrote:
> Hi,
I don't think its quite what you're looking for, but in case it is: my
PointArrays macros in the object collection can convert a linear spline
to a bezier spline with rounded corners. The convex corners will lie
inside the original as you want, but the rounding of the concave corners
will not. Also, it is still just a prism, so the y oriented edges will
be round but the top and bottom faces will still have sharp edges.
If you're interested check out the PA_Linear_To_Bezier and
PA_Linear_To_Bezier_Circ (and maybe PA_Linear_To_Bezier2) macros in the
PointArrays package. An example image can be seen here:
http://news.povray.org/4856d321%40news.povray.org
Hope this helps.
-The Mildly Infamous Blue Herring
> Also, it is still just a prism, so the y oriented edges will be
I didn't try your point array macros, but from the other sample
image (not the one you linked to), I think it might be able to
generate the object which needs to be differenced away from
the prism to get round edges at top and bottom.
Basically, the idea would be to use the same spline defining
the prism base for sweeping a 2d corner cutting shape.
"Slime" <fak### [at] email address> wrote in message
news:488e997e@news.povray.org...
> it's done in the most ideal way, but it should work fine.
Thanks! This works perfectly. :)
Also thanks to everybody else who offered help.
Rune
By the way, the automatic closing of the prism works fine if you replace
this line:
#if (pointarray[dim-1].u != pointarray[0].u & pointarray[dim-1].v !=
pointarray[0].v)
with this:
#if ((pointarray[dim-1].u != pointarray[0].u) | (pointarray[dim-1].v !=
pointarray[0].v))
Rune
That's a good idea, I haven't tried it in a while, and never tried it in
quite this way. May have to look into this again...
