POV-Ray : Newsgroups : povray.general : Can I watch variables after parsing for scene debug purposes? Server Time
27 Feb 2026 19:00:43 EST (-0500)
  Can I watch variables after parsing for scene debug purposes? (Message 1 to 9 of 9)
Subject: Can I watch variables after parsing for scene debug purposes?
Date: 21 Mar 2007 11:18:04
Message: <46015abc@news.povray.org>
Hi!
Is it possible to get variable content as an output after parsing a
scene for debug purposes?
regards
Hardy
Subject: Re: Can I watch variables after parsing for scene debug purposes?
Date: 21 Mar 2007 11:34:21
Message: <46015e8d@news.povray.org>
  Which variables?
Date: 21 Mar 2007 11:52:15
Message: <460162bf$1@news.povray.org>
Warp wrote:
>   Which variables?
Different identifiers that are changed e.g. in animations of recursive
structures. In most cases I need the current vectors or colors of
certain frames if possible as text output while the scene is rendered...
regards
Hardy
Date: 21 Mar 2007 11:55:03
Message: <web.460162ff12b31897e94cc5130@news.povray.org>
> Hi!
> regards
> Hardy
I don't know about truely *after* but you can always convert things like
floats to strings and then put your #debug statements where they'll get
parsed right at the end of the parsing stage.  Or you can put those strings
into in-scene text objects.  Do you need it to be truely after?
Date: 21 Mar 2007 14:50:01
Message: <web.46018b9c12b318975a5a69050@news.povray.org>
> Warp wrote:
> >   Which variables?
> regards
> Hardy
How about having your scene write the info you want to a text-file.  The
file
should be there as soon as the scene has finished parsing and you can read
it while the render takes place
Date: 21 Mar 2007 17:46:46
Message: <4601b5d6$1@news.povray.org>
> file
Yes, that would be great. As FrogRay wrote I have to convert the
identifier to a string and then write it to the log using #debug. Is
that right?
regards Hardy
Date: 21 Mar 2007 19:00:02
Message: <web.4601c5a912b31897e33c01c00@news.povray.org>
> > file
> that right?
> regards Hardy
Yes, you'll still want to turn things into floats, (str() vstr() concat()
etc).   For file writing I think you can direct the #debug stream to a file,
but  I think Frogray was suggesting to use POV-Ray's file-i/o capabilities,
i.e. #fopen and #write instead of #debug.
Charles
Date: 21 Mar 2007 19:40:31
Message: <4601d07f@news.povray.org>
Erhard Ducke nous apporta ses lumieres en ce 21-03-2007 18:46:
>> file
> that right?
> regards Hardy
It can be done that way, or you can create your own file.
Use #open #write and #close to open/create the file, write values and close the
file when you are finished filling it.
A clear conscience is usually the sign of a bad memory.
Date: 23 Mar 2007 06:25:43
Message: <4603b937@news.povray.org>
I think i'm now able to manage my problem...
Thanks for your time and brain!
regards Hardy
