![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello,
I was wondering if there is a way of producing blur effects on a pigment
(procedural or image map). I have been playing with the turbulence warp
and got close results using the code below with image maps.
warp{
turbulence <0.5,0.5,0.5>*0.005
octaves 6
omega 1.5
lambda 50
Unfortunately it requires quite a strong anti-aliasing setting for
acceptable results. It works better if colors are not too dissimilar. I
know that for image maps I can take it into a graphics editor and blur
the image but I would like to know if there is a proven method of
blurring pigments that can be done within POV-Ray. Specially if the
pigment is procedural.
Other variations of the warp above are useful for weathering effects on
pigments.
later,
FlyerX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Couldn't you use the average of a pigment with its copy slightly moved?
Come to think of it, you could use any number of copies all moved
differently.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> differently.
Very good idea, thanks. It actually works. I did not think about
average. Here is a simple code I typed for this
material{
texture{
pigment{
average pigment_map{
#declare r=seed(0);
#declare max_blur_amount=0.05; //as a fraction of 1.0
#declare n=50; //number of samples
#declare c=0;
#while (c<n) //loop n times
[1.0 image_map{sys "90.bmp" interpolate 2}
translate<rand(r),rand(r),rand(r)>*max_blur_amount]
#declare c=c+1;
I hope I can put it as a macro so I can call it as a special pigment.
thanks again,
FlyerX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> differently.
And here is the average with some Gaussian blurring
material{
texture{
pigment{
#declare r=seed(0);
#declare n=100; //number of samples (gets slow above 10)
#declare sigma=0.015;//as a fraction of 1.0
#declare max_blur_amount=sigma*3;//spread only 3sigmas out
#declare c=0;
#declare dist=<rand(r),rand(r),rand(r)>*max_blur_amount;
#declare
gauss=(1/2/pi/pow(sigma,2))*exp(-(pow(dist.x,2)+pow(dist.y,2)+pow(dist.z,2))/(2*pow(sigma,2)));
[gauss image_map{sys "90.bmp" interpolate 2 } translate dist]
#declare c=c+1;
later,
FlyerX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> differently.
That's what I do. I average a 2x2 to 8x8 copy of the pigment, depending
on the requirements of the image. For some projects I've made a blurred
image from the regular image and used that as the pigment.
I've also experimented with setting the anti-aliasing level to 4x4
samples per pixel, a threshold of zero, and jitter set to one. This
takes a bit of time (but not too much), and allows certain other
settings (such as area lights) to be set to lower levels and still
achieve the same quality.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You welcome. And thanks for the examples I copied them and put them in
my snipit file.
Have fun!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
