![](/i/fill.gif) |
"Trevor G Quayle" <Tin### [at] hotmail com> wrote:
> "dragonmage" <dra### [at] gmail com> wrote in message
> news:web.43d3183c456346d5e618711f0@news.povray.org...
> > Hellow, I am new to povray and have a question on an apparent lighnting
> > problem.
> > I too the phot_met_glass example and added a translate <10, 10, 10> to all
> > objects inclusing light and camera. This had an unexpected effect of
> > dramatically altering the bluish highlights in the rendered scene. I then
> > created another file with the translations still in there but set to:
> > translate <0, 0, 0> and the bluish hightlights came back. This leads me
> > to
> > believe there may be a default light source which I am not moving when I
> > add the translations. Anyone know wha is going on?
> Not sure exactly what you are saying here without further clarification or
> posting your scene, but it coul dpossibly be an 'ambient' problem. Try
> explicitly declaring "ambient 0" in all your object textures to remove any
> ambient effect on them and see if that helps.
I don't know how/where to declare ambient 0 yet - need to read up on POVRay
more . The scene is not large so I include the two examples below FYI.
THey only differ by where
the scene is positioned in the environment.
The first scene is as follows:
#version 3.5;
#include "glass.inc"
global_settings {
assumed_gamma 1
max_trace_level 25
photons {
spacing 0.03
autostop 0
jitter 0
location <20, 5, 10>
right 2*x
look_at <0,-1,0>
angle 34
translate <0, 0, 0>
light_source {
<-3, 10, 18>
color rgb <1.3, 1.2, 1.1>
translate <0, 0, 0>
photons {
reflection on
refraction on
plane {
y, -1
translate <0, 0, 0>
color rgb 1.0
sphere {
0, 1
translate <0, 0, 0>
gradient y
color_map {
[0.0 color rgb 1.0 ]
[0.3 color rgb <0.6, 0.65, 1.0> ]
finish { ambient 1 diffuse 0 }
scale 1000
hollow on
#declare Metal_Texture =
pigment { color rgb <0.5, 0.5, 0.6> }
finish {
ambient 0.0
diffuse 0.15
specular 0.3
roughness 0.01
reflection {
0.8
metallic
#declare Box = box { -1, 1 }
#declare Metal_Obj_1 =
difference {
object {
Box
object {
Box
scale <0.8, 0.8, 1.5>
object {
Box
scale <0.8, 1.5, 0.8>
object {
Box
scale <1.5, 0.8, 0.8>
texture { Metal_Texture }
rotate 12*y
translate <0, 0, 0>
#declare Metal_Obj_2 =
difference {
cylinder { -1.0*y, 0.0*y, 6.0
translate <0, 0, 0>
cylinder { -2.0*y, 1.0*y, 5.8
translate <0, 0, 0>
union {
object { Metal_Obj_1 }
object { Metal_Obj_2 }
sphere {
<0,0,0>, 1
translate <0, 0, 0>
material {
pigment { color Col_Glass_Clear }
finish { F_Glass6 }
interior {
I_Glass_Exp(2)
fade_color Col_Red_03
photons {
target
reflection on
refraction on
collect off
the same scene translated by (10,10,10) is:
#version 3.5;
global_settings {
assumed_gamma 1
max_trace_level 25
photons {
spacing 0.03
autostop 0
jitter 0
right 2*x
look_at <0,-1,0>
angle 34
light_source {
<-3, 10, 18>
photons {
reflection on
refraction on
plane {
y, -1
color rgb 1.0
sphere {
0, 1
gradient y
color_map {
scale 1000
hollow on
finish {
ambient 0.0
diffuse 0.15
specular 0.3
roughness 0.01
reflection {
0.8
metallic
difference {
object {
Box
object {
Box
object {
Box
object {
Box
rotate 12*y
difference {
union {
sphere {
<0,0,0>, 1
material {
finish { F_Glass6 }
interior {
I_Glass_Exp(2)
photons {
target
reflection on
refraction on
collect off
> -tgq
![](/i/fill.gif) |
![](/i/fill.gif) |
the problem is in one of your spheres:
//start
sphere {
0, 1
gradient y
color_map {
scale 1000
hollow on
//end
You are misusing translate and scale here, or at least its not operating as
you expect it to. When you scale something, it gets scaled based at the
origin, so translating *then* scaling does not equal scaling *then*
translating. In the original, the sphere was placed at <0,0,0> with a
radius of 1, then scaled 1000x. Since it was centered at the origin, the
result is that the sphere remains centered around the origin but now has a
radius of 1000. In your example here, you made a 1 radius sphere at the
origin and translated it <10,10,10> giving you a sphere with its center at
<10,10,10>. Then you scaled it 1000, which scaled the sphere larger, but
because scale centers on the origin, the <10,10,10> translation gets scaled
to a <10,10,10>*1000 translation giving you a 1000 radius sphere at
<10000,10000,10000> and therefore reflects in your other objects
differently. To get the correct results, move the translation after the
scale:
//start
sphere {
0, 1
gradient y
color_map {
scale 1000
hollow on
//end
Hope this helps you figure out what's going on.
-tgq
![](/i/fill.gif) |
