![](/i/fill.gif) |
I've monkeyed about trying to get the right look the past couple weekends
and have stumbled upon something I'm happy with and would like to share.
The solution i've found is 2 spheres, the skysphere, for the sky itself,
and another sphere properly textured for the clouds.
It's a fairly simple solution that doesn't rely on the built in pigments and
questionable color mapping and provides, I think, more realistic results
pretty quick and easy.
Now it's the inner cloud sphere that proved tricky, but my solution is this.
I found a number of cloud transparency maps on the internet for renders of
earth from space. I manip and use them for the transparency and then crop
and manip actual cloud photos for the color part of the texture. Then I can
rotate the cloud sphere and get any variety of sky I like.
Here are my skysphere settings for 4 distinct times of day. Of course you
can adjust the gradient to suit your own purposes, but the colors were
pulled and averaged from a number of photos, so they're pretty accurate:
// SKYSPHERE CODE
//Sunrise
sky_sphere {
gradient y
color_map {
[(1-cos(radians(20)))/2 color rgb <1,0.552941176,0.184313725>]
[(1-cos(radians(60)))/2 color rgb
<0.474509804,0.525490196,0.62745098>]
[(1-cos(radians(90)))/2 color rgb
<0.196078431,0.329411765,0.580392157>]
//Daysky
sky_sphere {
gradient y
color_map {
[(1-cos(radians(50)))/2 color rgb <0.6,0.721568627,0.764705882>]
<0.482352941,0.674509804,0.839215686>]
<0.364705882,0.584313725,0.803921569>]
//Overcast
sky_sphere {
gradient y
color_map {
<0.835294118,0.831372549,0.811764706>]
<0.749019608,0.756862745,0.760784314>]
<0.62745098,0.623529412,0.631372549>]
//Nightsky
sky_sphere {
gradient y
color_map {
[(1-cos(radians(30)))/2 color rgb
<0.254901961,0.290196078,0.48627451>]
[(1-cos(radians(45)))/2 color rgb
<0.141176471,0.17254902,0.294117647>]
<0.133333333,0.137254902,0.207843137>]
// END SKYSPHERE CODE
![](/i/fill.gif) |
![](/i/fill.gif) |
Wouldn't using a plane for the clouds be easier?
![](/i/fill.gif) |
![](/i/fill.gif) |
"fls13" <fls### [at] netzero net> schreef in bericht
news:web.46d0f0a38ed03b7599f93230@news.povray.org...
>> - Warp
> Depends on what your goals are. A slight rotation of the clouds sphere
> gives
> a completely different look and when you combine that with the variations
> in
> the skyspheres, for me, it's quick and easy to get whatever and exactly
> what
> you want.
In cases like these, I generally use flatened spheres for the clouds. Only
problem is the horizon, but that is often hidden by either haze or
topography/buildings.
Thanks for the code by the way!
![](/i/fill.gif) |
![](/i/fill.gif) |
> Depends on what your goals are. A slight rotation of the clouds sphere gives
> a completely different look and when you combine that with the variations in
> the skyspheres, for me, it's quick and easy to get whatever and exactly what
> you want.
You can achieve the same thing with a translate on the plane.
The problem with using a sphere is that you need to make it really
large and put its origin very far away (below) the camera for it to
look realistic, and objects that large might present rendering artifacts
due to limits in the floating point calculations.
One common mistake (even present in the povray documentation) is to
center the could sphere at the camera. This, of course, makes no sense
and doesn't even begin to simulate real clouds. Real clouds are not
located on the surface of a sphere centered at the viewer's location.
![](/i/fill.gif) |
![](/i/fill.gif) |
46d12e49@news.povray.org...
But if the farthest (and invisible) parts of the sphere are very far, the
rendered parts are at reasonable distance, aren't they?
Marc
![](/i/fill.gif) |
![](/i/fill.gif) |
So? It doesn't matter how close to the sphere's surface the camera is.
If its center is very far away and the radius is very large, it has
potential for artifacts.
![](/i/fill.gif) |
