POV-Ray : Newsgroups : povray.general : Isosurface warning message Server Time
15 Aug 2025 21:11:06 EDT (-0400)
  Isosurface warning message (Message 1 to 5 of 5)
Subject: Isosurface warning message
Date: 26 Jan 2006 16:12:24
Message: <43d93b38$1@news.povray.org>
I have a scene that contains some thousand isosurfaces with
slightly different functions. It is so many because I split
up a big isosurface into pieces to gain some render speed.
It actually worked and now the render process takes about
one third of the time it needed before.
But now there occur hundreds of warnings that the max_gradient
is too high. There is no simple way to adjust it into the optimal
range. The value now  is chosen for that it would fit in (nearly)
every case.
All together the test animation that renders at the moment already
makes 4MiB of fatal messages. Even piping everything to /dev/null takes
some seconds for every frame. This also is no real option because I
would like to keep other fatal messages and also don't want to spend
seconds for message disposal.
Is there a way to turn of these "lower max_gradient" messages?
Sebastian
Subject: Re: Isosurface warning message
Date: 26 Jan 2006 17:31:39
Message: <43d94dcb$1@news.povray.org>
> every case.
> Is there a way to turn off these "lower max_gradient" messages?
The messages are warning, not fatal or non-fatal error messages. You can
either redirect just the warning stream to /dev/null, or, more efficiently,
you can use the "Warning_Level" INI option and set it to 0. This makes
POV-Ray internally disregard the warnings relatively early, thus avoiding
some overhead associated with sending warnings to the output stream.
	Thorsten
Date: 30 Jan 2006 06:03:49
Message: <43ddf295@news.povray.org>
>> every case.
> efficiently, you can use the "Warning_Level" INI option and set it to 0.
> This makes POV-Ray internally disregard the warnings relatively early,
> thus avoiding some overhead associated with sending warnings to the
> output stream.
Great, reducing the warning level helps. Thank you very much.
Now I redirect all message streams to separate files respectively.
But the "lower max_gradient" messages definitely end up in the fatal
message file. So are they warnings or fatals or may this even be a bug?
The warning stream file contains just some warnings related to
screen.inc.
There's another curiosity. The first fatal message in the fatal message
file mentions a max_gradient of 10.850 found whereas the
max_gradient should have had been set to 13.000. But the greatest
max_gradient value to be found set in the whole scene is 5.0.
Another max_gradient value that can be found set and which possibly
was used is 1.35 (approx. 13.0/10). A max_gradient of 1.085 found also
would be feasible for the used isosurface and it would include a factor
of 1/10. This possible (and strage) multiplication by 10 happens only
for the first isosurface message in the fatal message file.
I rendered the scene with +GFfatal.txt.
Doing "cat fatal.txt | grep found" replies the following.
Shutdown Warning: The maximum gradient found was 10.850, but
max_gradient of the
Shutdown Warning: The maximum gradient found was 0.670, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.178, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.573, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.846, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.256, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.782, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.456, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.398, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.716, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.404, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.413, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.400, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.309, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.522, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.527, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.597, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.467, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.012, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.066, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.072, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.163, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.287, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.958, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.001, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.996, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.000, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 1.223, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.321, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.847, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.541, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.039, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.994, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.368, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.404, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.841, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.388, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.386, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.393, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.888, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.995, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.990, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.284, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.231, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.370, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.884, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.999, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.998, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.200, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.285, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.430, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.885, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.988, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.265, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.033, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.902, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.083, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.388, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.739, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.952, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.991, but max_gradient
of the
of the
of the
of the
Shutdown Warning: The maximum gradient found was 1.042, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.305, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.811, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.689, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.019, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.081, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.080, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 1.307, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.832, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.423, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.663, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.823, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.849, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.792, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.815, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.394, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.829, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.771, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.757, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.384, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.914, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.964, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 1.041, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.271, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.798, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.264, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.745, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.372, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.799, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.812, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.202, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.717, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.349, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.329, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.838, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.727, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.346, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.151, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.387, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.786, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.780, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.258, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.212, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.690, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.906, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.927, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.982, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.997, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.263, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.722, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.629, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.158, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.480, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.518, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.697, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.676, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.708, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.549, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.167, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.433, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.465, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.479, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.489, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.646, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.516, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.340, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.374, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.414, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.548, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.317, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.565, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.700, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.258, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.827, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.314, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.747, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.774, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.620, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.606, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.750, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.693, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.764, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.737, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.839, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.783, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.634, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.533, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.805, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.338, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.702, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.790, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.824, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.725, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.810, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.681, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.692, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.713, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.804, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.835, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.591, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.495, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.924, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.833, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.946, but max_gradient
of the
of the
Shutdown Warning: The maximum gradient found was 0.755, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.828, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.840, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.710, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.054, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.051, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.789, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.129, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 0.694, but max_gradient
of the
Shutdown Warning: The maximum gradient found was 1.139, but max_gradient
of the
of the
The rendered image seems in no way affected by this minor message
mystery. I just wanted it to be mentioned.
The povray version used is 3.6.1 compiled with gcc 3.3.5
(Debian sarge/stable).
Sebastian
Date: 30 Jan 2006 10:11:07
Message: <43de2c8b$1@news.povray.org>
This is indeed a bug in POV-Ray 3.6. It turns out that all messages that
report a filename/location _after_ parsing send their warnings to the error
message queue rather than the warning message queue, and consequently they
appear in the fatal/error stream rather than the warning stream where they
should be. This only concerns warning messages reporting a filename/location
_after_ parsing, which I think are (in 3.6) only isosurface max_gradient
warnings.
The max_gradient found depends on the pixels traced. The same is true for
the suggested max_gradient. It is only an estimate based on the pixels
traced, and usually not the real maximum gradient of the isosurface. As
such, it will be different if you trace different subsections of the same
isosurface.
	Thorsten
Date: 31 Jan 2006 11:02:51
Message: <43df8a2b@news.povray.org>
> error message queue rather than the warning message queue, and
> consequently they appear in the fatal/error stream rather than the
> warning stream where they should be. This only concerns warning messages
> reporting a filename/location _after_ parsing, which I think are (in
> 3.6) only isosurface max_gradient warnings.
>> message file mentions a max_gradient of 10.850 found whereas the
> for the suggested max_gradient. It is only an estimate based on the
> pixels traced, and usually not the real maximum gradient of the
> isosurface. As such, it will be different if you trace different
> subsections of the same isosurface.
>     Thorsten
Ok. Thank you for your reply.
Sebastian
