POV-Ray : Newsgroups : povray.general : 16-bit grayscale PNGs -> PoV-Ray 16-bit heightfield TGAs? Server Time
27 Aug 2025 07:06:20 EDT (-0400)
  16-bit grayscale PNGs -> PoV-Ray 16-bit heightfield TGAs? (Message 1 to 10 of 14)
Subject: 16-bit grayscale PNGs -> PoV-Ray 16-bit heightfield TGAs?
Date: 25 Mar 2008 05:20:39
Message: <47e8d1f7$1@news.povray.org>
High!
A recent thread on p.b.i. drew my attention to http://www.buining.com -
those 16-bit PNG elevation maps of Earth, the Moon and Mars look
tempting! But AFAIK PoV-Ray's height_field functionality can't handle
grayscale 16-bit PNGs... are there any tool for conversion into 16-bit
heightfield TGAs available? Or at least into ordinary uncompressed
32-bit TGAs, so I could write a converting routine on my own... perhaps
I should take a closer look at the latest version of IrfanView?
See you on www.khyberspace.de!
Yadgar
Now playing: Solid Rock (Dire Straits)
Subject: Re: 16-bit grayscale PNGs -> PoV-Ray 16-bit heightfield TGAs?
Date: 25 Mar 2008 09:03:32
Message: <47e90634@news.povray.org>
I think this should work:
global_settings{hf_gray_16}
plane{z,0
  texture{
   pigment{
    image_map{png "your_file_here" interpolate 2}
    translate -.5
    scale 2.1
   scale <-1,1,1>
   finish{brilliance 0 ambient 1}
camera{
  orthographic
  location <0,0,-1>
  up 1*y right 1*y
  angle 90
  look_at 0
Jaime
Date: 25 Mar 2008 09:07:04
Message: <47e90708$1@news.povray.org>
It should work. From the documentation of height fields:
"PNG format heightfields are usually stored in the form of a grayscale
image with black corresponding to lower and white to higher parts of the
height field. Because PNG files can store up to 16 bits in grayscale
images they will be as smooth as TGA and PPM images."
Date: 25 Mar 2008 11:10:59
Message: <47e92413$1@news.povray.org>
AFAIK, yes it can.
Date: 26 Mar 2008 14:15:00
Message: <web.47ea9ffdb76e2336a5d4a01d0@news.povray.org>
> AFAIK, yes it can.
I've had trouble with 16 bit PNGs as well.  The height_field come out as if it
were noise.
Date: 27 Mar 2008 19:30:00
Message: <web.47ec3925b76e233678dcad930@news.povray.org>
OK, I'm *completely* new to making 16-bit HFs. And so far, I'm feeling like a
complete dunce.  :-S  Even after reading the POV documentation. Help!
I downloaded the EarthDEM2160.png image file from the given link--a hi-rez,
16-bit elevation map of the earth's continents. Or so says the site--I have no
way of checking the bit depth, computer-knowledge-impaired as I am. (Photoshop
5.0 brings it up as an 8-bit image.)
So, do I understand that the proper series of events is, first to use Jaime's
technique of rendering this image in POV--as a hi-rez render, and setting my INI
file to Output_File_Type=N?  Doing so, I get a nice .png rendering...in 16 bits,
I assume. (Do I need to set Bits_Per_Color = 16 in the INI file as well? Haven't
done that yet.)
Then, do I take that rendered image and stick it into a a HF scene?  Like thus--
global{.....}
camera{......}
light_source(.....}
height_field{png "rendered_HF_image.png" scale <1,.2,1> // smooth
     texture{......}
I get a HF, but it looks rather rough (to my eyes), like the vertical resolution
is still 8-bit.  Don't really know for sure.
Do I have the steps correct?
Ken W.
Date: 27 Mar 2008 19:51:39
Message: <47ec411b$1@news.povray.org>
> done that yet.)
Yes, you do need Bits_Per_Color=16. Or just +fn16, which sets image type
to PNG and 16 bits :) I remember the short +stuff easier than the
Long_Ini_Settings... (and faster to type)
Date: 27 Mar 2008 20:30:01
Message: <web.47ec4791b76e233678dcad930@news.povray.org>
Thanks!
Either I'm vision-impaired, or I just haven't seen that little tidbit in the POV
docs, in either the hf_gray_16 section or the one on HFs. Perhaps it should be
obvious... though my initial thought was that setting the original rendering to
hf_gray_16 would take care of that.
Details, details...
So if the file_type has to be manually set to .png, and the Bits_Per_Color to
16--what exactly does global{hf-gray-16} do?? Besides making the image
gray-scale?  Hmm, perhaps that IS its only purpose, to eliminate unnecessary
color channels. Gee, I feel smarter already!
Ken W.
Date: 27 Mar 2008 23:55:01
Message: <web.47ec7984b76e233678dcad930@news.povray.org>
> technique of rendering this [downloaded] image in POV--as a hi-rez render,
> and setting my INI file to Output_File_Type=N...
Duh!  It just occurred to me--I'm finally starting to use my brain--that I can
use the 16-bit downloaded grayscale image AS-IS to make the height_field. No
hf_gray_16 rendering step required. The HF renders nicely.
So I have a question (truly out of ignorance): What is the purpose of
re-rendering  that 16-bit image using the hf_gray_16 rendering step that was
mentioned? Seems unnecessary and redundant (other than to apply interpolate 2
to it?) I DO understand that a preliminary rendering step is of course
necessary (using one of POV's patterns, for example) if there is no 16-bit
image to begin with.
I'm confused; please enlighten this poor unfortunate soul.
Ken W.
Date: 28 Mar 2008 01:40:00
Message: <web.47ec9114b76e233678dcad930@news.povray.org>
> mentioned?
A more enlightened reading of Jaime's original post tells me that I was
completely confused about what he meant (and I probably confused others by my
question.) It's clear now; he was describing a solution to the question in the
original post, a technique for taking a 16-bit .png image and re-rendering it to
be a different file type, one that could be used to make a 16-bit HF in case the
..png image itself didn't work.
But as others have said, a 16-bit .png image works as-is.
All clear. I'm off and running!
Ken W.
