POV-Ray : Newsgroups : povray.general : Post Scene Command shell out won't work in windows Server Time
31 Jul 2024 14:21:32 EDT (-0400)
  Post Scene Command shell out won't work in windows (Message 1 to 10 of 13)
Subject: Post Scene Command shell out won't work in windows
Date: 12 Mar 2007 11:45:02
Message: <web.45f5826d5c0f32344af8c2570@news.povray.org>
Hello,
I'm trying to do some manipulation on the result of the pov-ray rendered
image.
I fill the Povray.ini file in the render folder with the line:
Post_Scene_Command=c:RogerrenameFile.bat
After the image rendering has finished I get in the povray main window two
lines saying:
POV-RAY is creating another process
and then Pov-Ray stops without starting the bat file. I've already try to
change the call in the ini file to:
Post_Scene_Command="c:RogerrenameFile.bat"
Post_Scene_Command=command /C c:RogerrenameFile.bat
without any success.
I'm working in a Windows XP SP2 machine.
Does anyone have a idea how to fix this problem ??
Thanks
roger
Subject: Re: Post Scene Command shell out won't work in windows
Date: 12 Mar 2007 13:33:21
Message: <v27bv2pklb8nvmc18ian1747drq72tp06m@4ax.com>
On Mon, 12 Mar 2007 11:40:13 EST, "roger" <nomail@nomail> wrote:
>Hello,
>image.
>lines saying:
>Thanks
>roger
This has given me trouble in the past look for the thread
Post_Frame_Command Troubles
dated
03 Sep 2004
in povray.general
I seem to remember that I could not solve my original problem and had to use the
pre scene command which worked.
Regards
Date: 12 Mar 2007 15:35:01
Message: <web.45f5b94591a0c41cca4075b80@news.povray.org>
> I've already try to
I don't know anything about that command, but aren't you missing a backslash
in the address to the bat file? i.e. c:RogerrenameFile.bat
Date: 12 Mar 2007 15:50:02
Message: <web.45f5bbeb91a0c41cca4075b80@news.povray.org>
> dated
> 03 Sep 2004
> in povray.general
> Regards
>  Stephen
Hmm, "Your search - Post_Frame_Command Troubles - did not match any
documents." :-(
But I found it the old fashioned way:
http://news.povray.org/povray.general/thread/%3Cijthj0tohdj1ldlqus8gilon0kkamhd2t7%404ax.com%3E/?ttop=239800&toff=1300&
mtop=199954
Date: 12 Mar 2007 18:11:40
Message: <45f5de2c$1@news.povray.org>
Grassblade nous apporta ses lumieres en ce 12-03-2007 16:34:
>> I've already try to
The web forum have a tendency to drop the backslash "\".
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
An Hourglass is Female, because over time, the weight shifts to the bottom.
Date: 12 Mar 2007 22:26:38
Message: <45F627CB.6030304@joplin.com>
> lines saying:
What version of POV do you use?
I had win98 with POV3.6
And had the same problem, never did get it right.
I tried every combination in the Post_Scene_Command statement
that I could think of. Tried moving my taget file into the same
directory as POV'exe.
  As last resort I even posted here. But no one seem to want to tackle
this problem.
Good Luck!
Have Fun!
Date: 13 Mar 2007 06:25:02
Message: <web.45f6896091a0c41c8790798d0@news.povray.org>
> >Hello,
> >image.
> >lines saying:
> >Thanks
> >roger
> dated
> 03 Sep 2004
> in povray.general
> Regards
>  Stephen
I've looked at all the posts related with this issue and I see no solution
for it. Should I open a bug report? Does anyone know how to do it?
Date: 13 Mar 2007 06:30:01
Message: <web.45f68ac491a0c41c8790798d0@news.povray.org>
Leroy <lrw### [at] joplincom> wrote:
> > lines saying:
> this problem.
> Good Luck!
> Have Fun!
I'm using Pov 3.6. With Pov 3.5 it worked fine.
I've tried all the options I remember, without any success.
The most strange thing about it is that in the Pov console i get the two
POV-RAY is creating another process.
Strange thing ..... :-S
Roger
Date: 13 Mar 2007 06:40:01
Message: <web.45f68d0491a0c41cf1cb1e660@news.povray.org>
> > Regards
> >  Stephen
I think it would be a good idea to report it but first check the FAQ.
http://news.povray.org/povray.announce.frequently-asked-questions/thread/%3Cfpupiu02i1198jbb38i3o06hv6is1a3uar%404ax.co
m%3E/
There is a group for reporting bugs and instructions in the help file. Sorry
Date: 13 Mar 2007 16:15:01
Message: <web.45f7134691a0c41ceee1bc430@news.povray.org>
> > > Regards
> > >  Stephen
co
> m%3E/
> Stephen
Thank you very much for your help. I'll open the bug report, after all it's
my problem .... :-)
Roger
