POV-Ray : Newsgroups : povray.general : "Whiten" an image_map? Server Time
28 Feb 2026 02:02:15 EST (-0500)
  "Whiten" an image_map? (Message 1 to 4 of 4)
Subject: "Whiten" an image_map?
Date: 3 Oct 2006 11:09:32
Message: <45227d2c$1@news.povray.org>
Maybe this is blindingly obvious, but I can't seem to see through the
problem.  I've got an image_map applied to an object, but the colors are
coming out too dim.  My 'white' isn't as white as I'd like.  So... how do I
essentially set the image_map color range to be > 1?  Normally, with a solid
pigment color, you'd just write:  pigment {color rgb <1,1,1>*3} or some
such.  But how is this to be done with image_maps?
The code looks something like this:
#declare WhiteTex =
    image_map {
      jpeg "mywhitepic.jpg"
      map_type 1
#declare MyTransMat =
material {
    image_pattern { jpeg "mytransparentmask.jpg" use_alpha map_type 1}
    texture_map {
      [0 WhiteTex ]
      [1 pigment { transmit 1 } ]
Er, am I being silly?
- How
Subject: Re: "Whiten" an image_map?
Date: 3 Oct 2006 11:35:01
Message: <web.45227e787249d82b2e3296b70@news.povray.org>
Not really :)
Have you tried specifying a finish? Povray gives every material a standard
finish of ambient 0.1, diffuse 0.6 if not specified. Try to increase these
settings according to your situation.
Note that ambient makes the material "glow" and may not look
realistic, especially in radiosity situation.
Diffuse controls how much light is reflected from the surface, can become to
bright in a situation where there is a bright light hitting the surface.
I usually use ambient 0.0 and diffuse 0.9-1.0 in a radiosity situation.
the ambient at default and try increase diffuse. Then again all this
depends on how you intend to use the material. If you want the glow effect
then increase ambient as well.
This goes for all sorts of materials, solid colors, patterns and bitmaps.
Hildur Kolbrun
Date: 3 Oct 2006 11:40:00
Message: <web.4522836b7249d82b731f01d10@news.povray.org>
Try increasing the diffuse value in finish { }. The default is only 0.6.
Bill
Date: 3 Oct 2006 12:08:40
Message: <45228b08$1@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:web.4522836b7249d82b731f01d10@news.povray.org...
Excellent!  Thank you both (Bill and Hildur).  Somehow, all these years and
I've missed the significance of the diffuse keyword.  Back to POV-Ray 101
for me...
Thanks!
- How
