POV-Ray : Newsgroups : povray.general : Limit Reflection Server Time
28 Feb 2026 22:45:26 EST (-0500)
  Limit Reflection (Message 1 to 4 of 4)
Subject: Limit Reflection
Date: 23 Jun 2005 19:28:33
Message: <42bb45a1$1@news.povray.org>
I'm creating a city scene and a plaza is surrounded on all four sides by
skyscrapers. These are mostly tinned glass and so reflect a lot.
My problem is that my scene is taking years to render because of all the
reflections .. the light is bouncing down the streets from building to
building!
Now, when I look at skyscrapers in my RL city, this doesn't happen ..
everything just appears darkish unless the sky is actually reflecting on it.
How do I get this to happen in POVRay?
Subject: Re: Limit Reflection
Date: 24 Jun 2005 00:58:27
Message: <42bb92f3@news.povray.org>
"Rick Measham" <rickm*at%isite.net.au> wrote in message
news:42bb45a1$1@news.povray.org...
> building!
> it.
The global setting 'max_trace_level' will already limit it by default to 5
bounces but maybe you could set that to just 3 instead and still not effect
transparent surfaces.
If you aren't using variable reflection (both a minimum and a maximum value
together) yet maybe give that a try, so that the reflections diminish at
various angles of view or incidence.
And, after saying all that, I almost forgot about the exact phenomenon you
seem to have told of-- 'reflection_exponent', or as it is used now, just the
word exponent with a value less than one and nearer to zero which reflects
less of the darker things and so leaving brighter things to remain instead.
At least I think this might be the best advice of the three choices I
mentioned here, but I'm not sure how it'll effect render time. Maybe
somebody else knows better than I do (no surprise, if so).
Bob Hughes
Date: 24 Jun 2005 10:52:28
Message: <42bc1e2c$1@news.povray.org>
Rick Measham nous apporta ses lumieres en ce 2005-06-23 19:28:
> building!
> it.
Have a lower value for your reflection like reflection 0.5, never use reflection 1. In
the
global_settings{...} set a slightly larger value for adc_bailout, like 1/128 to 1/64
A sample texture for your reflective windows can help to give you a more specific
suggestion.
Date: 25 Jun 2005 19:33:34
Message: <42bde9ce$1@news.povray.org>
> > it.
reflection 1.
This tip combined with making the sky significantly brighter than the
buildings will probably get the proper effect. I would try a lower
reflection value like 0.3 or so to get the building reflections as dark as
you think they should be, and then play with the sky brightness to make it
look right. It might be tricky to do this while avoiding a blindingly white
sky; the buildings themselves could be darkened to help avoid that.
 - Slime
 [ http://www.slimeland.com/ ]
