POV-Ray : Newsgroups : povray.general : Text with diacritic signs Server Time
11 Jun 2026 22:56:35 EDT (-0400)
  Text with diacritic signs (Message 1 to 5 of 5)
Subject: Text with diacritic signs
Date: 14 Feb 2006 05:32:22
Message: <43f1b1b6@news.povray.org>
Greetings!
I got a problem when using text objects containing diacritic signs. For
the only program I use which shows this problem, I assume it is a problem
within POV. Is any solution available?
Thanks!!
Subject: Re: Text with diacritic signs
Date: 14 Feb 2006 06:16:27
Message: <ss1oEAAbtb8DFwAM@econym.demon.co.uk>
Wasn't it Thomas de Groot who wrote:
>Greetings!
>Thanks!!
Are you using "global_settings {charset utf8}"?
Mike Williams
Gentleman of Leisure
Date: 14 Feb 2006 09:06:20
Message: <43f1e3dc@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> schreef in bericht
news:ss1### [at] econymdemoncouk...
No, but now that you mention it, I see that default is ascii in
global_settings. I shall try utf8... and read the docs accordingly!
Thanks for the tip, Mike!
Date: 14 Feb 2006 09:38:22
Message: <43f1eb5d@news.povray.org>
  Note that if you use that setting, you then truely have to use utf8
encoding on the scene file (or more precisely, on those text strings
you want to render; the SDL itself just uses ascii, naturally, which is
"utf8-compatible").
  I actually am not completely sure if the winpov editor supports utf8.
My guess is that it doesn't...
Date: 15 Feb 2006 03:05:45
Message: <43f2e0d9@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schreef in bericht
news:43f1eb5d@news.povray.org...
> "utf8-compatible").
Well, I don't know about that, but it works fine indeed, and does what I
want!!
To reconstruct history: The problem arose from a scene in Moray. I have now
"discovered" that in Moray you can actually choose between ascii and utf8
settings. After all those years, I just overlooked it.
