POV-Ray : Newsgroups : povray.general : Distributing patch objects Server Time
14 Oct 2025 00:08:33 EDT (-0400)
  Distributing patch objects (Message 1 to 4 of 4)
Subject: Distributing patch objects
Date: 14 Feb 2007 01:17:25
Message: <45d2a975$1@news.povray.org>
I currently have a grass object defined as a mesh which I tile
repeatedly over an area.  The placement of the object is random within
this area, meaning some areas are more densely covered than others (a
very nice effect, I think).  However, the problem comes at the edge of
the area I want covered.
I have a box {MIN, MAX} that I place the grass mesh in multiple times.
Originally, I adjusted the boundaries of the area I used so that no
grass would be outside of this box.  This was quite fast, as my scene
would render in less than a minute (it took about 3 minutes to parse,
but there's a lot of other stuff going on as well).  Unfortunately, it
meant that portions along the side were very likely to not have any
grass at all.
My next attempt was to have a more generous area to place the grass in,
letting portions of the mesh fall outside of my bounding area.  I then
ran a check at parse time to see if the mesh did indeed cross over the
boundary; if it did, then it would be clipped to the boundary area.  If
it fell inside the boundary completely, no clipping would occur.
This was much more satisfactory, and had exactly the effect I wanted,
but took more than 45 minutes to render (compared to less than 1,
before).  I was surprised that clipping caused such a problem.
I have not yet reduced the problem to a simpler scene, but has anyone
else encountered a problem similar to this?
...Chambers
PS I should note that I am using the current 3.7 beta; I'll try to make
the attempt with 3.6 later and see what effect that has on things.
Subject: Re: Distributing patch objects
Date: 14 Feb 2007 15:36:58
Message: <45d372ea@news.povray.org>
Testing with 3.6 reveals the same dramatic slowdown.  I'm now trying to
reduce the scene to the simplest form possible which still retains this
dramatic decrease in speed.
...Chambers
Date: 14 Feb 2007 16:27:08
Message: <45d37eac$1@news.povray.org>
Well, I've reduced it as much as possible.  Render times are 30s for the
unclipped version, and 50s for the clipped version on a test scene.
Doesn't seem too bad, until you realize that generating the mesh during
the parse takes 20s on its own, the so render times now seem to be 10s
and 30s.  A 3x slowdown seems quite abnormal to me.
However, in examining the test I was doing, it is entirely possible that
the clipped version is simply rendering more detail (since it shows
grass up to the border), and that is the cause for the slowdown.  I
suppose this would be minimized when there's a greater area which does
not intersect the border, so I'll test with that.
I'll post my scene and include file (note that the include file has a
limited texture applied, for the actual scene I'm working on I use a
more varied texture) in p.b.scene-files, as well as two sample shots in
p.b.images.
...Chambers
Date: 14 Feb 2007 16:41:23
Message: <45d38203$1@news.povray.org>
A further test confirmed, that a scene where 90+% of the visible grass
is not intersecting the border results in only an 8% slowdown in trace
time.  I guess the problem all along was the large proportion of space
edges in my scene; that is, in my scene a lot of grass patches intersect
the area boundaries, meaning more computations are needed.
Sorry to bother everyone, this has been a fun little dialogue by myself
:)  Of course, if anyone can think of another way to speed up this
thing, I'd very much like to hear it.
...Chambers
