POV-Ray : Newsgroups : povray.general : Looking for a POV add- on or similar Server Time
10 Sep 2025 00:09:03 EDT (-0400)
  Looking for a POV add- on or similar (Message 1 to 10 of 17)
Subject: Looking for a POV add- on or similar
Date: 6 Jul 2005 12:20:34
Message: <42cc04d2@news.povray.org>
I'm trying out a number of media renders. In this process I'm iterating
round a loop of...
tinker with the settings
render
think
render
think
render
think
render
think
Oh hang on, it was better two iterations ago.  What were the setting then???
Darn, I've forgotten!
So what I'm looking for is a tool/facility/add-on that allows me to keep
tinkering with a pov file and saves the source and rendered file away
without me having to manually rename everything everytime.
Subject: Re: Looking for a POV add- on or similar
Date: 6 Jul 2005 12:51:38
Message: <Xns968BBFDD7B54Dseed7@news.povray.org>
> keep tinkering with a pov file and saves the source and rendered file
> away without me having to manually rename everything everytime.
Maybe subversion is the tool you need:
http://subversion.tigris.org/
Ingo
Date: 6 Jul 2005 15:48:49
Message: <42cc35a1$1@news.povray.org>
Create a subdirectory named after the date (down to the second) and copy
all the files into it? This is pretty easy as a batch file in either
Windows or Unix. (Well, trivial in Unix, really. Getting the date into a
format without special characters on Windows is a little tricky.)
     The samba was clearly inspired
     by the margarita.
Date: 6 Jul 2005 16:42:22
Message: <42CC419B.1060507@hotmail.com>
> round a loop of...
> render
> think
> render
> think
> render
> think
> render
> think
Sounds suspiciously like version control to me. Have you googled for
that?
Date: 6 Jul 2005 16:47:22
Message: <42cc435a$1@news.povray.org>
A subversion/cvs Gui Extension would be da bomb!
Date: 7 Jul 2005 09:33:07
Message: <42cd2f13$1@news.povray.org>
Thanks for your input guys, but it looks like I'm going to have to write
something myself.  I think I'll call it...  "Tinker".
Date: 7 Jul 2005 10:59:33
Message: <Xns968CACDB56C8Aseed7@news.povray.org>
Have not tried it, but you can probably automate it a lot with a clever
setup of Post_Scene_Commands in the main ini-file already.
Ingo
Date: 8 Jul 2005 20:48:06
Message: <42cf1ec6@news.povray.org>
Try animation.  You don't have to rename the file, you just save.  I
frequently use this approach when composing, even stills.
"Josh" <s### [at] acom> wrote in message news:42cc04d2@news.povray.org...
> round a loop of...
> render
> think
> render
> think
Date: 9 Jul 2005 05:30:01
Message: <web.42cf9892c97db32627f845b20@news.povray.org>
Can you make it available when you finish? I'm tired of saving as
sceneXX.pov :P
Date: 9 Jul 2005 12:28:09
Message: <42cffb19$1@news.povray.org>
 > sceneXX.pov :P
What OS are you using? It's a one-line shell script under Unix that you
could either invoke from a terminal or click on the desktop. I could
give you something for Windows the same way almost as easily. (Except
that the Windows shell isn't quite as sophisticated and the "date"
command is too user-friendly there. :-)
     by the margarita.
