POV-Ray : Newsgroups : povray.general : POV-Ray: Photons: save_file: Continue? Server Time
23 Dec 2025 01:04:58 EST (-0500)
  POV-Ray: Photons: save_file: Continue? (Message 1 to 9 of 9)
Subject: POV-Ray: Photons: save_file: Continue?
Date: 26 Jan 2008 18:25:47
Message: <479bc17b@news.povray.org>
Hi.
Here is my question:
Since around 3 days, POV-Ray (Windows version) rendered a file with photons.
I used the option "save_file "HeliChopper 02 Gray Fleet on Ground.ptn".
Since those 3 days, POV creates the photon map. Now I had a power cut, and
would like to know, if there is an option to continue the photon map file
building, where it stopped, similar to the "+c" option for the raytracing
itself.
If for some reason there is not yet such an option, I would herewith suggest
this feature with a big urgence.
Thanks.
Sven Littkowski
Subject: Re: POV-Ray: Photons: save_file: Continue?
Date: 26 Jan 2008 18:43:03
Message: <479bc587@news.povray.org>
> itself.
The file is saved only when the whole photon shooting finishes. If you
have a file on disk, then it's complete (unless the power cut was while
the file was being written, unlikely).
Date: 26 Jan 2008 19:06:44
Message: <479bcb14$1@news.povray.org>
Your answer hits my worst fears: after three days working on a photon file
which has not yet been saved, all is lost!
My question is: why allows POV a scene to be continued, but not a photon
file?
Please, developers, create the possibility to also continue the photon map
file after a stop (of which reason ever). POV-Ray partially writes data into
an image, so it can continue where the previous render was stopped. Could
the same procedure of partial writing into a file not be applied to the
photon file, as well?
THIS IS A FEATURE REQUEST.
Sven
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> schrieb im
Newsbeitrag news:479bc587@news.povray.org...
>> photons. I used the option "save_file "HeliChopper 02 Gray Fleet on
>> Ground.ptn". Since those 3 days, POV creates the photon map. Now I had a
>> power cut, and would like to know, if there is an option to continue the
>> photon map file building, where it stopped, similar to the "+c" option
>> for the raytracing itself.
Date: 26 Jan 2008 19:46:18
Message: <479bd45a$1@news.povray.org>
> file?
Note that when saving a PNG image, the file is only flushed to disk
every 16 lines. Probably it's also updated when you pause the render;
but that won't happen on a power failure, so you could lose your last 15
lines :)
In the case of photons, it looks like they are "sorted" (whatever that
means) when the photons finish shooting. And *then* they get saved. I
see no reason why it couldn't save the photons as they get calculated,
then sort them and overwrite the whole file with the sorted version, so
that if the render gets suspended before it's done, it could in theory
load from the file, shoot what's left, and sort the whole thing. But I
know little about the internals of how photons work, so there may be a
good reason why it's not done this way.
PS: what are your computer specs? If mine turns out to be better than
yours, I could give you some CPU time for that insane render.
Date: 26 Jan 2008 20:03:29
Message: <479bd861$1@news.povray.org>
YES!!! That would be fine! In addition, you would be free to use the items
inside there for your own scenes, I do not mind.
Specs:
- Intel Pentium DualCore 3.06 GH CPU
- 2,048 MB RAM (2 GB RAM)
- Scene File Output Resolution: 3,200 x 2,400 pixels
Do you know about "Render Farm" software?
Sven
Newsbeitrag news:479bd45a$1@news.povray.org...
>> file which has not yet been saved, all is lost!
>> file?
>> map file after a stop (of which reason ever). POV-Ray partially writes
>> data into an image, so it can continue where the previous render was
>> stopped. Could the same procedure of partial writing into a file not be
>> applied to the photon file, as well?
> Note that when saving a PNG image, the file is only flushed to disk every
> 16 lines. Probably it's also updated when you pause the render; but that
> won't happen on a power failure, so you could lose your last 15 lines :)
> means) when the photons finish shooting. And *then* they get saved. I see
> no reason why it couldn't save the photons as they get calculated, then
> sort them and overwrite the whole file with the sorted version, so that if
> the render gets suspended before it's done, it could in theory load from
> the file, shoot what's left, and sort the whole thing. But I know little
> about the internals of how photons work, so there may be a good reason why
Date: 26 Jan 2008 21:02:54
Message: <479be64e@news.povray.org>
items inside there for your own scenes, I do not mind.
 > Specs:
My computer is an AMD Dual Core 4200+ 2.20GHz, 2GB of RAM. So I guess
it's slower... And I think I have higher chance of a power outage than you.
