POV-Ray : Newsgroups : povray.general : media artefacts when object surfaces come close to eachother Server Time
22 Dec 2025 23:08:33 EST (-0500)
  media artefacts when object surfaces come close to eachother (Message 1 to 6 of 6)
Subject: media artefacts when object surfaces come close to eachother
Date: 7 Apr 2008 12:43:07
Message: <47fa4f1b$1@news.povray.org>
Hi!
In the povray-code posted below, I'm trying to show two objects composed
of transparent light emitting material, that intersect eachother, simply
as an illustration of what the intersection should look like (first
object red, second green, in the intersection both colors are emitted
simultaneously).
This seems to work great, except when the surfaces of both objects come
close to eachother.  Rendering the code should show some sort of cross
composed of areas/pixels that are either fully red or green.  It is as
if the rays only see the entrance into one of both objects, and the
other object is disregarded.  Rendering with anti-aliasing partly hides
the problems where they weren't too large in the first place, but the
cross is still very visible.
Is there an easy solution for this?  (I suppose it's an accuracy
problem, not a real bug)
Many thanks,
Stefaan
// Povray code for two intersecting, light emitting transparent lathes
	translate 1 * -z
	rotate <-90, 0, 0>
#declare cone0 =
	lathe {
		linear_spline
		2,
		<0, 0>, <.4, 4>
#declare cone1 =
	object {
		cone0
		transform {
			translate -y * 2
			rotate <90, 0, 0>
#declare cone2 =
	object {
		cone0
		transform {
			translate -y * 2
			rotate <0, 0, 90>
			rotate <90, 0, 0>
object {
	cone1
	pigment { color rgbt <0, 0, 0, 1> }
	interior {
		media {
			emission rgb <.5, 0, 0>
			intervals 1
			samples 5
			method 3
			density { rgb 2 }
	hollow
object {
	cone2
	interior {
		media {
			emission rgb <0, .5, 0>
			intervals 1
			samples 5
			method 3
			density { rgb 2 }
	hollow
Subject: Re: media artefacts when object surfaces come close to eachother
Date: 8 Apr 2008 05:12:01
Message: <47fb36e1@news.povray.org>
> Is there an easy solution for this?  (I suppose it's an accuracy problem,
> not a real bug)
There is no easy solution to this.
The artifacts are from floating point errors where
the very narrow seams are too small to sample.
Date: 8 Apr 2008 13:09:52
Message: <47fba6e0$1@news.povray.org>
Stefaan De Roeck nous apporta ses lumieres en ce 2008/04/07 12:43:
> Hi!
> simultaneously).
> Many thanks,
> Stefaan
Problems with floating point rounding errors.
An easy solution:
Scale your scene by 100 and divide the density by 100 and the cross is almost
gone. Increase that to 1000 and you no longer see the artefacts.
A question: Why use a lathe when you have the cone primitive?
WARNING: The consumption of alcohol may make you think you are whispering when
you are not.
Date: 10 Apr 2008 09:42:42
Message: <47fe1952$1@news.povray.org>
> An easy solution:
> almost gone. Increase that to 1000 and you no longer see the artefacts.
Strange, but it works.  But how can it?  Floating point numbers are
represented by radix and exponent.  Usually errors are introduced when
e.g. subtracting two similar numbers, thus challenging the radix'
accuracy.  Those cannot be solved by such scaling, suggesting the
exponent in the floating point does not suffice to represent
intermediate results.  Supposing double precision floats, this would
mean some significant intermediate results are between 2^(-1024) and
2^(-1024)/1000?
In any case I'm happy to have a workaround, but I'm still trying to
understand the source of the problems.
Because I lack adequate knowledge on the primitives :)
Thanks!
Date: 11 Apr 2008 13:08:42
Message: <47ff9b1a$1@news.povray.org>
Stefaan De Roeck nous apporta ses lumieres en ce 2008/04/10 09:42:
>> An easy solution:
> 2^(-1024)/1000?
> Thanks!
In fact, the artefacts are still there, but they become smaller, sub-pixel. When
you scale up, the integer part become larger. You don't get rounding errors on
the integer part, only in the fractional part. When you scale up, the fractional
part become less and less importent, reducing the errors.
After any salary raise, you will have less money at the end of the month than
you did before.
Date: 11 Apr 2008 13:10:11
Message: <47ff9b73$1@news.povray.org>
>> An easy solution:
> 2^(-1024)/1000?
Experiment with the primitives, and gain practical knowlege of them.
> Thanks!
you did before.
