POV-Ray : Newsgroups : povray.general : normals and textures using texture_map Server Time
28 Feb 2026 22:45:27 EST (-0500)
  normals and textures using texture_map (Message 1 to 6 of 6)
Subject: normals and textures using texture_map
Date: 1 Jul 2005 17:54:37
Message: <42c5bb9d@news.povray.org>
I have a normal "myNormal", created from a pigment function "fnPig" that I
want to apply to a texture "t3", but i want to apply the normal after I'm
done doing the warp & scale loop. "t3" is a texture created with a
"texture_map" of two textures "t1" and "t2".
Is it possible to apply a normal on "t3" (see comment in "t3") without
specifying a normal on "t1" and "t2"? If so, how?
thanks,
ross
// Begin Pov SDL
#declare t1 = texture {pigment {rgb 1} finish { specular 1 roughness 0.003
diffuse 0.3 reflection {0.2, 0.4 fresnel on} } }
#declare t2 = texture {pigment {rgb 0.2} finish { specular 0.6 roughness
0.03 diffuse 0.3 } }
#declare nPig =
 leopard scale 0.15
 color_map {
  [0.0 rgb 1]
  [1.0 rgb 0]
 #declare step = 8;
 #declare turb = <0.34, 0.3, 0.7>;
 #while (step > 0)
  warp {repeat x flip y}
  warp {turbulence turb }
  scale 1.2
  #declare step = step - 1;
#declare fnPig = function {pigment {nPig}}
#declare myNormal = normal {function {fnPig(x, y, z).gray}}
#declare t3 =
  leopard scale 0.15
  texture_map {
   [0.0 t1]
   [1.0 t2]
  #declare w1 = 8;
  #declare t1 = <0.34, 0.3, 0.7>;
  #while (w1 > 0)
   warp {turbulence t1 }
   scale 1.2
   #declare w1 = w1 - 1;
  // want to apply normal here, but it doesn't work
/**** test scene ****/
  location  <0, 6, -10>
  look_at   <0,5,0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <200,400,-350>
  color rgb 1
sphere {
 <0, 2, 2>, 2
 texture {t3}
 interior {
   ior 1.455
plane {
  y, 0
  texture { pigment {rgb <0.65, 1, 0.36>} }
Subject: Re: normals and textures using texture_map
Date: 2 Jul 2005 10:45:01
Message: <web.42c6a70ef229687477de37d40@news.povray.org>
No, but I think the following does what you want.
// Persistence of Vision Ray Tracer Scene Description File
//  From: Ross
//  Subject: normals and textures using texture_map
//  Date: 1 Jul 2005 21:54:37
//  Message: <42c5bb9d@news.povray.org>
//  Modified by PM 2Ring
//  -D +A0.1 +AM2 +R3
//  -F -A0.5 +AM2 +R1
global_settings { assumed_gamma 1.0 }
#declare Step = 8;
#declare Turb = <0.34, 0.3, 0.7>;
#declare Pig =
 leopard scale 0.15
 //color_map {[0.0 rgb 1][1.0 rgb 0]} //Redundant: this is the default
 #declare I = Step;
 #while (I > 0)
  warp {turbulence Turb}
  scale 1.2
  #declare I = I - 1;
#declare fnPig = function {pigment {Pig}}
#declare myNormal = normal {function {fnPig(x, y, z).x}}
#declare Dull =  finish { specular 1 roughness 0.003 diffuse 0.3 reflection
#declare Shiny = finish { specular 0.6 roughness 0.03 diffuse 0.3 }
#declare t1 = texture {pigment {rgb 1} finish { Dull } normal {myNormal} }
#declare t2 = texture {pigment {rgb 0.2} finish { Shiny } normal {myNormal}
#declare t3 =
  texture_map {
   [0.0 t1]
   [1.0 t2]
  //location  <0, 6, -10>
  //look_at   <0,5,0>
  location  <0, 3, -12>
  look_at   <0,2,0>
  angle 30
light_source {
  <200,400,-350>
  rgb 1
sky_sphere {
    gradient y
    color_map {
plane {
  y, 0
//The ball
sphere {
 <0, 2, 2>, 2
 texture {t3}
 interior { ior 1.455 }   //So Fresnel works
//Some objects to reflect in the ball
#macro Post(A,C) cylinder{A, A+4*y, 0.5 pigment{C}
  finish{specular .5 roughness 0.03}}
Post(-2.4*x, red 1)
Post(2.4*x, blue 1)
I hope this helps.
