POV-Ray : Newsgroups : povray.general : Determining rotation Server Time
13 Oct 2025 06:44:04 EDT (-0400)
  Determining rotation (Message 1 to 7 of 7)
Subject: Determining rotation
Date: 10 May 2008 19:55:41
Message: <482635fd@news.povray.org>
I am working with limbs still.  Given a point A, a given distance (r)
from the origin, how would I determine the angles to rotate an object at
<0, r, 0> to match A?  I've beaten my head against this one for some
weeks now, and my math skills are not up to the task.
Subject: Re: Determining rotation
Date: 10 May 2008 20:02:51
Message: <482637ab@news.povray.org>
  No need to do the math when others have already done it for you:
http://povray.org/documentation/view/3.6.1/488/
Date: 11 May 2008 05:40:56
Message: <4826bf28$1@news.povray.org>
"Tail Kinker" <the### [at] gmailcom> wrote in message
news:482635fd@news.povray.org...
>I am working with limbs still.  Given a point A, a given distance (r) from
>the origin, how would I determine the angles to rotate an object at <0, r,
>0> to match A?  I've beaten my head against this one for some weeks now,
This can get quite complicated, depending on precisely what you want to do.
Particularly when posing limbs where you may need to work in a sequence
that's different from the conventional X-Y-Z rotation sequence.
If you aren't interested in the orientation of the object around its own
axis (you usually are with limbs), you can get from <0,r,0> to anywhere with
one X rotation followed by one Y rotation (anywhere where vlength(A)=r).
You can work out the angles, one at a time, by taking the point that you get
by projecting point A onto the YZ-plane (project a line through A and
through the YZ-plane at right angles). This point will be at <0,A.y,A.z>.
You can now use trigonometry to work out the two angles you're interested
in, or you can use the VAngleD() function from math.inc (you'll obviously
need to take care over angles in the different quadrants).
If you are interested in the final orientation of the limb (which you
probably are) then getting a single X-Y-Z rotation gets quite a bit more
complicated. A simpler alternative is to apply the reverse rotations you get
from the previous calculation to an orientation vector (a normal to Vector
A) to bring it back onto the XZ-plane. You can then use VAngleD() to work
out a Y rotation that can be applied to the object before you apply the X-Y
rotations from the previous calculation to the limb object. By doing this
you end up with a Y-X-Y rotation sequence, rather than an X-Y-Z rotation
sequence, so you'll need to apply two POV-Ray rotation statements rather
than one.
Hope that helps unlock the particular bits of grey matter that beating your
head didn't :-)
Chris B.
Date: 11 May 2008 06:07:26
Message: <4826c55e@news.povray.org>
Perhaps I am blind, or stupid, but I cannot see how any of these
functions would assist in this problem. Could you please clarify?
Date: 11 May 2008 06:38:32
Message: <4826cca8@news.povray.org>
  You asked how to rotate a vector <0, r, 0> so that it ends up
pointing at the same direction as a vector A. That's precisely what
the Point_At_Trans() macro does.
  (Or, more precisely, the Point_At_Trans() macro creates a transformation
which you can use in an object or to modify a vector using vtransform).
Date: 11 May 2008 08:35:07
Message: <4826e7fb@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4826bf28$1@news.povray.org...
> ... snip ...
> get by projecting point A onto the YZ-plane (project a line through A and
Sorry. I got this a bit wrong.
To get the 'Y' rotation you need to drop point A down onto the XZ-plane. The
'Y' rotation is therefore VAngleD(z,<A.x,0,A.z>). To get the 'X' rotation
you need to rotate point A back onto the YZ-plane so that it lies in +Z. To
do this, use vrotate() with point A and the negative of the Y-rotation you
just calculated. This gives you a point B on the YZ-plane that you can use
with VAngleD(y,B) to retrieve the first rotation angle.
> ... snip ...
Chris B.
Date: 11 May 2008 16:59:22
Message: <48275e2a@news.povray.org>
Okay, so I'm stupid.  :)  Thanks for the assist.
