POV-Ray : Newsgroups : povray.general : Strange behaviour on cubic_spline Server Time
10 May 2026 21:36:15 EDT (-0400)
  Strange behaviour on cubic_spline (Message 1 to 5 of 5)
Subject: Strange behaviour on cubic_spline
Date: 11 Mar 2006 07:00:40
Message: <4412bbe8@news.povray.org>
Hi all.
I noted a strange behaviour on cubic_spline when I define paths with the
spline  keyword. In previous version of Pov-Ray the first and last
points of the spline were to set the tangent of the second and the last
but one point. So the first and last "stretchs" between first-second and
last but one-last points were straight.
In 3.6 version this is not this way so, why this behaviour on the new
version or am I wrong ?
Thanks. See ya.
Subject: Re: Strange behaviour on cubic_spline
Date: 13 Mar 2006 05:57:48
Message: <4415502c$1@news.povray.org>
"Manuel Mata Rueda" <man### [at] yahooes> wrote in message
news:4412bbe8@news.povray.org...
> Hi all.
> spline  keyword. In previous version of Pov-Ray the first and last points
> of the spline were to set the tangent of the second and the last but one
> point. So the first and last "stretchs" between first-second and last but
> Thanks. See ya.
Hi Manuel,
With a cubic_spline the first and last points are just control points and
don't actually get displayed. Whilst I haven't used cubic_splines much in
POV-Ray my recollection is that POV-Ray has always been that way, so you
don't get a straight line at the ends because you don't get any line at the
ends, the shape starts at the second point and ends at the last-but-one
point. As you say these control points form tangents to the start and end of
the curve.
If you think you've found something odd with the behaviour of the
cubic-spline in 3.6, maybe post a short snippet of SDL to illustrate your
concern.
Chris B.
Date: 13 Mar 2006 16:52:50
Message: <4415e9b2$1@news.povray.org>
> concern.
I'll post some code here down here. I'll explain it.
There are 4 points forming a path like a rectangle and 3 splines.
The yellow one is a closed cubic_spline.
With the green one I try to make a closed spline with straight stretchs,
so I make 4 splines to build it, 2 linear_splines and 2 cubic_splines.
The points should be tangent but they aren't. If you see the 2
cubic_splines definition they only define a stretch and have 2 control
points who should define the tangents at the points.
The blue spline is a simple cubic_spline. I try to draw it fully, from
the first definition point to the last, but it only draws from the
second to the last but one as you said before.
You can use camera 1 and 2 with the 'c' var at the end of the code to
see the tangents. Here is the code.
I think I'm not doing anything badly ...
#version 3.6;
light_source{<0, 100, 0> White*1.5 parallel point_at <0,0,0>}
plane{y,0 pigment{checker White,Gray75}}
//axis
cylinder{0 x*100 0.1 pigment{Red}}
cylinder{0 z*100 0.1 pigment{Blue}}
//s: spline
//i: first point to draw
//j: last point to draw
//step: interval to place the object
//o: object to place (usually a sphere)
#macro drawSpline(s,i,j,step,o)
   union{
   #local counter = i;
   #while (counter <= j)
     object{o translate s(counter)}
     #local counter = counter + step;
//objects to draw splines
#declare yellowSphere = sphere{y*1 0.2 pigment{Yellow}}
#declare greenSphere = sphere{y*2 0.1 pigment{Green}}
#declare blueSphere = sphere{y*3 0.05 pigment{Blue}}
//points of spline
#declare p0 = <-6,0,4>;
#declare p1 = < 6,0,4>;
#declare p2 = < 6,0,-4>;
#declare p3 = <-6,0,-4>;
//red spheres to see the spline path
sphere{p0 0.3 pigment{Red}}
sphere{p1 0.3 pigment{Red}}
sphere{p2 0.3 pigment{Red}}
sphere{p3 0.3 pigment{Red}}
//splines
//from 0 to 3
#declare yellowSpline = spline{
cubic_spline
-1  p3,
0   p0,
1   p1,
2   p2,
3   p3,
4   p0,
5   p1
//from 0 to 1
#declare greenSpline_00 = spline{