*I have a renderfarm* currently hosted on IMP (Internet Movie Project)
server. There's somebody attached with some 8-core machines! Although he
has some powerful Macs, and I never got round to compiling POV-Ray (with
my patches) for Mac, so there's some unused power.
http://impfarm.imp.org/boinc/hosts_user.php?userid=36
One problem is that photon mapping *can't* be distributed, in the sense
that we can't lower the time it takes by throwing more computers into
it. At least not without modifying POV source in areas I wouldn't dare
touch. Although, even if it was possible, it would need a lot of network
bandwidth for all computers to exchange the parts of the photon map they
computed, before doing the render...
So, each computer would need to compute the photon map completely. And
since it can't be resumed, that may be a problem for some users who
wouldn't keep their computers running for 6 days...
<PovAddict> somebody on povray newsgroups has a scene that takes 6 days
to do a pre-computation that cannot be resumed, I'm wondering if it
would be acceptable for imp@home to have WUs that spend 6 days computing
without being able to checkpoint at all
<KathrynM> are you crazy?
<PovAddict> :D
<Rookie_69> That's why he comes here.
Hmm yeah it may be a problem.
And then there is the RAM usage. POV-Ray keeps the whole photon map
loaded in RAM. There are sub-2GB machines that won't be able to
participate. Plus, are you sure exactly how much memory the scene will
use? I think that's impossible to know without computing the whole
photon map and checking the statistics at the end of the render.
PS: I tried to email you, removing the obvious anti-spam measures, but
it immediately bounced back, saying "invalid address".
Date: 26 Jan 2008 23:33:03
Message: <479c097f$1@news.povray.org>
So rent one of Amazon's machines for a week. Probably $20 or so. :-)
     On what day did God create the body thetans?
Date: 26 Jan 2008 23:55:00
Message: <479c0ea4@news.povray.org>
Hi Darren,
can you give me some details about those Amazon machines? How and where to
gain more information on that? How to contact that company?
Thanks,
Sven
"Darren New" <dne### [at] sanrrcom> schrieb im Newsbeitrag
news:479c097f$1@news.povray.org...
>> to do a pre-computation that cannot be resumed, I'm wondering if it would
>   Darren New / San Diego, CA, USA (PST)
Date: 27 Jan 2008 00:22:42
Message: <479c1522$1@news.povray.org>
Go to www.amazonaws.com. (That's Amazon's Web Services, see...)
On the left edge, they list all the web services they supply. Two are
most notable for people not doing electronic commerce stuff:
The Amazon Simple Storage Service (also known as S3) lets you store
arbitrary amounts of data out on Amazon's servers for small amounts of
money (relatively speaking). There are a number of client libraries and
programs that make it easy to get to it, and so on. (Jungle Disk is
decent, if you want something that works better than a demo and you want
to treat the storage like a disk.)
The Amazon Elastic Compute Cloud (also known as ECC) allows you to start
up a machine running Linux, load it with an operating system stored on
Amazon S3 (either by you, by Amazon, or by someone else making their
OS-configuration available to you), and run it. They ten cents per hour
per CPU (about a 1.x GHz CPU IIRC). You can also rent multi-CPU
configurations for a multiple of that. (Actually, it used to be twenty
cents per hour - I wonder what happened.)
It's really pretty easy to set up compared to anything else I've seen.
You need to have access to SSH (such as putty under Windows). Getting
the Java command-line stuff working with the right environment variables
was the hardest part. Once you manage to fire up an "instance" and get
yourself logged in, it's just a normal remote computer running Linux.
Follow carefully the instructions in the "getting started" tutorial and
you'll be online in half an hour.
If you want to do something manually, you can just fire up a machine,
remote login, scp povray onto it, start it up, and when it finishes,
copy the results off and shut down the machine.
I've also written a programm I call "oddjob" that lets you set up a
collection of jobs to be done (e.g., povray image traces for an
animation), and the program will coordinate N different machines all
peeking into the list of jobs, pulling down the data files, running the
program, and storing the data files back into S3, and then shutting down
the machines as the number of jobs runs out.  I haven't released it yet,
but only because I haven't had time to set up any sample ECC "images."
I.e., the program works, but actually firing up the Amazon computers is
still manual. I'm happy to share the code with you, but it's not really
targeting what you're talking about here, which is something that's hard
to distribute amongst multiple machines.
Paying for it is as easy as paying for something you order from Amazon.
You even use the same account you already have with them, and just pick
how you want them to bill your credit card at the end of the month. If
your credit card is funky, be aware they *will* actually charge you
three cents if that's how much of their services you use. Kind of
strange, but I guess they do enough traffic to get special contracts
with their Visa and Mastercard providers and all[*].
[*] Or they bought their own bank, which was one of the suggestions made
by an investor early in my career. When everyone at the table twitched,
he added "you can get some small banks quite reasonably these days."
