POV-Ray : Newsgroups : povray.general : Texture: Canvas (slightly Transluscent) Server Time
27 Feb 2026 08:52:41 EST (-0500)
  Texture: Canvas (slightly Transluscent) (Message 1 to 10 of 12)
Subject: Texture: Canvas (slightly Transluscent)
Date: 19 Feb 2008 04:41:17
Message: <47baa43d$1@news.povray.org>
who can consult me? I want to create a scene named "The Magnificent men in
their Flying Machines", which contains a number of wicked airplanes and
want-to-be-airplanes. Most of them have canvas over the wooden framework.
While I have already a graphic file I can use for the canvas texture, I am
still in need of some consulting: the cancvas you get to see on vintage
airplanes is slightly transluscent, means, if you see such an airplane in
the air and you're below it, through the sunlight you can get an idea of the
wooden framework below the canvas. I need your advices how best to achieve
such an effect. To make it even a bit more difficult, the canvas seems to
blur the edges of the wooden framwork below it, in its slightly transluscent
effect. How to achieve that little blur effect?
Thanks,
Sven
Subject: Re: Texture: Canvas (slightly Transluscent)
Date: 19 Feb 2008 07:40:05
Message: <47bace25@news.povray.org>
Sven Littkowski napsal(a):
> Hi,
> Thanks,
> Sven
use a blurred refraction:
-make it solid
-give it IOR
-use multiple pigment{Clear} normal{bumps} layers
-add the canvas itself
It's slow but it might work
Date: 19 Feb 2008 14:25:14
Message: <47bb2d1a$1@news.povray.org>
Jan Dvorak nous apporta ses lumieres en ce 2008/02/19 07:39:
>> Hi,
>> men in their Flying Machines", which contains a number of wicked
>> airplanes and want-to-be-airplanes. Most of them have canvas over the
>> wooden framework.
>> I am still in need of some consulting: the cancvas you get to see on
>> vintage airplanes is slightly transluscent, means, if you see such an
>> airplane in the air and you're below it, through the sunlight you can
>> get an idea of the wooden framework below the canvas. I need your
>> advices how best to achieve such an effect. To make it even a bit more
>> difficult, the canvas seems to blur the edges of the wooden framwork
>> below it, in its slightly transluscent effect. How to achieve that
>> little blur effect?
>> Thanks,
>> Sven
> -make it solid
> -give it IOR
Don't use to many, each ray will be affected by two surfaces.
But I thought YOU did the backups...
Date: 19 Feb 2008 14:47:03
Message: <47bb3237$1@news.povray.org>
Thanks, Jan and Alain! I appreciate your help a lot!
I use POV-Ray since around 1993 or so. Long time. But I used, up to now,
only relatively simple techniques. I would like to ask you two to give me
some sample code for a basic box, which should have these attributes. The
reason is, I was reading your suggestions but still don't know, how to
follow them up.
Let it be a thin sample box, resembling some canvas:
box
 < 0.0, 0.0, 0.0 > < 0.0, 0.0, 0.0 >
Let's assume the the name for the canvas texture graphic file would be
"Canvas.png".
Thanks for your help again,
Sven
"Sven Littkowski" <sven [] jamaica-focus [] com> schrieb im Newsbeitrag
news:47baa43d$1@news.povray.org...
> Hi,
> the wooden framework below the canvas. I need your advices how best to
> achieve such an effect. To make it even a bit more difficult, the canvas
> seems to blur the edges of the wooden framwork below it, in its slightly
> transluscent effect. How to achieve that little blur effect?
> Thanks,
> Sven
Date: 19 Feb 2008 14:56:31
Message: <47bb346f$1@news.povray.org>
> box
That is a zero-sized box. An invisible point.
Date: 19 Feb 2008 16:17:18
Message: <47bb475e$1@news.povray.org>
Thanks, Jan, Nicolas and Alain! I appreciate your help a lot!
follow them up.
Let it be a thin sample box, resembling some canvas (corrected version):
box
 < -10.0, -1.0, 0.0 > < 10.0, 1.0, 0.005 >
"Canvas.png".
Sven
Date: 19 Feb 2008 16:50:23
Message: <47bb4f1f@news.povray.org>
> follow them up.
> box
> "Canvas.png".
> Sven
see http://tag.povray.org/povQandT/languageQandT.html#blurredreflection
I haven't tried it myself but I could if you want me to.
Date: 19 Feb 2008 17:00:10
Message: <47bb516a@news.povray.org>
to be exact, the times don't add up. they multiply.
Date: 19 Feb 2008 18:00:01
Message: <47bb5f71$1@news.povray.org>
Jan, it might be I have to ask you to give me a sample canvas. I was reading
the link you provided, but this all sounds a bit Chinese to me. I never used
those techniques before, not even the NORMAL feature.
All I know is, that I would go for the small scale (0.001), since I need a
high antialiasing and a high speed.
Thanks a lot, I appreciate your help very much! Shall I name one of these
wicked vintage airplanes with your name?
Here the canvas box and a thin wooden board behind.
box
box
  < -10.0, -0.025, 0.005 > < 10.0, 0.025, 0.055 >
Greetings,
Sven
"Jan Dvorak" <jan### [at] centrumcz> schrieb im Newsbeitrag
news:47bb4f1f@news.povray.org...
>> follow them up.
>> box
>> "Canvas.png".
>> Sven
Date: 19 Feb 2008 18:02:00
Message: <47bb5fe8$1@news.povray.org>
Correction: here it is again. Just the upper box needs to be modified.
box   // Canvas
box   // Wooden Frame
 pigment {  Brown }