linear_spline
0  p0,
1  p1,
//from 1 to 2
#declare greenSpline_01 = spline{
cubic_spline
0 p0,
1 p1,
2 p2,
3 p3
//from 2 to 3
#declare greenSpline_02 = spline{
linear_spline
2  p2,
3  p3,
//from 3 to 4
#declare greenSpline_03 = spline{
cubic_spline
2 p2,
3 p3,
4 p0,
5 p1
object{drawSpline(yellowSpline,0,4,0.005,yellowSphere)}
object{drawSpline(greenSpline_00,0,1,0.005,greenSphere)}
object{drawSpline(greenSpline_01,1,2,0.005,greenSphere)}
object{drawSpline(greenSpline_02,2,3,0.005,greenSphere)}
object{drawSpline(greenSpline_03,3,4,0.005,greenSphere)}
object{drawSpline(greenSpline_01,0,3,0.005,blueSphere)}
//c: cameras from 1 to 2
#declare c = 1;
#switch(c)
   #case(1) camera {orthographic location <0,15,0> look_at <0,0,0>} #break
   #case(2) camera {orthographic location <6,15,4> direction 3*z look_at
p1} #break
Date: 13 Mar 2006 18:08:02
Message: <4415fb52$1@news.povray.org>
"Manuel Mata" <man### [at] yahooes> wrote in message
news:4415e9b2$1@news.povray.org...
>  ... snip ... I try to make a closed spline with straight stretchs, so I
> make 4 splines to build it, 2 linear_splines and 2 cubic_splines. The
> points should be tangent but they aren't. If you see the 2 cubic_splines
> definition they only define a stretch and have 2 control points who should
>  ... snip ...
Ahh. I think I see what you are getting at and I need to correct an error in
my earlier post where I agreed that the first and last points defined for a
cubic spline form tangents to the start and end of  the curve. As you
observe through your SDL they don't.  The first and last points in the cubic
spline are just control points and I believe they are treated in the same
way as the other cubic spline control points.
WRT your question as to whether this is different between POV-Ray 3.6 and
earlier versions, I don't think it is different. Certainly the cubic_spline
examples in the 3.6 help and the 3.5 help look to me to be identical and
both show what you seem to be showing in your SDL with the first point being
the same as the third from last point and the last point being the same as
the third point. In the 3.6 help, this example is in section 2.3.1.3.1
"Teaching An Old Spline New Tricks". In the 3.5 help it's the same section
title, but the section number is 3.4.3.1.
Chris B.
Date: 14 Mar 2006 17:02:11
Message: <44173d63$1@news.povray.org>
You are right the are treated like control points, but ... in 3.6 docs
'3.2.1.9 Spline Identifiers' section there is a 'Note' that says:
"Note: Because of the way cubic_splines are defined: the first and last
points are tangents rather than points on the spline, cubic_spline
interpolation is only valid between the second and next-to-last points ..."
I should read that and get confused. That note may is not well writen.
> earlier versions, I don't think it is different ...
What's the meaning of WRT ? Anyway you're right again, but ... I read
this tutorial at http://pandora.inf.uni-jena.de/p/e/noo/povsp/use.html
and probably get confused again. If you download and render the samples
you won't get the straight lines as we commented before, but ... I you
render them with Megapov 0.7g you'll see the straight stretch.
I think to remember that I began to use splines with Megapov so that's
why I probably were confused. I know that Megapov is unofficial so the
'control points' version of the cubic_spline is the only valid one.
Finally: first and last points are only 'control points'.
But I won't tire out. I'm tryin to build a spline that extends
cubic_spline. I had some #macros anywhere in my Old Hard Disk using
Hermite interpolation and with those #macros I had a spline where I
could create straight and curves stretch inside the same spline and with
continuity.
Anyway thanks Chris B. See ya.
                  Manuel Mata.
                  http://www.mmata.org