Date: 3 Jul 2005 01:49:56
Message: <pan.2005.07.03.05.49.55.750463@speakeasy.net>
:snip:
> I hope this helps.
Yes, that looks good I think. Thanks for the technique. Looks really goopy
and bumpy :)
Thanks,
ross
Date: 3 Jul 2005 20:10:01
Message: <web.42c87d7ef2296874ad93754b0@news.povray.org>
> :snip:
> > I hope this helps.
> and bumpy :)
> Thanks,
> ross
My pleasure! Yes, it does look good. I'm going to try an isosurface version.
Thanks for showing me that trick of multiple repeat warps, I'll have to
investigate this further.
Here's my first scene using repeat & black hole warps. You may need to
adjust the gamma; I messed up the conversion from .png to .jpg.
<web.42bd012124f9fc099b7567e60@news.povray.org>
Date: 6 Jul 2005 07:45:00
Message: <web.42cbc31df229687430757dd90@news.povray.org>
Here's the isosurface version. As expected, it renders much slower than the
normals version. If you make the accuracy much smaller than 0.0075, you
will have to push the max_gradient right up and render speeds become
glacial, especially with high AA settings.
//  From: Ross
//    I have a normal "myNormal", created from a pigment function "fnPig"
that I
//  want to apply to a texture "t3", but i want to apply the normal after
I'm
//  done doing the warp & scale loop. "t3" is a texture created with a
//  "texture_map" of two textures "t1" and "t2".
//  Is it possible to apply a normal on "t3" (see comment in "t3") without
//  specifying a normal on "t1" and "t2"? If so, how?
//  thanks,
//  ross
//  Isosurface version 2005.07.04
//  -D +A0.1 +AM2 +R2
#include "functions.inc"
global_settings {
  assumed_gamma 1.0
  max_trace_level 7
#declare Step = 8;
#declare Pig =
  leopard scale 0.15
  #declare I = Step;
  #while (I > 0)
    scale 1.2
    #declare I = I - 1;
#declare t1 = texture {pigment {rgb 1} finish { Dull } }
#declare t2 = texture {pigment {rgb 0.2} finish { Shiny } }
#declare t3 =
  texture_map {
   [0.0 t1]
   [1.0 t2]
  //look_at   <0,5,0>
  look_at   <0,2,0>
  angle 30
light_source {
  <200,400,-350>
  rgb 1
sky_sphere {
    gradient y  scale .7
    color_map {
plane {
  y, 0
#declare IsoDepth = 0.035;
isosurface{
  function {f_sphere(x,y-2,z-2, 2 + IsoDepth*(fnPig(x,y,z).x-1))}
  contained_by{sphere {<0, 2, 2>, 2}}
  accuracy 0.0075
  max_gradient 9.9
  texture {t3}
#macro Post(A,C)cylinder{A, A+4*y, 0.5 pigment{C}finish{specular .75
roughness 0.01}} #end
Post(-2.4*x, red 1)
Post(2.4*x, blue 1)
Date: 7 Jul 2005 11:13:16
Message: <42cd468c$1@news.povray.org>
"PM 2Ring" <nomail@nomail> wrote in message
news:web.42cbc31df229687430757dd90@news.povray.org...
the
> isosurface{
>   accuracy 0.0075
>   max_gradient 9.9
>   texture {t3}
thanks, I'll play with it some. there are some small differences between
what I had tried and what you have posted. i need to figure out why they are
important. (my tries had me cranking max_gradient up to > 50)
-r
