POV-Ray : Newsgroups : povray.general : Union{} problem Server Time
31 Jul 2024 22:16:39 EDT (-0400)
  Union{} problem (Message 1 to 3 of 3)
Subject: Union{} problem
Date: 3 Sep 2006 21:55:45
Message: <44fb87a1$1@news.povray.org>
Hello,
POV-Ray 3.6.1 / WinXP
When I use union{} with several mesh2 objects that may be intersecting
the render always ends with bright edges where the mesh intersections
are. The only way to avoid this that I know of is to add split_union off
at the end of the union{}. Using this flag the render is fine but the
problem is that it does not let any of the individual mesh objects to
have no_shadow properties of their own.
Here are two images showing the issue. Look at the knees and left hip.
http://mysite.verizon.net/sfg0000/images/split_union_on.png
http://mysite.verizon.net/sfg0000/images/split_union_off.png
I am sure I do not know what I am doing but the documentation is lacking
on detailed information about this. Any insight will be appreciated.
later,
FlyerX
Subject: Re: Union{} problem
Date: 3 Sep 2006 23:05:30
Message: <44fb97fa$1@news.povray.org>
This is a variation of the coincident surfaces problem.
A mesh has no inside, (unless you declare one with
inside_vector) so at the joins sometimes the rays
"see thru". If you add inside_vector to your meshes
it'll look fine.
Date: 3 Sep 2006 23:49:31
Message: <44fba24b@news.povray.org>
> it'll look fine.
That worked. I just added inside_vector<0,0,1> at the end of all meshes.
Thanks.
FlyerX
